lsusb:
******@******-laptop:~$
lsusbBus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 5986:0102 Acer, Inc Crystal Eye webcam
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 062a:0000 Creative Labs Optical mouse
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmseg:
] usb 1-2: new low speed USB device using ohci_hcd and addre
bash: [: missing `]'
george@george-laptop:~$ [ 2.772130] usbcore: registered new device driver usbbash: [: missing `]'
[ 5.376031] ata2: SATA link down (SStatus 0 SControl
george@george-laptop:~$ [ 2.772432] No dock devices found.
[ 5.383506] usb 1-2: configuration
george@george-laptop:~$ [ 2.789826] SCSI subsystem initialized
[ 5.710144] ata3: SATA link down (SSta
george@george-laptop:~$ [ 2.848753] libata version 3.00 loaded.
[ 6.110145] ata4: SATA link down (SStat
george@george-laptop:~$ [ 2.851364] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
[ 6.110874] scsi 0:0:0:0: Direct-Access ATA Hitachi HTS54251 BBCO PQ:
george@george-laptop:~$ [ 2.851852] ACPI: PCI Interrupt Link [LMAC] enabled at
[ 6.111644] ACPI: PCI Interrupt Link [LNK1] enabled at
george@george-laptop:~$ [ 2.851864] forcedeth 0000:00:0a.0: PCI INT A -> Link[LMA
[ 6.111657] ohci1394 0000:01:04.0: PCI INT A -> Link[LNK1
george@george-laptop:~$ [ 2.851870] forcedeth 0000:00:0a.0: setting latency timer
[ 6.163387] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[
george@george-laptop:~$ [ 2.862487] ohci_hcd: 2006 August 04 USB 1.1 '
[ 6.171727] pata_acpi 0000:00:06.0: setting la
> [ 3.431084] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x732 @ 1,
> [ 3.431090] forcedeth 0000:00:0a.0: high
> [ 3.431963] ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 22
[ 6.176094] pata_amd 0000:00:06.0: version 0.3.10
[ 6.176148] pata_amd 0000:00:06.0: setting latency timer to 64
[ 6.177121] scsi4 : pata_amd
[ 6.177244] scsi5 : pata_a> [ 3.431976] ohci_hcd 0000:00:02.0: PCI INT A ->
md
[ 6.177741] ata5: PATA max UDMA/133 cmd 0x1f0 > [ 3.431992] ohci_hcd 0000:00:02.0: setti
> [ 3.431996] ohci_hcd 0000:00:02.0: OHCI Host Con
> [ 3.432060] ohci_hcd 0000:00:02.0: new USB b
ctl 0x3f6 bmdma 0x30c0 irq 14
[ 6.177745] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x30c8 irq 15
[ 6.203246] scsi 0:0:0:0: Attach> [ 3.432090] ohci_hcd 0000:00:02.0: irq 22, io mem
ed scsi generic sg0 type 0
[ 6.238103] Driver 'sd'> [ 3.486176] usb usb1: configuration #1 chosen from 1
> [ 3.486208] hub 1-0:1.0: USB hub found
needs updating - please use bus_type methods
[ 6.238232] sd 0:0:0:0: [sda] 312581808 512-byte h> [ 3.486219] hub 1-0:1.0: 5 ports detected
ardware sectors (160042 MB)
[ 6.238253] sd> [ 3.693415] ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 21
0:0:0:0: [sda] Write Protect is off
[ 6.238256] sd 0:0:0:0: [> [ 3.693428] ehci_hcd 0000:00:02.1: PCI INT B -> Link[LUS2] -> GSI 21 (le
sda] Mode Sense: 00 3a 00 00
[ 6.238291] sd 0:0:0:0: [sda] Write cache: e> [ 3.693443] ehci_hcd 0000:00:02.1: setting latency ti
> [ 3.693447] ehci_hcd 0000:00:02.1: EHCI Host Controll
