http://hostsfile.mine.nu/downloads/updatehosts.sh.txt
Πώς ακριβώς το τρέχω;;;;
Πώς μπορώ να το βάλω να τρέχει αυτόματα κάθε μέρα;
#!/bin/bash
# Hosts file updater
# You will probably need root or su rights to access /etc/hosts
# modified by killermist with (what seem to be) some logical tweaks
# Debian users will need the package "sysutils" as this script uses dos2unix
# $ sudo apt-get install sysutils
HFSERVER="http://hostsfile.mine.nu.nyud.net"
HFILE="hosts.zip"
ORIGFILE="/etc/hosts.original"
clear
echo "-------------------------------------------------------------"
echo "This script will update your Hosts file to the latest version"
echo "Your original Hosts file will be renamed to $ORIGFILE"
echo ""
if [ ! -f "$ORIGFILE" ] ; then
echo "Backing up your previous hosts file.."
cp -v /etc/hosts $ORIGFILE # I like verbose file operations. Can be less verbose if necessary.
fi
echo "Retrieving $HFILE from $HFSERVER"
echo ""
wget -O /tmp/$HFILE $HFSERVER/$HFILE
unzip -p /tmp/$HFILE | dos2unix > /tmp/hosts
if [ 'grep -c "banner" /tmp/hosts' ];then
echo "Downloaded and unpacked $HFILE OK"
echo "Appending host list to original content" # which was probably there for a reason, like to make sure localhost worked, and possibly even more stuff if part of a corporate LAN
#cp -f -u /tmp/hosts /etc/hosts
cat $ORIGFILE >/etc/hosts
echo "" >>/etc/hosts # to make sure the original file ends in a new-line so that 2 entries don't end up on the same line, either causing unexpected behavior or not working at all
cat /tmp/hosts >>/etc/hosts
rm -fv /tmp/hosts* # again, I like verbose file operations. I like to know what my system is doing.
echo "Update process complete"
#echo "-------------------------------------------------------------"
echo "As a side-effect of this script, any changes you wish to make"
echo "persistent in the hosts file should be made to $ORIGFILE"
echo "because /etc/hosts will be respawned from that file and the "
echo "newlist from the server each time this script runs."
exit
else
echo "Update failed"
fi
