χαιρετώ σας
έκανα επανεκκίνηση πολλές φορές ...
το αποτέλεσμα είναι το παρακάτω:
[ 0.712320] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.712723] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.712950] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.713002] TCP reno registered
[ 0.720069] NET: Registered protocol family 1
[ 0.720223] checking if image is initramfs... it is
[ 1.400684] Freeing initrd memory: 7929k freed
[ 1.400902] Simple Boot Flag at 0x79 set to 0x1
[ 1.401862] audit: initializing netlink socket (disabled)
[ 1.401931] type=2000 audit(1226240523.400:1): initialized
[ 1.407833] highmem bounce pool size: 64 pages
[ 1.407884] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.410233] VFS: Disk quotas dquot_6.5.1
[ 1.410364] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.410507] msgmni has been set to 1743
[ 1.410666] io scheduler noop registered
[ 1.410713] io scheduler anticipatory registered
[ 1.410761] io scheduler deadline registered
[ 1.410817] io scheduler cfq registered (default)
[ 1.410876] pci 0000:00:02.0: Boot video device
[ 1.411144] pcieport-driver 0000:00:1c.0: setting latency timer to 64
[ 1.411197] pcieport-driver 0000:00:1c.0: found MSI capability
[ 1.411297] pci_express 0000:00:1c.0:pcie00: allocate port service
[ 1.411336] pci_express 0000:00:1c.0:pcie02: allocate port service
[ 1.411373] pci_express 0000:00:1c.0:pcie03: allocate port service
[ 1.411489] pcieport-driver 0000:00:1c.1: setting latency timer to 64
[ 1.411540] pcieport-driver 0000:00:1c.1: found MSI capability
[ 1.411638] pci_express 0000:00:1c.1:pcie00: allocate port service
[ 1.411679] pci_express 0000:00:1c.1:pcie02: allocate port service
[ 1.411717] pci_express 0000:00:1c.1:pcie03: allocate port service
[ 1.411828] pcieport-driver 0000:00:1c.3: setting latency timer to 64
[ 1.411879] pcieport-driver 0000:00:1c.3: found MSI capability
[ 1.411977] pci_express 0000:00:1c.3:pcie00: allocate port service
[ 1.412021] pci_express 0000:00:1c.3:pcie02: allocate port service
[ 1.412063] pci_express 0000:00:1c.3:pcie03: allocate port service
[ 1.412178] pcieport-driver 0000:00:1c.5: setting latency timer to 64
[ 1.412230] pcieport-driver 0000:00:1c.5: found MSI capability
[ 1.412327] pci_express 0000:00:1c.5:pcie00: allocate port service
[ 1.412369] pci_express 0000:00:1c.5:pcie02: allocate port service
[ 1.412408] pci_express 0000:00:1c.5:pcie03: allocate port service
[ 1.412765] isapnp: Scanning for PnP cards...
[ 1.766804] isapnp: No Plug & Play device found
[ 1.798741] hpet_resources: 0xfed00000 is busy
[ 1.798851] Serial: 8250/16550 driver4 ports, IRQ sharing enabled
[ 1.801115] brd: module loaded
[ 1.801230] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 1.801408] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.804804] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.804857] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.809105] mice: PS/2 mouse device common for all mice
[ 1.809273] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.809352] rtc0: alarms up to one month, y3k, hpet irqs
[ 1.809530] EISA: Probing bus 0 at eisa.0
[ 1.809627] EISA: Mainboard Y__FFFF detected.
[ 1.809715] Cannot allocate resource for EISA slot 1
[ 1.809794] EISA: Detected 0 cards.
[ 1.809841] cpuidle: using governor ladder
[ 1.809892] cpuidle: using governor menu
[ 1.810442] TCP cubic registered
[ 1.810512] Using IPI No-Shortcut mode
[ 1.810725] registered taskstats version 1
[ 1.810923] Magic number: 0:15:384
[ 1.811076] rtc_cmos 00:03: setting system clock to 2008-11-09 14:22:04 UTC (1226240524)
[ 1.811138] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.811849] EDD information not available.