nabled, read cache: enabled, doesn't support DPO or FUA
[ 6.238376] sd 0:0:0:0: [sda] 312581808 512-byte hardwa> [ 3.693496] ehci_hcd 0000:00:02.1: new USB bus
[ 6.238394] sd 0:0:0:0: [> [ 3.693524] ehci_hcd 0000:00:02.1: debug port 1
[ 6.238397] sd 0:0:0:0> [ 3.693529] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
: [sda] Mode Sense: 00 3a 00 00
[ 6.238431] sd 0:0:0:0: [sda] Write cache:> [ 3.693548] ehci_hcd 0000:00:02.1: irq 21, io mem 0xd0889000
enabled, read cache: enabled, doesn't support DPO or FUA
[ 6> [ 3.910148] usb 1-2: new low speed USB device using ohci_hcd and address 2
> [ 3.921025] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2
.238435] sda:<6>usbcore: registered new interface driver hiddev
[ 6.262151] sda1 sda2 sda3 sda4 <<6>input: HID 062a:0000 as /devices/pci0000:00/0000:00:02.> [ 3.921188] usb usb2: configuration #1 chosen from 1 choice
> [ 3.921219] hub 2-0:1.0: USB hub found
> [ 3.921230] hub 2-0:1.0: 5 ports detected
> [ 3.976037] hub 1-0:1.0: unable to enumerate USB device on port 2
> [ 4.129576] ACPI: PCI Interrupt Link [Z00N] enabled at IRQ 20
> [ 4.129591] ohci_hcd 0000:00:04.0: PCI INT A -> Link[Z00N] -> GSI 20
> [ 4.129605] ohci_hcd 0000:00:04.0: setting latency timer to 64
> [ 4.129609] ohci_hcd 0000:00:04.0
0/usb1/1-2/1-2:1.0/input/input2
[ 6.265192] input,hidraw0: USB HID v1.10 Mouse [HID 062a:0000] on usb-0000:00:02.0-2
[ 6.265217] usbcore: registered new interface driver usbhid
[ 6.265221] usbhid: v2.6:USB HID core driver
[ 6.277375] sda5 sda6 >
[ 6.290599] sd 0:0:0:0: [sda] Attached SCSI disk
[ 6.340308] ata5.00: ATAPI: HL-DT-ST DVDRAM GSA-T20N, WP03, max UDMA/33
[ 6.340324] ata5: nv_mode_filter: 0x739f&0x701f->0x701f, BIOS=0x7000 (> [ ber 3658] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus num
0xc000c700) ACPI=0x701f (60:600:0x13)
[ 6.356318] ata5.00: configured for UDMA/33> [ 4.129686] ohci_hcd 0000:00:04.0: irq 20, io mem 0xd0887000
[ 6.356356] ata6: port disabled. ignoring.
[ 6.359926] sc> [ 4.186172] usb usb3: configuration #1 chosen from 1 choice
si 4:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T20N WP03 PQ
> [ 4.186204] hub 3-0:1.0: USB hub found
[ 6.360108] scsi 4:0:0:0: Attached scs
> [ 4.186217] hub 3-0:1.0: 5 ports detected
[ 6.391107] Driver 'sr' needs updating -
> [ 4.288770] ACPI: PCI Interrupt Link [Z00O] enabled at IRQ 23
[ 6.401968] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/r
> [ 4.288777] ehci_hcd 0000:00:04.1: PCI INT B -> Link[Z00O] -> GSI 23 (level, low) -> IRQ 23
[ 6.401974] Uniform CD-ROM driver Revision: 3.20
[ 6.402086] sr 4:0:0:0: Attached scsi C> [ 4.288791] ehci_hcd 0000:00:04.1: setting latency timer
D-ROM sr0
[ 6.851023] PM: Starting manual resume from disk> [ 4.288795] ehci_hcd 0000:00:04.1: EHCI Host Control
[ 6.851029] PM: Resume from partition 8:6
[ 6.851> [ 4.288824] ehci_hcd 0000:00:04.1: new USB bus regis
031] PM: Checking hibernation image.
[ 6.851238] PM: > [ 4.288853] ehci_hcd 0000:00:04.1: debug port 1
Resume from disk failed.
