Το πρόβλημα είναι ότι αργεί υπερβολικά στο boot. Παραθέτω τα παρακάτω, γιατί νομίζω ότι κάτι συμβαίνει με τους δίσκους και αργεί:
georgios@georgios-Lenovo-G50-80:~$ systemd-analyze blame
24.059s apt-daily.service
8.599s NetworkManager-wait-online.service
7.608s dev-sda3.device
5.584s networking.service
4.576s apparmor.service
2.893s systemd-udevd.service
2.565s NetworkManager.service
1.706s thermald.service
1.653s accounts-daemon.service
1.560s console-setup.service
1.539s ModemManager.service
1.259s gpu-manager.service
1.156s grub-common.service
1.126s systemd-tmpfiles-setup-dev.service
1.062s keyboard-setup.service
1.056s systemd-tmpfiles-setup.service
1.045s colord.service
902ms systemd-modules-load.service
738ms snapd.refresh.service
727ms systemd-rfkill.service
690ms plymouth-start.service
674ms lm-sensors.service
671ms rsyslog.service
671ms apport.service
660ms avahi-daemon.service
533ms systemd-hostnamed.service
519ms upower.service
499ms systemd-journald.service
424ms systemd-localed.service
376ms udisks2.service
362ms sys-kernel-debug.mount
361ms dev-mqueue.mount
327ms lightdm.service
309ms dns-clean.service
282ms systemd-update-utmp.service
274ms dev-hugepages.mount
270ms systemd-logind.service
249ms systemd-random-seed.service
241ms irqbalance.service
240ms systemd-timesyncd.service
229ms systemd-udev-trigger.service
228ms systemd-sysctl.service
218ms wpa_supplicant.service
181ms ufw.service
178ms systemd-user-sessions.service
166ms systemd-remount-fs.service
148ms polkitd.service
132ms systemd-backlight@backlight:intel_backlight.service
129ms bluetooth.service
80ms systemd-journal-flush.service
74ms ondemand.service
72ms plymouth-read-write.service
71ms speech-dispatcher.service
69ms kmod-static-nodes.service
60ms setvtrgb.service
32ms alsa-restore.service
28ms user@1000.service
22ms resolvconf.service
19ms pppd-dns.service
18ms systemd-tmpfiles-clean.service
15ms hddtemp.service
8ms systemd-update-utmp-runlevel.service
7ms rtkit-daemon.service
6ms sys-fs-fuse-connections.mount
6ms ureadahead-stop.service
5ms rc-local.service
2ms plymouth-quit-wait.service
521us snapd.socket
georgios@georgios-Lenovo-G50-80:~$ sudo blkid
/dev/sda1: LABEL="System Reserved" UUID="C2E0620AE062054F" TYPE="ntfs" PARTUUID="57a01957-01"
/dev/sda2: UUID="50468342468327B4" TYPE="ntfs" PARTUUID="57a01957-02"
/dev/sda3: UUID="76b193fd-106b-466e-88e5-84d762c08eab" TYPE="ext4" PARTUUID="57a01957-03"
/dev/sda5: UUID="0664868b-56e9-4fed-a263-d2f250b7dbac" TYPE="swap" PARTUUID="57a01957-05"
/dev/sda6: LABEL="arxeio" UUID="12B5B44B2C19B2F2" TYPE="ntfs" PARTUUID="57a01957-06"
georgios@georgios-Lenovo-G50-80:~$ sudo gedit /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda3 during installation
UUID=76b193fd-106b-466e-88e5-84d762c08eab / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=ca0c5d7d-9809-483b-8502-d275ea57f177 none swap sw 0 0
