Nvidia 334.16 (beta) και Ubuntu 14.04(alpha2)
Δημοσίευσηαπό Learner » 08 Φεβ 2014, 20:55
Κυκλοφόρησε μόλις χθες ο νέος beta οδηγός της Nvidia. Τα links για να κατεβάσετε είναι
1) http://www.nvidia.com/download/driverRe ... 3100/en-us
2) http://www.nvidia.com/download/driverRe ... 3099/en-us
Κατάφερε να τον εγκαταστήσει κανείς ; Προσπάθησα 1-2 φορές αλλά αποτυχία. Τα σχετικά μηνύματα του Xorg
[    39.963] (II) Module glx: vendor="NVIDIA Corporation"
[    39.963] (II) NVIDIA GLX Module  334.16  Tue Feb  4 14:15:35 PST 2014
[    39.963] (II) LoadModule: "nvidia"
[    39.963] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    40.014] (II) Module nvidia: vendor="NVIDIA Corporation"
[    40.015] (II) NVIDIA dlloader X Driver  334.16  Tue Feb  4 13:53:20 PST 2014
[    40.015] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    40.047] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    40.047] (EE) NVIDIA:     system's kernel log for additional error messages and
[    40.047] (EE) NVIDIA:     consult the NVIDIA README for details.
[    40.047] (==) Matched nvidia as autoconfigured driver 0
[    40.047] (II) LoadModule: "nvidia"
[    40.047] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    40.047] (II) Module nvidia: vendor="NVIDIA Corporation"
[    40.047] (II) UnloadModule: "nvidia"
[    40.048] (II) Unloading nvidia
[    40.048] (II) Failed to load module "nvidia" (already loaded, -1217370442)
[    40.092] (II) NVIDIA dlloader X Driver  334.16  Tue Feb  4 13:53:20 PST 2014
[    40.092] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    40.092] (II) NOUVEAU driver for NVIDIA chipset families :
[    40.108] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    40.108] (EE) NVIDIA:     system's kernel log for additional error messages and
[    40.108] (EE) NVIDIA:     consult the NVIDIA README for details.
[    40.300] (II) VESA(0): VESA VBE OEM: NVIDIA
[    40.300] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[    41.100] (II) VESA(0): VESA VBE OEM: NVIDIA
[    41.100] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[    41.309] (EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
και του πυρήνα
nvidia: module license 'NVIDIA' taints kernel.
nvidia: module verification failed: signature and/or  required key missing - tainting kernel
nvidia: Unknown symbol acpi_os_wait_events_complete (err 0)
Τα δυο πρώτα δεν νομίζω ότι έχουν σχέση, όσο το τελευταίο. Τα 2 πρώτα τα εμφανίζει και στον 331 ο οποίος λειτουργεί σωστά.
Σχετικά με το τελευταίο μήνυμα λάθους, βρήκα μια συζήτηση στο nvidia-developers zone για παλαιότερο οδηγό (331) και τον 3-13 -rc1 πυρήνα. Λέτε να μην το έχουν διορθώσει ακόμη ; Να έχει σχέση με τον Xorg 1.15 που «φοράει» η 14.04 ;
Re: Nvidia 334.16 (beta) και Ubuntu 14.04(alpha2)
Δημοσίευσηαπό asvos » 09 Φεβ 2014, 18:51
Δηλαδή σε xubuntu δεν παίζει;
Η λέω βλακείες;
NetBook
Ubuntu 19.04
asvos
Δημοσίευσηαπό Learner » 09 Φεβ 2014, 19:10
Λογικά δεν πρέπει να παίζει σε καμία 14.04 (ανεξαρτήτως γραφικού περιβάλλοντος), αν είναι πρόβλημα του πυρήνα. Το μήνυμα που σου έχει βγάλει όμως είναι επειδή δεν έχεις κλείσει τον X server. Αυτό το καταφέρνεις μέσω του Display Manager. Ακόμη και μετά από μια επιτυχημένη εγκατάσταση μπορεί να σπάσει το γραφικό περιβάλλον και να χρειαστεί να δουλέψεις μέσα από κονσόλα.
Αν δεν γνωρίζεις πως να επαναφέρεις το γραφικό περιβάλλον, τότε καλύτερα μην προχωρήσεις στην εγκατάσταση του οδηγού μέσω του αρχείου .run. Είναι καθαρά beta ο οδηγός, (όπως και η έκδοση Ubuntu είναι Alpha).
Δημοσίευσηαπό asvos » 09 Φεβ 2014, 19:32
Thanks! :)
NetBook
Ubuntu 19.04
asvos
Δημοσίευσηαπό fkol k4 » 09 Φεβ 2014, 19:34
Έχω την εντύπωση πως διάβασα στο Phoronix πως δεν υπάρχει ακόμη υποστήριξη για τον 3.13, οπότε για την 14.04 μάλλον δεν μπαίνει.
Για κάποια άλλη διανομή που δεν έχει περάσει ακόμη σε 3.13, μπορεί να μην υπάρχει πρόβλημα.
Δημοσίευσηαπό Learner » 09 Φεβ 2014, 19:43
fkol k4 έγραψε:Έχω την εντύπωση πως διάβασα στο Phoronix πως δεν υπάρχει ακόμη υποστήριξη για τον 3.13, οπότε για την 14.04 μάλλον δεν μπαίνει.
Μάλλον κάτι τέτοιο παίζει. Θα περιμένουμε(νω) μέχρι να το διορθώσουν.
Ο nouveau σου δουλεύει σωστά μετά τις τελευταίες αναβαθμίσεις ; Σε μένα δεν δούλεψε. Δεν φορτωνόταν ακόμη και με εγγραφή στο /etc/modules. Χειροκίνητα μπορούσα να τον φορτώσω (με modprobe), αλλά δεν υπήρχε καμία διαφορά στην ανάλυση. Vesa 1024χ768.
Αν είναι τελικά να κάνω debugging , θα κάνω στον nouveau μάλλον. Στον nvidia και να ήξερα, δεν θα μπορούσα λόγω του κλειστού κώδικα ;)
Δημοσίευσηαπό fkol k4 » 09 Φεβ 2014, 19:52
Learner έγραψε:Ο nouveau σου δουλεύει σωστά μετά τις τελευταίες αναβαθμίσεις ;
Εννοείς για την 14.04 μετά την αναβάθμιση σε 3.13 υποθέτω, σωστά;
Καλά δουλεύει, αν εξαιρέσουμε πως έσπασε τις ρυθμίσεις του desktop και αναγκαστικά επανέφερα το Unity στις προεπιλεγμένες ρυθμίσεις.
Μετά, έκανα ξανά τις ρυθμίσεις και τώρα είναι εντάξει.
Επιστροφή στο Ubuntu +1