[ 7.451163] ieee1394: H> [ 4.288858] ehci_hcd 0000:00:04.1: cache
> [ 4.288876] ehci_hcd 0000:00:04.1: irq 23,
ost added: ID:BUS[0-00:1023] GUID[00023f81ba405d66]
[ 12.576313] udevd version 124 star> [ 4.401027] usb 2-3: new high speed USB
ted
[ 13.239143] input: Power Button (FF) > [ 4.412021] ehci_hcd 0000:00:04.
as /devices/LNXSYSTM:00/LNXPWRBN:00/
> [ 4.412185] usb usb4: configuration #1
> [ 4.412219] hub 4-0:1.0: USB
> [ 4.412229] hub 4-0:1.0: 5 ports dete
> [ 4.516349] ahci 0000:00:09.0: vers
[ 13.248044] ACPI: Power Button (FF) [PWRF]
[ 13.248188] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input4
[ 13.262321] AC> [ 4.516808] ACPI: PCI Interrupt Link [LSI0] enabled at IRQ 22
PI: Lid Switch [LID]
[ 13.262418] input: Sleep Button (CM) as /> [ 4.516813] ahci 0000:00:09.0: PCI INT A -> Link
devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input
> [ 4.516911] ahci 0000:00:09.0: AHCI 0001.0
[ 13.289023] ACPI: Sleep Button (CM) [SLPB]
> [ 4.516915] ahci 0000:00:09.0: flags: 64bit sntf le
[ 13.289213] input: Power Button (CM) as /devices/LN
> [ 4.516919] ahci 0000:00:09.0: setting latency ti
[ 13.321036] ACPI: Power Button (CM) [PWRB]
[ 13> [ 4.517319] scsi0 : ahci
.601974] ACPI: WMI: Mapper l
> [ 4.517462] scsi1 : ahci
> [ 4.517551] scsi2 : ahci
> [ 4.517633] scsi3 : ahci
> [ 4.517744] ata1: SATA max UDMA/133 abar m8
> [ 4.517748] ata2: SATA max UDMA/133 abar
> [ 4.517751] ata3: SATA max UDMA/133 abar m8192@0xd0884
> [ 4.517754] ata4: SATA max UDMA/133 abar
> [ 4.827404] usb 2-3: configuration #1 ch
> [ 5.036040] ata1: SATA link up 1.5 Gbps (SSta
> [ 5.036972] ata1.00: ATA-8: Hitachi HTS542516K9SA00, BBCOC31
> [ 5.036976] ata1.00: 312581808 sectors, mult
> [ 5.038093] ata1.00: configured for UDMA/133
> [ 5.180033] usb 1-2: new low speed USB device using ohci_hcd and addre
[ 13.881866] ACPI: AC Adapter [ACAD] (off-line)
[ 14.144049] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 21
[ 14.144058] HDA Intel 0000:00:07.0: PCI INT A -> Link[LAZA] -> GSI 21 (level, low) -> IRQ 21
[ 14.144082] HDA Intel 0000:00:07.0: setting latency timer to 64
[ 14.290430] ricoh-mmc: Ricoh MMC Controller disabling driver
[ 14.290435] ricoh-mmc: Copyright(c) Philip Langdale
[ 14.291417] ricoh-mmc: Ricoh MMC controller found at 0000:01:04.2 [1180:0843] (rev 12)
[ 14.291464] ricoh-mmc: Controller is now disabled.
[ 14.369387] sdhci: Secure Digital Host Controller Interface driver
[ 14.369391] sdhci: Copyright(c) Pierre Ossman
[> [ 5.383506] usb 1-2: configuration
14.379353] sdhci-pci 0000:01:04.1:
[ 14.379953] ACPI: PCI Interrupt Link [
> [ 6.177244] scsi5 : pata_amd
> [ 6.177741] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x30c0 irq 14
> [ 6.203246] scsi 0:0:0:0: Attached scsi generic sg0 type 0
> [ 6.238103] Driver 'sd' needs updating - please use bus_type methods
> [ 6.238232] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
> [ 6.238253] sd 0:0:0:0: [sda] Write Protect is off
[ 14.379959] sdhci-pci 0000:01:04.1: PCI INT B -> Link[LNK2] -> GSI 11 (level, low) -> IRQ 11
[ 14.383021] mmc0: SDHCI controller on PCI [0000:01:04.1] using PIO
[ 14.519313] Linux video capture interface: v2.00
[ 14.541484] ACPI: Battery Slot [BAT1] (battery present)
[ 14.550390] uvcvideo: Found UVC 1.00 device Acer Crystal Eye webcam (5986:0102)
[ 14.637547] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 14.652409] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.841913] input: Acer Crystal Eye webcam as /devices/pci0000:00/0000:00:02.1/usb2/2-3/2-3:1.0/input/input7
[ 14.864894] input: PC Speaker as /devices/platform/pcspkr/input/input8
[ 14.890555] Linux agpgart interface v0.103
[ 14.909344] usbcore: registered new interface driver uvcvideo
[ 14.909350] USB Video Class driver (v0.1.0)
[ 15.132519] ath_hal: module license 'Proprietary' taints kernel.