[ 1.812093] Freeing unused kernel memory: 424k freed
[ 1.812176] Write protecting the kernel text: 2576k
[ 1.812247] Write protecting the kernel read-only data: 936k
[ 1.812982] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 1.898660] fuse init (API version 7.9)
[ 1.920775] ACPI: SSDT 7F66E4F2, 0286 (r1 PmRef Cpu0Ist 3000 INTL 20050624)
[ 1.921291] ACPI: SSDT 7F66DE88, 05E5 (r1 PmRef Cpu0Cst 3001 INTL 20050624)
[ 1.921812] Monitor-Mwait will be used to enter C-1 state
[ 1.921815] Monitor-Mwait will be used to enter C-2 state
[ 1.921818] Monitor-Mwait will be used to enter C-3 state
[ 1.922000] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 1.922226] processor ACPI0007:00: registered as cooling_device0
[ 1.922278] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 1.922719] ACPI: SSDT 7F66E778, 00C4 (r1 PmRef Cpu1Ist 3000 INTL 20050624)
[ 1.923182] ACPI: SSDT 7F66E46D, 0085 (r1 PmRef Cpu1Cst 3000 INTL 20050624)
[ 1.923942] ACPI: CPU1 (power states: C1[C1]Marking TSC unstable due to TSC halts in idle
[ 1.924078] C2[C2] C3[C3])
[ 1.924252] processor ACPI0007:01: registered as cooling_device1
[ 1.924306] ACPI: Processor [CPU1] (supports 8 throttling states)
[ 1.930893] thermal LNXTHERM:01: registered as thermal_zone0
[ 1.934972] ACPI: Thermal Zone [THM] (57 C)
[ 2.193239] usbcore: registered new interface driver usbfs
[ 2.193313] usbcore: registered new interface driver hub
[ 2.193411] usbcore: registered new device driver usb
[ 2.203522] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 2.203592] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 2.203596] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.203687] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.207672] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.207725] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[ 2.207737] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfed1c400
[ 2.211702] USB Universal Host Controller Interface driver v3.0
[ 2.221023] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.221213] usb usb1: configuration #1 chosen from 1 choice
[ 2.221288] hub 1-0:1.0: USB hub found
[ 2.221340] hub 1-0:1.0: 4 ports detected
[ 2.323300] No dock devices found.
[ 2.345483] SCSI subsystem initialized
[ 2.362394] libata version 3.00 loaded.
[ 2.429484] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.429551] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 2.429555] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.429630] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 2.429731] uhci_hcd 0000:00:1a.0: irq 20, io base 0x00006f20
[ 2.429878] usb usb2: configuration #1 chosen from 1 choice
[ 2.429952] hub 2-0:1.0: USB hub found
[ 2.430005] hub 2-0:1.0: 2 ports detected
[ 2.636551] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 2.636613] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 2.636617] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 2.636706] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 3
[ 2.636800] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00006f00
[ 2.636938] usb usb3: configuration #1 chosen from 1 choice
[ 2.637013] hub 3-0:1.0: USB hub found
[ 2.637083] hub 3-0:1.0: 2 ports detected
[ 2.740747] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.740811] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.740815] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.740897] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
[ 2.744857] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.744908] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 2.744914] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xfed1c000
[ 2.748053] usb 2-2: new full speed USB device using uhci_hcd and address 2
[ 2.760242] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.760414] usb usb4: configuration #1 chosen from 1 choice
[ 2.760486] hub 4-0:1.0: USB hub found
[ 2.760536] hub 4-0:1.0: 6 ports detected
[ 2.933100] usb 2-2: configuration #1 chosen from 1 choice
[ 2.935072] hub 2-2:1.0: USB hub found
[ 2.936865] hub 2-2:1.0: 3 ports detected
[ 2.968747] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.968802] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.968806] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.969012] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 2.969116] uhci_hcd 0000:00:1d.0: irq 20, io base 0x00006f80
