http://www.alsa-project.org/db/?f=5e9937a91e676359e6755c4cabfca51c63e46bb8
παιδιά δεν έχω ήχο στο notebook που έχω στην υπογραφή μου και δεν ξέρω τι να κάνω....
έγραψε:00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
sudo alsa force-reloadkillall pulseaudio
gelasak@gelasak-laptop:~$ killall pulseaudio
gelasak@gelasak-laptop:~$ sudo alsa force-reload
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
Output information may be incomplete.
Terminating processes: 2224lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
2243lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
2260lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
2277lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
(with SIGKILL:) 2294lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/gelasak/.gvfs
(failed: processes still using sound devices: 2311(pulseaudio)).
/sbin/alsa: Warning: Processes using sound devices: 2311(pulseaudio).
Unloading ALSA sound driver modules: snd-seq-dummy snd-seq-oss snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-seq-device snd-pcm-oss snd-mixer-oss snd-hda-intel snd-hda-codec-intelhdmi snd-hda-codec-realtek snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc (failed: modules still loaded: snd-hda-intel snd-hda-codec-intelhdmi snd-hda-codec-realtek snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc).
Loading ALSA sound driver modules: snd-seq-dummy snd-seq-oss snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-seq-device snd-pcm-oss snd-mixer-oss snd-hda-intel snd-hda-codec-intelhdmi snd-hda-codec-realtek snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc.
[sudo] password for gelasak:
--Sat Mar 6 17:30:01 EET 2010----Alsa-Upgrade-Script-1.0.22.1-1 -----------------
- You'll be upgraded from 1.0.21. to 1.0.22.1
- Run -h option for further help and to look up the workflows
- DISCLAIMER: Use this script at your own risk. I do not take any
- responsability for any problems caused by running
- this script.
- In any case I strongly advise you to make a backup first!
- Do you want to configure and compile 1.0.22.1 [y/n]: y
- Alsa packages(drivers/lib/util/firmware/oss) will be compiled
- Prepare for compilation and installation...
- Compiling drivers...
rm -f .depend *.o snd.map*
rm -f modules/*.o modules/*.ko
make[1]: Entering directory `/usr/src/Alsa-1.0.22.1/alsa-driver-1.0.22.1/include'
Makefile:6: ../Makefile.conf: No such file or directory
make[1]: *** No rule to make target `../Makefile.conf'. Stop.
make[1]: Leaving directory `/usr/src/Alsa-1.0.22.1/alsa-driver-1.0.22.1/include'
make: *** [clean] Error 1
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking whether time.h and sys/time.h may both be included... yes
checking whether gcc needs -traditional... no
checking for current directory... /usr/src/Alsa-1.0.22.1/alsa-driver-1.0.22.1
checking cross compile...
checking for directory with ALSA kernel sources... ./configure: line 5107: cd: ../alsa-kmirror: No such file or directory
../alsa-kmirror
checking for directory with kernel source... /usr/src/linux-headers-2.6.33-020633-generic
checking for directory with kernel build...
checking for kernel linux/version.h... yes
checking for kernel linux/autoconf.h... no
The file /usr/src/linux-headers-2.6.33-020633-generic/include/linux/autoconf.h does not exist.
Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /lib/modules/2.6.33-020633-generic/build).
- alsa-driver-1.0.22.1 configure failed
gelasak@gelasak-laptop:~$ sudo ./AlsaUpgrade-1.0.22.1-2.sh -c
--Sat Mar 6 17:31:36 EET 2010----Alsa-Upgrade-Script-1.0.22.1-1 -----------------
- this script.
../alsa-kmirror
Kernel release: 2.6.33-020633-genericέγραψε:Supported kernels: 2.6.24/26/27/28/29/30/31/32 family (including rt-kernel & NON-Ubuntu ZEN-rt-kernel)
έγραψε:Θα μπουρούσες να βάλεις το Ubuntu Lucid 10.04, πού έχει Alsa 1.0.22.1. Ή τουλάχιστον δοκίμασε το Live CD, έτσι και αλλιώς θα έχει επίσημα σε ένα μήνα.
