Wordpress + Piwik + docker compose πρόβλημα
...ρύθμιση - εγκατάσταση web server, mail server, ftp server, κλπ
Συντονιστές: the_eye, konnn
Δημοσίευσηαπό pc_magas » 06 Αύγ 2016, 19:15
Καλησπέρες,
Όπως αναγράφω στο:
http://stackoverflow.com/questions/3880 ... containers
και στο
http://serverfault.com/questions/795247 ... containers
Θέλω να βάλω σε docker container wordpress και piwik έτσι να μπορώ να έχω και analytics σε ένα wordppress blog. To docker compose μου εν το:
db:
  image: mysql
  volumes:
    - ./mysql/runtime:/var/lib/mysql
  environment:
    - MYSQL_ROOT_PASSWORD
app:
  image: piwik
  links:
    - db
  volumes:
    - ./config:/var/www/html/config
    - ./ssmtp.conf:/etc/ssmtp/ssmtp.conf
    - ./revaliases:/etc/ssmtp/revaliases
web:
  image: nginx
  volumes:
    - ./nginx.conf:/etc/nginx/nginx.conf:ro
  links:
    - app
  volumes_from:
    - app
  environment:
    - VIRTUAL_HOST
cron:
  image: piwik
  links:
    - db
  volumes_from:
    - app
  entrypoint: |
    bash -c 'bash -s <<EOF
    trap "break;exit" SIGHUP SIGINT SIGTERM
    while /bin/true; do
      su -s "/bin/bash" -c "/usr/local/bin/php /var/www/html/console core:archive" www-data
      sleep 3600
    done
    EOF'
db2:
  image: mysql:5.7
  volumes:
    - "./.data/db/wordpress:/var/lib/mysql"
  restart: always
  environment:
    MYSQL_ROOT_PASSWORD: wordpress
    MYSQL_DATABASE: wordpress
    MYSQL_USER: wordpress
    MYSQL_PASSWORD: wordpress
wordpress:
  image: wordpress:latest
  volumes:
    - ".data/www/wordppress:/var/www/html"
  links:
    - db2
    - web
  ports:
    - "8000:80"
  restart: always
  environment:
    WORDPRESS_DB_HOST: db2:3306
    WORDPRESS_DB_PASSWORD: wordpress
Ενώ το σφάλμα στην "φαφλατάδικη" μορφή είναι:
compose.config.config.find: Using configuration files: ./docker-compose.yml
docker.auth.auth.load_config: File doesn't exist
compose.cli.command.get_client: docker-compose version 1.8.0, build 94f7016
docker-py version: 1.9.0
CPython version: 2.7.12
OpenSSL version: OpenSSL 1.0.2g-fips  1 Mar 2016
compose.cli.command.get_client: Docker base_url: http+docker://localunixsocket
compose.cli.command.get_client: Docker version: KernelVersion=4.4.0-31-generic, Os=linux, BuildTime=Wed, 20 Apr 2016 14:19:16 -0700, ApiVersion=1.22, Version=1.10.3, GitCommit=20f81dd, Arch=amd64, GoVersion=go1.6.1
compose.cli.verbose_proxy.proxy_callable: docker info <- ()
compose.cli.verbose_proxy.proxy_callable: docker info -> {u'Architecture': u'x86_64',
u'BridgeNfIp6tables': True,
u'BridgeNfIptables': True,
u'CPUSet': True,
u'CPUShares': True,
u'ClusterAdvertise': u'',
u'ClusterStore': u'',
u'Containers': 2,
u'ContainersPaused': 0,
u'ContainersRunning': 0,
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=False, filters={u'label': [u'com.docker.compose.project=piwik', u'com.docker.compose.oneoff=False']})
compose.cli.verbose_proxy.proxy_callable: docker containers -> (list with 0 items)
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=True, filters={u'label': [u'com.docker.compose.project=piwik', u'com.docker.compose.service=db', u'com.docker.compose.oneoff=False']})
compose.cli.verbose_proxy.proxy_callable: docker containers -> (list with 1 items)
compose.cli.verbose_proxy.proxy_callable: docker inspect_container <- (u'977abffbb37e6e174ca288e74e2c093ebb4e1e647a54263a37171dbef5f28d02')
compose.cli.verbose_proxy.proxy_callable: docker inspect_container -> {u'AppArmorProfile': u'',
u'Args': [u'mysqld'],
u'Config': {u'AttachStderr': False,
             u'AttachStdin': False,
             u'AttachStdout': False,
             u'Cmd': [u'mysqld'],
             u'Domainname': u'',
             u'Entrypoint': [u'docker-entrypoint.sh'],
             u'Env': [u'MYSQL_ROOT_PASSWORD',
                      u'PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin',
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=True, filters={u'label': [u'com.docker.compose.project=piwik', u'com.docker.compose.service=app', u'com.docker.compose.oneoff=False']})