[ 15.134827] AR5210, AR5211, AR5212, AR5416, RF5111> [ 6.238256] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
> [ 6.238291] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
, RF5112, RF2413, RF5413, RF2133, RF2425, RF2417)
[ 15.798560] ACPI: PCI Interrupt Link [LGPU] enabled at IRQ 17
[ 15.798574] nvidia 0000:00:12.0: PCI INT Ageorge@george-laptop:~$ [ 6.2383ware sectors (160042 MB)2581808 512-byte hard
-> Link[LGPU] -> GSI 17 (level, low) -> IRQ 17
[ 15.798582] nvidia 0000:00:12.bash: syntax error near unexpected token `('
george@george-laptop:~$ [ 6.238394] sd 0:0:0:0: [sda] Write Protect is off
[ 15.798846] NVRM: lobash: [: missing `]'
george@george-laptop:~$ [ 6.238397] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00ading NVIDIA UNIX x86 Kernel Module 177.80 Wed Oct 1 1
george@george-laptop:~$ [ 6.238431] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 15.928191] acer-wmi: Acer Laptop ACPI-WMI Extras
[ 15.960540] ACPI: PCI Interrupt Link [LK4E] en> [ 6.238435] sda:<6>usbcore: registered new interface driver hiddev
abled at IRQ 19
[ 15.960554] ath_pci 0000:05:00.0: PCI INT A -> Link[> [ 6.262151] sda1 sd00:00/0000:00:02.0/usb1/1-2/1-2:1.0/input/input2s/pci00
LK4E] -> GSI 19 (level, low) -> IRQ 19
[ 15.960564] ath_pci 0000:05:00.0: setting latency timer to 64
[ 16.449821] MadWifi:> [ 6.265192] input,hidraw0: USB HID v1.10 Mouse [HID 00:02.0-2] on usb-0000:
ath_attach: Switching rfkill capability off.
[ 16.532835] wifi0: Atheros AR2425 chip > [ 6.265217] usbcore: registered new interface driver usbhid
found (MAC 14.2, PHY SChip 7.0, Radio 10.2)
[ 16.551440] ath_pci: wifi0: Atheros 5424/2424: mem=0xd0400000, i> [ 6.277375] sda5 sda6 >
rq=19
[ 17.090194] input: > [ 6.290599] sd 0:0:0:0: [sda] Attached SCSI disk
PS/2 Mouse as /devices/platform/i8042/serio1/input/i
> [ 6.340324] ata5: nv_mode_filter: 0x739f&0x701f->0x701f, BIOS=0x7000 (0xc000c700) ACPI=0x701f (60:600:0x13)
> [ 6.359926] scsi 4:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T20N WP03 PQ
[ 17.147274] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input10
[ 17.650729] lp: driver loaded but no devices found
[ 17.858613] Adding 1365484k swap on /dev/sda6. Priority:-1 extents:1 across:1365484k
[ 19.624323] type=1505 audit(1225746741.166:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" n> [ 6.360108] scsi 4:0:0:0: Attached scs
ame2="default" pid=4392
[ 19.836322] type=1505 audit(1225746741.378:3): operation="pr> [ 6.401968] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/r
ofile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=4397
[ 19.836569] type=1505 audit(1225746741.> [ 6.402086] sr 4:0:0:0: Attached scsi CD-ROM sr0
378:4): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=4397
[ 19.990156] ip_table> [ 6.851029] PM: Resume from partition 8:6
s: (C) 2000-2006 Netfilter Core Team
[ 20.9> [ 6.851031] PM: Checking hibernation image.
