dual screen
jockey-text
dual screen
Δημοσίευσηαπό manolis » 07 Ιούλ 2008, 01:03
παιδια καλησπερα ,εδω και καιρο προσπαθω να κανω τις 2 οθονες που εχω να δουλεψουβ "σωστα".αυτη τη στιγμη οι οθονες ειναι σαν cloned δηλ δειχνουν το ιδιο desktop το ποντικι παει απο τι μια οθονη στην αλλη η μια μονο οθονη εχει εικονιδια δεν μπορω να μεταφερω ενα παραθυρο απο τη μια οθονη στην αλλη (μπορω ομως ενα αρχειο) και επεισης δε μπορω να μεγαλωσω ενα παραθηρο ωστε να καλυψει και τις 2.εχω ubuntu 8.04 ati radeon hd2600 pro (ειναι agp) και τον fglrx.
το xorg conf ειναι ετσι:
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
Screen "aticonfig-Screen[0]-1" RightOf "aticonfig-Screen[0]-0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dri"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-1"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
Option "DesktopSetup" "horizontal"
Option "OverlayOnCRTC2" "1"
BusID "PCI:2:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-1"
Driver "fglrx"
BusID "PCI:2:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-1"
Device "aticonfig-Device[0]-1"
Monitor "aticonfig-Monitor[0]-1"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
στην ουσια εγω θελω οι 2 οθονες να δειχνουν σαν μια.
εχω δοκιμασει το bigdesktop αλλα τιποτα
Επίπεδο Γνώσεων: Linux: χαμηλο/ Προγραμματισμός: Όχι / Αγγλικά: καλα
Λειτουργικό ubuntu 8.04.1 32bit
AMD Athlon 3000+ / 2x512 / ATI RADEON 2600PRO HD AGP / NO / NO / NFORCE -NVIDIA nFORCE2 /2xLG 19"-2650-1024
manolis
Re: dual screen
Δημοσίευσηαπό ftso » 07 Ιούλ 2008, 02:21
Δες εδώ (http://ubuntuforums.org/showthread.php?t=221174) τι μπορείς να κάνεις.
Νομίζω μόνο το xinerama μπορείς να δοκιμάσεις ακόμα.
ftso
IRC: ftso