[ 2.969389] usb usb5: configuration #1 chosen from 1 choice
[ 2.969609] hub 5-0:1.0: USB hub found
[ 2.969658] hub 5-0:1.0: 2 ports detected
[ 3.001193] Clocksource tsc unstable (delta = -334446268 ns)
[ 3.176771] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 3.176828] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.176832] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.177057] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 3.177143] uhci_hcd 0000:00:1d.1: irq 21, io base 0x00006f60
[ 3.177442] usb usb6: configuration #1 chosen from 1 choice
[ 3.177519] hub 6-0:1.0: USB hub found
[ 3.177569] hub 6-0:1.0: 2 ports detected
[ 3.280783] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 22 (level, low) -> IRQ 22
[ 3.280840] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.280844] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.280917] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 3.281001] uhci_hcd 0000:00:1d.2: irq 22, io base 0x00006f40
[ 3.281143] usb usb7: configuration #1 chosen from 1 choice
[ 3.281217] hub 7-0:1.0: USB hub found
[ 3.281266] hub 7-0:1.0: 2 ports detected
[ 3.432146] usb 4-6: new high speed USB device using ehci_hcd and address 4
[ 3.489291] ahci 0000:00:1f.2: version 3.0
[ 3.489305] ahci 0000:00:1f.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 3.489467] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x5 impl SATA mode
[ 3.489527] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems
[ 3.489590] ahci 0000:00:1f.2: setting latency timer to 64
[ 3.490296] scsi0 : ahci
[ 3.490455] scsi1 : ahci
[ 3.490574] scsi2 : ahci
[ 3.490912] ata1: SATA max UDMA/133 abar m2048@0xfe9fb800 port 0xfe9fb900 irq 219
[ 3.490972] ata2: DUMMY
[ 3.491016] ata3: SATA max UDMA/133 abar m2048@0xfe9fb800 port 0xfe9fba00 irq 219
[ 3.569323] usb 4-6: configuration #1 chosen from 1 choice
[ 3.649863] usb 2-2.1: new full speed USB device using uhci_hcd and address 3
[ 3.776000] usb 2-2.1: configuration #1 chosen from 1 choice
[ 3.853863] usb 2-2.2: new full speed USB device using uhci_hcd and address 4
[ 3.983955] usb 2-2.2: configuration #1 chosen from 1 choice
[ 4.032137] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.061860] usb 2-2.3: new full speed USB device using uhci_hcd and address 5
[ 4.191971] usb 2-2.3: configuration #1 chosen from 1 choice
[ 4.400471] ata1.00: ATA-8: TOSHIBA MK2546GSX, LB013D, max UDMA/100
[ 4.400526] ata1.00: 488397168 sectors, multi 8: LBA48 NCQ (depth 31/32)
[ 4.401536] ata1.00: configured for UDMA/100
[ 4.432138] usb 5-2: new low speed USB device using uhci_hcd and address 2
[ 4.612569] usb 5-2: configuration #1 chosen from 1 choice
[ 4.728109] usb 7-1: new full speed USB device using uhci_hcd and address 2
[ 4.736133] ata3: SATA link down (SStatus 0 SControl 300)
[ 4.752246] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK2546GS LB01 PQ: 0 ANSI: 5
[ 4.752548] b43-pci-bridge 0000:0c:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 4.752631] b43-pci-bridge 0000:0c:00.0: setting latency timer to 64
[ 4.812145] ssb: Sonics Silicon Backplane found on PCI device 0000:0c:00.0
[ 4.812248] tg3.c:v3.94 (August 14, 2008)
[ 4.812317] tg3 0000:09:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 4.812378] tg3 0000:09:00.0: setting latency timer to 64
[ 4.905490] usb 7-1: configuration #1 chosen from 1 choice
[ 4.909871] usbcore: registered new interface driver hiddev
[ 4.913090] input: Broadcom Corp as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2.2/2-2.2:1.0/input/input2
[ 4.917165] input,hidraw0: USB HID v1.11 Keyboard [Broadcom Corp] on usb-0000:00:1a.0-2.2
[ 4.921230] input: Broadcom Corp as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2.3/2-2.3:1.0/input/input3
[ 4.921512] input,hidraw1: USB HID v1.11 Mouse [Broadcom Corp] on usb-0000:00:1a.0-2.3
[ 4.972868] input: Microsoft Microsoft Wireless Optical Mouse� 1.00 as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.0/input/input4
[ 4.973156] input,hidraw2: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Mouse� 1.00] on usb-0000:00:1d.0-2