77833] powernow-k8: Found 1 AMD Athlon(tm) 64 X
> [ 6.851238] PM: Resume from disk failed.
[ 20.978498] powernow-k8: 0 : fid 0xb
> [ 7.451163] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00023f81ba405d66]
[ 20.978503] powernow-k8: 1 : fid 0xa (1800 MHz), vid 0x13
[ 20.978506]> [ 12.576313] udevd version 124 started
powernow-k8: 2 : fid 0x8 (1600 MHz),
> [ 13.239143] input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/
[ 20.978509] powernow-k8: 3 : fid 0x0 (800 MHz), vid 0x1a
[ 21.657768> [ 13.248044] ACPI: Power Button (FF) [PWRF]
> [ 13.262321] ACPI: Lid Switch [LID]
] warning: `avahi-daemon' uses 32-bit capabilities (legacy support in use)
[ 21.762849] apm: BIOS not found.
[ 21.914857] ppdev: user-space parallel port driver
[ 22.911> [ 13.262418] input: Sleep Button (CM) as /devices/LNXSYSTM:00/deviC0E:00/input/input
021] NET: Registered protocol family 10
[ 22.911573] lo: Disabled Privacy Extensions
[ 23.501037] Clocksource tsc unstable (delta = -179432> [ 13.289213] input: Power Button (CM) as /devices/LN
417 ns)
[ 26.217215] Bluetooth: Core ver 2.13
[ 26.> [ 13.321036] ACPI: Power Button (CM) [PWRB]
> [ 13.601974] ACPI: WMI: Mapper l
221199] NET: Registered protocol family 31
[ 26.221217] Bluetooth: HCI device a> [ 13.881866] ACPI: AC Adapter [ACAD] (off-line)
> [ 14.379353] sdhci-pci 0000:01:04.1:
> [ 15.134827] AR5210, AR5211, AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2133, RF2425, RF2417)
> [ 15.798574] nvidia 0000:00:12.0: PCI INT A -> Link[LGPU] -> GSI 17 (level, low) -> IRQ 17
> [ 15.798582] nvidia 0000:00:12.0: setting latency timer to 64
> [ 15.798846] NVRM: loading NVIDIA UNIX x86 Kernel Module 177.80 Wed Oct 1 1
> [ 15.960540] ACPI: PCI Interrupt Link [LK4E] enabled at IRQ 19
> [ 15.960554] ath_pci 0000:05:00.0: PCI INT A -> Link[LK4E] -> GSI 19 (level, low) -> IRQ 19
> [ 16.449821] MadWifi: ath_attach: Switching rfkill capability off.
> [ 16.532835] wifi0: Atheros AR2425 chip found (MAC 14.2, PHY SChip 7.0, Radio 10.2)
> [ 16.551440] ath_pci: wifi0: Atheros 5424/2424: mem=0xd0400000, irq=19
> [ 17.090194] input: PS/2 Mouse as /devices/platform/i8042/serio1/input/i
> [ 19.624323] type=1505 audit(1225746741.166:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" name2="default" pid=4392
> [ 19.836322] type=1505 audit(1225746741.378:3): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=4397
> [ 19.836569] type=1505 audit(1225746741.378:4): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=4397
> [ 19.990156] ip_tables: (C) 2000-2006 Netfilter Core Team
> [ 20.977833] powernow-k8: Found 1 AMD Athlon(tm) 64 X
> [ 20.978506] powernow-k8: 2 : fid 0x8 (1600 MHz),
> [ 21.657768] warning: `avahi-daemon' uses 32-bit capabilities (legacy support in use)
/usr/sbin/cupsd"
[ 140.637991] type=1503 audit(1225746862.182:10): operation="socket_create" family="ipx" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
[ 140.638008] type=1503 audit(1225746862.182:11): operation="socket_create" family="appletalk" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
[ 140.638026] type=1503 audit(1225746862.182:12): operation="socket_create" family="econet" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
[ 140.638044] type=1503 audit(1225746862.182:13): operation="socket_create" family="ash" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
[ 140.638061] type=1503 audit(1225746862.182:14): operation="socket_create" family="x25" sock_type="seqpacket" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ george@george-laptop:~$ [ 21.762849] apm: BIOS not found.