compose.cli.verbose_proxy.proxy_callable: docker inspect_container <- (u'0616eefb57ced533cda3d0dee0827e76e5af517d728dbe532d4a5144ed7b484d')
u'Args': [u'php-fpm'],
             u'Cmd': [u'php-fpm'],
             u'Domainname': u'',
             u'Entrypoint': [u'/entrypoint.sh'],
             u'Env': [u'PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin',
                      u'PHPIZE_DEPS=autoconf \t\tfile \t\tg++ \t\tgcc \t\tlibc-dev \t\tmake \t\tpkg-config \t\tre2c',
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=True, filters={u'label': [u'com.docker.compose.project=piwik', u'com.docker.compose.service=web', u'com.docker.compose.oneoff=False']})
compose.cli.verbose_proxy.proxy_callable: docker containers <- (all=True, filters={u'label': [u'com.docker.compose.project=piwik', u'com.docker.compose.service=cron', u'com.docker.compose.oneoff=False']})
compose.cli.verbose_proxy.proxy_callable: docker inspect_image <- ('mysql')
compose.cli.verbose_proxy.proxy_callable: docker inspect_image -> {u'Architecture': u'amd64',
u'Author': u'',
u'Comment': u'',
u'Config': {u'ArgsEscaped': True,
             u'Domainname': u'',
compose.cli.verbose_proxy.proxy_callable: docker inspect_image <- ('piwik')
u'Author': u'pierre@piwik.org',
u'Comment': u'',
             u'Domainname': u'',
compose.cli.verbose_proxy.proxy_callable: docker inspect_image <- ('nginx')
u'Author': u'NGINX Docker Maintainers "docker-maint@nginx.com"',
u'Comment': u'',
             u'Cmd': [u'nginx', u'-g', u'daemon off;'],
             u'Domainname': u'',
             u'Entrypoint': None,
u'Comment': u'',
             u'Domainname': u'',
u'Author': u'',
u'Comment': u'',
             u'Domainname': u'',
             u'Domainname': u'',
u'Comment': u'',
             u'Domainname': u'',
             u'Domainname': u'',
compose.parallel.feed_queue: Pending: set([<Service: db>, <Service: app>, <Service: web>, <Service: cron>])
compose.parallel.feed_queue: Starting producer thread for <Service: db>
compose.service.start_container_if_stopped: Starting piwik_db_1
compose.cli.verbose_proxy.proxy_callable: docker start <- (u'977abffbb37e6e174ca288e74e2c093ebb4e1e647a54263a37171dbef5f28d02')
compose.parallel.feed_queue: Pending: set([<Service: cron>, <Service: app>, <Service: web>])
compose.cli.verbose_proxy.proxy_callable: docker start -> None
compose.parallel.parallel_execute_iter: Finished processing: <Service: db>
compose.parallel.feed_queue: Starting producer thread for <Service: app>
compose.service.start_container_if_stopped: Starting piwik_app_1
compose.cli.verbose_proxy.proxy_callable: docker start <- (u'0616eefb57ced533cda3d0dee0827e76e5af517d728dbe532d4a5144ed7b484d')
compose.parallel.feed_queue: Pending: set([<Service: cron>, <Service: web>])
compose.parallel.parallel_execute_iter: Failed: <Service: app>
compose.parallel.feed_queue: <Service: cron> has upstream errors - not processing
compose.parallel.feed_queue: <Service: web> has upstream errors - not processing
compose.parallel.parallel_execute_iter: Failed: <Service: cron>
compose.parallel.feed_queue: Pending: set([])
compose.parallel.parallel_execute_iter: Failed: <Service: web>
ERROR: for app  Cannot start service app: Cannot link to a non running container: /piwik_db_1 AS /piwik_app_1/db
compose.cli.main.main: Encountered errors while bringing up the project.
Για να τρέξω τα containers χρησιμοποιώ την εντολή:
docker-compose --verbose up -d
Και έχω τις εξής εκδόσεις:
  • docker-compose version 1.8.0, build 94f7016
  • Docker version 1.10.3, build 20f81dd
Και όλα τα τρέχω σε ubuntu 16.04 .
Οι υπολογιστές μου:
pc_magas
Τοποθεσία: Αχαρναί Αττικής
Launchpad: pc_magas
IRC: pc_magas
Re: Wordpress + Piwik + docker compose πρόβλημα
Δημοσίευσηαπό pc_magas » 07 Αύγ 2016, 16:35
Τελικά το έλυσα αλλάζοντας εκεί που λέει:
  environment:
σε:
  environment:
    MYSQL_ROOT_PASSWORD: "samplepasword"
Οι υπολογιστές μου:
pc_magas
Launchpad: pc_magas
IRC: pc_magas
Επιστροφή στο Διακομιστές / Εξυπηρετητές