[ 4.973352] usbcore: registered new interface driver usbhid
[ 4.973399] usbhid: v2.6:USB HID core driver
[ 5.109693] eth0: Tigon3 [partno(BCM95906) rev c002 PHY(5906)] (PCI Express) 10/100Base-TX Ethernet 00:1d:09:3e:e2:27
[ 5.109762] eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] WireSpeed[0] TSOcap[0]
[ 5.109822] eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 5.109904] ohci1394 0000:03:01.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 5.162678] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[19] MMIO=[fe4ff800-fe4fffff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 5.170968] ata_piix 0000:00:1f.1: version 2.12
[ 5.170979] ata_piix 0000:00:1f.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 5.171073] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 5.171948] scsi3 : ata_piix
[ 5.172081] scsi4 : ata_piix
[ 5.172907] ata4: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x6fa0 irq 14
[ 5.172960] ata5: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x6fa8 irq 15
[ 5.178804] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.193677] Driver 'sd' needs updating - please use bus_type methods
[ 5.193836] sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB)
[ 5.193909] sd 0:0:0:0: [sda] Write Protect is off
[ 5.193956] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.194002] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.194143] sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB)
[ 5.194216] sd 0:0:0:0: [sda] Write Protect is off
[ 5.194917] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.194963] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.195025] sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
[ 5.327878] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.340727] ata4.00: ATAPI: MATSHITA DVD+/-RW UJ-857G, Z111, max UDMA/33
[ 5.356612] ata4.00: configured for UDMA/33
[ 5.356731] ata5: port disabled. ignoring.
[ 5.358483] scsi 3:0:0:0: CD-ROM MATSHITA DVD+-RW UJ-857G Z111 PQ: 0 ANSI: 5
[ 5.358694] scsi 3:0:0:0: Attached scsi generic sg1 type 5
[ 5.385043] Driver 'sr' needs updating - please use bus_type methods
[ 5.391191] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda caddy
[ 5.391248] Uniform CD-ROM driver Revision: 3.20
[ 5.391391] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 5.852610] PM: Starting manual resume from disk
[ 5.852659] PM: Resume from partition 8:7
[ 5.852660] PM: Checking hibernation image.
[ 5.852832] PM: Resume from disk failed.
[ 5.903821] kjournald starting. Commit interval 5 seconds
[ 5.903881] EXT3-fs: mounted filesystem with ordered data mode.
[ 6.436430] ieee1394: Host added: ID:BUS[0-00:1023] GUID[434fc00030e54c70]
[ 13.580732] udevd version 124 started
[ 13.854771] Linux agpgart interface v0.103
[ 13.965526] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 14.016103] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.037568] agpgart-intel 0000:00:00.0: Intel 965GM Chipset
[ 14.038085] agpgart-intel 0000:00:00.0: detected 7676K stolen memory
[ 14.050744] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 14.083729] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input5
[ 14.084431] ACPI: Lid Switch [LID]
[ 14.085568] input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input6
[ 14.113061] ACPI: Power Button (CM) [PBTN]
[ 14.113187] input: Sleep Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input7
[ 14.141029] ACPI: Sleep Button (CM) [SBTN]
[ 14.154816] ACPI: AC Adapter [AC] (on-line)
[ 14.235141] ACPI: Battery Slot [BAT0] (battery present)
[ 14.281993] ACPI: WMI: Mapper loaded
[ 14.568221] acpi device:32: registered as cooling_device2
[ 14.569403] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:2e/device:2f/input/input8
[ 14.592037] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 14.606945] acpi device:37: registered as cooling_device3
[ 14.607497] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:34/input/input9
[ 14.628026] ACPI: Video Device [VID1] (multi-head: yes rom: no post: no)
[ 14.628256] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:39/input/input10
[ 14.652238] ieee80211_crypt: registered algorithm 'NULL'
[ 14.657736] wl: module license 'MIXED/Proprietary' taints kernel.
