sudo gedit /var/lib/dpkg/info/wine.postinst
και postαρε το περιεχομενο του αρχειου!
#!/bin/sh -e
if [ "$1" = "configure" ] ; then
if [ -x /usr/sbin/update-binfmts ]; then
/usr/sbin/update-binfmts --import wine || true
fi
fi
if [ "$1" = "upgrade" ] ; then
if ps -C wineserver > /dev/null && test -d /var/lib/update-notifier/user.d/ ; then
cp -f /usr/share/wine/wineserver-restart-required.update-notifier /var/lib/update-notifier/user.d/wineserver-restart-required
fi
fi
# Automatically added by dh_installmime
if [ "$1" = "configure" ] && [ -x "`which update-mime 2>/dev/null`" ]; then
update-mime
fi
# End automatically added section
# Automatically added by dh_makeshlibs
if [ "$1" = "configure" ]; then
ldconfig
fi
# This is a workaround to procps not starting (LP: #447197)
cat /etc/sysctl.d/*.conf /etc/sysctl.conf | sysctl -p -
cat /etc/sysctl.d/*.conf /etc/sysctl.conf | sysctl -p - || true
sudo apt-get install wine
Reading package lists... Done
Building dependency tree
wine is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Setting up wine (1.0.1-0ubuntu8) ...
kernel.printk = 4 4 1 7
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.tcp_syncookies = 1
vm.mmap_min_addr = 0
error: "vm.swapiness" is an unknown key
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
elefher έγραψε:απλα τωρα εχω τη παλια version ετσι?να μην δοκιμασω τη καινουργια ακομα?