george@george-laptop:~$ [ 21.914857] ppdev: user-space parallel port driver
george@george-laptop:~$ [ 22.911021] NET: Registered protocol family 10
george@george-laptop:~$ [ 22.911573] lo: Disabled Privacy Extensions
george@george-laptop:~$ [ 23.501037] Clocksource tsc unstable (delta = -179432417 ns)
george@george-laptop:~$ [ 26.217215] Bluetooth: Core ver 2.13
george@george-laptop:~$ [ 26.221199] NET: Registered protocol family 31
george@george-laptop:~$ [ 26.221217] Bluetooth: HCI device and connection manager initialized
george@george-laptop:~$ [ 26.221228] Bluetooth: HCI socket layer initialized
george@george-laptop:~$ [ 26.253374] Bluetooth: L2CAP ver 2.11
george@george-laptop:~$ [ 26.253401] Bluetooth: L2CAP socket layer initializedbash: [: missing `]'
george@george-laptop:~$ [ 26.278079] Bluetooth: SCO (Voice Link) ver 0.6
george@george-laptop:~$ [ 26.278108] Bluetooth: SCO socket layer initialized
george@george-laptop:~$ [ 26.328771] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
george@george-laptop:~$ [ 26.328792] Bluetooth: BNEP filters: protocol multicast
george@george-laptop:~$ [ 26.343066] Bluetooth: RFCOMM socket layer initialized
george@george-laptop:~$ [ 26.343112] Bluetooth: RFCOMM TTY layer initialized
george@george-laptop:~$ [ 26.343118] Bluetooth: RFCOMM ver 1.10
george@george-laptop:~$ [ 26.398896] Bridge firewalling registered
george@george-laptop:~$ [ 26.399359] pan0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
george@george-laptop:~$ [ 30.537010] eth0: no link during initialization.
george@george-laptop:~$ [ 30.538373] ADDRCONF(NETDEV_UP): eth0: link is not ready
george@george-laptop:~$ [ 30.656234] NET: Registered protocol family 17
george@george-laptop:~$ [ 41.374682] ath0: no IPv6 routers present
george@george-laptop:~$ [ 71.623283] CPU0 attaching NULL sched-domain.
george@george-laptop:~$ [ 71.623328] CPU1 attaching NULL sched-domain.
george@george-laptop:~$ [ 71.635507] CPU0 attaching sched-domain:
george@george-laptop:~$ [ 71.635527] domain 0: span 0-1 level CPU
george@george-laptop:~$ [ 71.635536] groups: 0 1
george@george-laptop:~$ [ 71.635554] CPU1 attaching sched-domain:
george@george-laptop:~$ [ 71.635559] domain 0: span 0-1 level CPU
george@george-laptop:~$ [ 71.635565] groups: 1 0
george@george-laptop:~$ [ 139.590215] type=1503 audit(1225746861.133:5): operation="inode_permission" requested_mask="r::" denied_mask="r::" fsuid=7 name="/proc/6135/net/" pid=6135 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.637833] type=1503 audit(1225746862.182:6): operation="inode_permission" requested_mask="r::" denied_mask="r::" fsuid=7 name="/proc/6139/net/" pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.637938] type=1503 audit(1225746862.182:7): operation="socket_create" family="ax25" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.637956] type=1503 audit(1225746862.182:8): operation="socket_create" family="netrom" sock_type="seqpacket" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.637973] type=1503 audit(1225746862.182:9): operation="socket_create" family="rose" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.637991] type=1503 audit(1225746862.182:10): operation="socket_create" family="ipx" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.638008] type=1503 audit(1225746862.182:11): operation="socket_create" family="appletalk" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.638026] type=1503 audit(1225746862.182:12): operation="socket_create" family="econet" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.638044] type=1503 audit(1225746862.182:13): operation="socket_create" family="ash" sock_type="dgram" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
george@george-laptop:~$ [ 140.638061] type=1503 audit(1225746862.182:14): operation="socket_create" family="x25" sock_type="seqpacket" protocol=0 pid=6139 profile="/usr/sbin/cupsd"