[ 14.660039] ACPI: Video Device [VID2] (multi-head: yes rom: no post: no)
[ 14.919140] Bluetooth: Core ver 2.13
[ 14.948735] NET: Registered protocol family 31
[ 14.948789] Bluetooth: HCI device and connection manager initialized
[ 14.948839] Bluetooth: HCI socket layer initialized
[ 14.993096] Bluetooth: Generic Bluetooth USB driver ver 0.3
[ 14.993784] usbcore: registered new interface driver btusb
[ 15.102771] iTCO_vendor_support: vendor-support=0
[ 15.186880] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[ 15.190390] iTCO_wdt: Found a ICH8M TCO device (Version=2, TCOBASE=0x1060)
[ 15.190527] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 15.391218] ricoh-mmc: Ricoh MMC Controller disabling driver
[ 15.391270] ricoh-mmc: Copyright(c) Philip Langdale
[ 15.391976] ricoh-mmc: Ricoh MMC controller found at 0000:03:01.2 [1180:0843] (rev 12)
[ 15.392075] ricoh-mmc: Controller is now disabled.
[ 15.413842] sdhci: Secure Digital Host Controller Interface driver
[ 15.413898] sdhci: Copyright(c) Pierre Ossman
[ 15.417716] sdhci-pci 0000:03:01.1: SDHCI controller found [1180:0822] (rev 22)
[ 15.417804] sdhci-pci 0000:03:01.1: PCI INT B -> GSI 18 (level, low) -> IRQ 18
[ 15.420999] mmc0: SDHCI controller on PCI [0000:03:01.1] using DMA
[ 15.485466] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 15.614493] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 15.614588] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 15.617242] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 15.639462] Linux video capture interface: v2.00
[ 15.657319] b43-phy0: Broadcom 4311 WLAN found
[ 15.725663] phy0: Selected rate control algorithm 'pid'
[ 15.749862] uvcvideo: Found UVC 1.00 device Laptop Integrated Webcam (05a9:2640)
[ 15.750276] uvcvideo: Failed to query (135) UVC control 1 (unit 0) : -32 (exp. 26).
[ 15.807548] input: Laptop Integrated Webcam as /devices/pci0000:00/0000:00:1d.7/usb4/4-6/4-6:1.0/input/input12
[ 15.820230] usbcore: registered new interface driver uvcvideo
[ 15.820297] USB Video Class driver (v0.1.0)
[ 15.939816] Broadcom 43xx driver loaded [ Features: PLR, Firmware-ID: FW13 ]
[ 16.231808] Synaptics Touchpad, model: 1, fw: 6.3, id: 0x1c0b1, caps: 0xa04753/0x200000
[ 16.267124] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input13
[ 16.750128] NET: Registered protocol family 10
[ 16.750674] lo: Disabled Privacy Extensions
[ 17.564712] lp: driver loaded but no devices found
[ 17.901195] Adding 2473968k swap on /dev/sda7. Priority:-1 extents:1 across:2473968k
[ 18.382604] EXT3 FS on sda5, internal journal
[ 19.323642] kjournald starting. Commit interval 5 seconds
[ 19.323830] EXT3 FS on sda6, internal journal
[ 19.323838] EXT3-fs: mounted filesystem with ordered data mode.
[ 20.027378] type=1505 audit(1226233342.680:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" name2="default" pid=4527
[ 20.192046] type=1505 audit(1226233342.844:3): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=4532
[ 20.192231] type=1505 audit(1226233342.848:4): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=4532
[ 20.386763] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 60.891341] warning: `avahi-daemon' uses 32-bit capabilities (legacy support in use)
[ 61.137278] apm: BIOS not found.
[ 61.334341] ppdev: user-space parallel port driver
[ 64.429414] Bluetooth: L2CAP ver 2.11
[ 64.429429] Bluetooth: L2CAP socket layer initialized
[ 64.512745] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 64.512758] Bluetooth: BNEP filters: protocol multicast
[ 64.596491] Bridge firewalling registered
[ 64.610030] pan0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
[ 64.611851] Bluetooth: RFCOMM socket layer initialized
[ 64.611876] Bluetooth: RFCOMM TTY layer initialized
[ 64.611882] Bluetooth: RFCOMM ver 1.10
[ 64.650144] Bluetooth: SCO (Voice Link) ver 0.6
[ 64.650158] Bluetooth: SCO socket layer initialized
[ 68.010929] [drm] Initialized drm 1.1.0 20060810
[ 68.015642] pci 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 68.015652] pci 0000:00:02.0: setting latency timer to 64
[ 68.016397] [drm] Initialized i915 1.6.0 20060119 on minor 0
[ 68.901687] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 68.981251] input: b43-phy0 as /devices/virtual/input/input14
[ 69.073221] firmware: requesting b43/ucode5.fw
[ 69.157346] firmware: requesting b43/pcm5.fw
[ 69.161024] firmware: requesting b43/b0g0initvals5.fw
[ 69.178865] firmware: requesting b43/b0g0bsinitvals5.fw
[ 69.297086] b43-phy0: Loading firmware version 351.126 (2006-07-29 05:54:02)
[ 69.297097] b43-phy0 warning: You are using an old firmware image. Support for old firmware will be removed in July 2008.
[ 69.297103] b43-phy0 warning: You must go to
http://linuxwireless.org/en/users/Drive ... cefirmware and download the latest firmware (version 4).
[ 69.465147] Registered led device: b43-phy0::tx
[ 69.466195] Registered led device: b43-phy0::rx
[ 69.466242] Registered led device: b43-phy0::radio
[ 69.501605] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 69.669240] NET: Registered protocol family 17
[ 70.555526] tg3: eth0: Link is up at 100 Mbps, full duplex.
[ 70.555540] tg3: eth0: Flow control is on for TX and on for RX.
[ 70.556635] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 80.648117] eth0: no IPv6 routers present
[ 126.249615] wlan0: authenticate with AP 00:1c:f0:e3:28:36
[ 126.251619] wlan0: authenticated
[ 126.251634] wlan0: associate with AP 00:1c:f0:e3:28:36
[ 126.258840] wlan0: RX AssocResp from 00:1c:f0:e3:28:36 (capab=0x471 status=0 aid=1)
[ 126.258859] wlan0: associated
[ 126.263342] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 136.680094] wlan0: no IPv6 routers present
[ 221.984206] usb 4-1: new high speed USB device using ehci_hcd and address 5
[ 222.118541] usb 4-1: configuration #1 chosen from 1 choice
[ 222.293055] usbcore: registered new interface driver libusual
[ 222.318843] Initializing USB Mass Storage driver...
[ 222.319551] scsi5 : SCSI emulation for USB Mass Storage devices
[ 222.320228] usbcore: registered new interface driver usb-storage
[ 222.320243] USB Mass Storage support registered.
[ 222.321294] usb-storage: device found at 5
[ 222.321306] usb-storage: waiting for device to settle before scanning
[ 227.320484] usb-storage: device scan complete
[ 227.321611] scsi 5:0:0:0: Direct-Access Intuix U3 6.15 PQ: 0 ANSI: 0 CCS
[ 227.322082] scsi 5:0:0:1: CD-ROM Intuix U3 6.15 PQ: 0 ANSI: 0
[ 227.326546] sd 5:0:0:0: [sdb] 1994751 512-byte hardware sectors (1021 MB)
[ 227.327050] sd 5:0:0:0: [sdb] Write Protect is off
[ 227.327057] sd 5:0:0:0: [sdb] Mode Sense: 45 00 00 08
[ 227.327063] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 227.328674] sd 5:0:0:0: [sdb] 1994751 512-byte hardware sectors (1021 MB)
[ 227.329170] sd 5:0:0:0: [sdb] Write Protect is off
[ 227.329177] sd 5:0:0:0: [sdb] Mode Sense: 45 00 00 08
[ 227.329182] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 227.329191] sdb:
[ 227.330462] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 227.330683] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 227.334574] sr1: scsi3-mmc drive: 8x/40x writer xa/form2 cdda tray
[ 227.334755] sr 5:0:0:1: Attached scsi CD-ROM sr1
[ 227.334932] sr 5:0:0:1: Attached scsi generic sg3 type 5
[ 2376.607342] tg3: eth0: Link is down.
[ 7929.344054] CE: hpet increasing min_delta_ns to 15000 nsec
[16597.085166] CE: hpet increasing min_delta_ns to 22500 nsec
[19315.306534] usb 4-1: USB disconnect, address 5
[19324.116129] usb 4-1: new high speed USB device using ehci_hcd and address 6
[19324.718486] usb 4-1: configuration #1 chosen from 1 choice
[19324.733901] scsi6 : SCSI emulation for USB Mass Storage devices
[19324.743481] usb-storage: device found at 6
[19324.743495] usb-storage: waiting for device to settle before scanning
[19329.740511] usb-storage: device scan complete
[19329.741856] scsi 6:0:0:0: Direct-Access Lexar JD FireFly 1100 PQ: 0 ANSI: 0 CCS
[19329.744081] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[19329.745342] sd 6:0:0:0: [sdb] Write Protect is off
[19329.745350] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[19329.745353] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[19329.758407] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[19329.759713] sd 6:0:0:0: [sdb] Write Protect is off
[19329.759723] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[19329.759726] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[19329.759733] sdb: sdb1
[19329.761484] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[19329.761606] sd 6:0:0:0: Attached scsi generic sg2 type 0
[22647.440758] usb 4-1: USB disconnect, address 6
[22650.445084] usb 4-1: new high speed USB device using ehci_hcd and address 7
[22650.967622] usb 4-1: configuration #1 chosen from 1 choice
[22650.980423] scsi7 : SCSI emulation for USB Mass Storage devices
[22650.983159] usb-storage: device found at 7
[22650.983170] usb-storage: waiting for device to settle before scanning
[22655.981576] usb-storage: device scan complete
[22655.983060] scsi 7:0:0:0: Direct-Access Lexar JD FireFly 1100 PQ: 0 ANSI: 0 CCS
[22655.985890] sd 7:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[22655.987280] sd 7:0:0:0: [sdb] Write Protect is off
[22655.987289] sd 7:0:0:0: [sdb] Mode Sense: 43 00 00 00
[22655.987294] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[22655.990649] sd 7:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[22655.992022] sd 7:0:0:0: [sdb] Write Protect is off
[22655.992031] sd 7:0:0:0: [sdb] Mode Sense: 43 00 00 00
[22655.992035] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[22655.995617] sdb: sdb1
[22655.997517] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[22655.998937] sd 7:0:0:0: Attached scsi generic sg2 type 0
[27105.208710] usb 4-1: USB disconnect, address 7
[27204.361057] usb 4-1: new high speed USB device using ehci_hcd and address 8
[27204.962110] usb 4-1: configuration #1 chosen from 1 choice
[27204.966148] scsi8 : SCSI emulation for USB Mass Storage devices
[27204.967996] usb-storage: device found at 8
[27204.968030] usb-storage: waiting for device to settle before scanning
[27209.964630] usb-storage: device scan complete
[27209.965812] scsi 8:0:0:0: Direct-Access Lexar JD FireFly 1100 PQ: 0 ANSI: 0 CCS
[27209.971749] sd 8:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[27209.972854] sd 8:0:0:0: [sdb] Write Protect is off
[27209.972868] sd 8:0:0:0: [sdb] Mode Sense: 43 00 00 00
[27209.972874] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[27209.975487] sd 8:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB)
[27209.976609] sd 8:0:0:0: [sdb] Write Protect is off
[27209.976616] sd 8:0:0:0: [sdb] Mode Sense: 43 00 00 00
[27209.976621] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[27209.976630] sdb: sdb1
[27209.977844] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[27209.978072] sd 8:0:0:0: Attached scsi generic sg2 type 0
vasilis@vasilis-laptop:~$
1 Γνώσεις Linux: Ικανοποιητικό ┃ Προγραμματισμού: Καθόλου ┃ Αγγλικών: Πρώτα βήματα
2 Ubuntu 12.04 precise 32bit (el_GR.UTF-8), Ubuntu 3.2.0-23-generic-pae
3 Intel Core2 Duo CPU T7250 2.00GHz ‖ RAM 2003 MiB ‖ Dell Inc. 0N6705 - Dell Inc. XPS M1330
4 Intel Mobile GM965/GL960 Integrated Graphics Controller (primary) [8086:2a02] (rev 0c)
5 eth0: Broadcom NetLink BCM5906M Fast Ethernet PCI Express [14e4:1713] (rev 02)
