Σπάνια το χρησιμοποιώ, αλλά καλό είναι να δουλεύει, έστω τουλάχιστον όπως στην αρχή. Το θέμα δεν με απασχολούσε μέχρι χθες που χρειάστηκε να μεταφέρω το λάπτοπ & ξέχασα να πάρω μαζί μου το ποντίκι!
synclient
~$ synclient
Couldn't find synaptics properties. No synaptics driver loaded?
xinput list
~$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) id=9 [slave pointer (2)]
⎜ ↳ MCE IR Keyboard/Mouse (ite-cir) id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ ITE8709 CIR transceiver id=12 [slave keyboard (3)]
dmesg
cat /var/log/Xorg.0.log
ls /etc/X11
~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.5.0-37-generic (buildd@allspice) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #58~precise1-Ubuntu SMP Wed Jul 10 17:48:11 UTC 2013 (Ubuntu 3.5.0-37.58~precise1-generic 3.5.7.16)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-37-generic root=UUID=9eea859f-c227-40ef-a480-748bfa7890a2 ro quiet splash vt.handoff=7
[ 0.000000] AMD AuthenticAMD
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009b7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009b800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007fecffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007fed0000-0x000000007fedbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007fedc000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed14000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: FUJITSU SIEMENS AMILO Xi 2428/F40 , BIOS 1.07C 10/23/2007
[ 0.000000] e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] No AGP bridge found
[ 0.000000] e820: last_pfn = 0x7fed0 max_arch_pfn = 0x400000000
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 2GB, type WB
[ 0.000000] reg 1, base: 2047MB, range: 1MB, type UC
[ 0.000000] total RAM covered: 2047M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 2M num_reg: 2 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] found SMP MP-table at [mem 0x000f8030-0x000f803f] mapped at [ffff8800000f8030]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x1fffffff]
[ 0.000000] Base memory trampoline at [ffff880000095000] 95000 size 24576
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x7fecffff]
[ 0.000000] [mem 0x00000000-0x7fdfffff] page 2M
[ 0.000000] [mem 0x7fe00000-0x7fecffff] page 4k
[ 0.000000] kernel direct mapping tables up to 0x7fecffff @ [mem 0x1fffc000-0x1fffffff]
[ 0.000000] RAMDISK: [mem 0x36204000-0x370f9fff]
[ 0.000000] ACPI: RSDP 00000000000f8000 00024 (v02 PTLTD )
[ 0.000000] ACPI: XSDT 000000007fed2507 0007C (v01 FSC PC 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 000000007fed8c6c 000F4 (v03 INTEL CRESTLNE 06040000 ALAN 00000001)
[ 0.000000] ACPI: DSDT 000000007fed3ae2 05116 (v02 ECS F40 06040000 INTL 20050624)
[ 0.000000] ACPI: FACS 000000007fedbfc0 00040
[ 0.000000] ACPI: HPET 000000007fed8d60 00038 (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: MCFG 000000007fed8d98 0003C (v01 INTEL CRESTLNE 06040000 LOHR 0000005A)
[ 0.000000] ACPI: TMOR 000000007fed8dd4 00026 (v01 PTLTD 06040000 PTL 00000003)
[ 0.000000] ACPI: APIC 000000007fed8dfa 00068 (v01 PTLTD ? APIC 06040000 LTP 00000000)
[ 0.000000] ACPI: BOOT 000000007fed8e62 00028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] ACPI: SLIC 000000007fed8e8a 00176 (v01 FSC PC 06040000 LTP 00000000)
[ 0.000000] ACPI: SSDT 000000007fed3805 002DD (v01 SataRe SataAhci 00001000 INTL 20050624)
[ 0.000000] ACPI: SSDT 000000007fed2b0f 0025F (v01 PmRef Cpu0Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 000000007fed2a69 000A6 (v01 PmRef Cpu1Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 000000007fed2583 004E6 (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000007fecffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x7fecffff]
[ 0.000000] NODE_DATA [mem 0x7fecc000-0x7fecffff]
[ 0.000000] [ffffea0000000000-ffffea0001ffffff] PMD -> [ffff88007d600000-ffff88007f5fffff] on node 0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00010000-0x00ffffff]
[ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00010000-0x0009afff]
[ 0.000000] node 0: [mem 0x00100000-0x7fecffff]
[ 0.000000] On node 0 totalpages: 523867
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 6 pages reserved
[ 0.000000] DMA zone: 3909 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 8124 pages used for memmap
[ 0.000000] DMA32 zone: 511764 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009b000 - 000000000009c000
[ 0.000000] PM: Registered nosave memory: 000000000009c000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff88007fc00000 s83584 r8192 d22912 u1048576
[ 0.000000] pcpu-alloc: s83584 r8192 d22912 u1048576 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 515673
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-37-generic root=UUID=9eea859f-c227-40ef-a480-748bfa7890a2 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] Checking aperture...
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 2031288k/2095936k available (6824k kernel code, 468k absent, 64180k reserved, 6344k data, 948k init)
[ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:16640 nr_irqs:512 16
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] allocated 8388608 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2394.166 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4788.33 BogoMIPS (lpj=9576664)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004034] Security Framework initialized
[ 0.004052] AppArmor: AppArmor initialized
[ 0.004053] Yama: becoming mindful.
[ 0.004252] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.005361] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.005893] Mount-cache hash table entries: 256
[ 0.006123] Initializing cgroup subsys cpuacct
[ 0.006127] Initializing cgroup subsys memory
[ 0.006137] Initializing cgroup subsys devices
[ 0.006139] Initializing cgroup subsys freezer
[ 0.006141] Initializing cgroup subsys blkio
[ 0.006142] Initializing cgroup subsys perf_event
[ 0.006173] CPU: Physical Processor ID: 0
[ 0.006174] CPU: Processor Core ID: 0
[ 0.006177] mce: CPU supports 6 MCE banks
[ 0.006184] CPU0: Thermal monitoring enabled (TM2)
[ 0.006188] using mwait in idle threads.
[ 0.009514] ACPI: Core revision 20120320
[ 0.014037] ftrace: allocating 27630 entries in 108 pages
[ 0.020491] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.062860] CPU0: Intel(R) Core(TM)2 Duo CPU T7700 @ 2.40GHz stepping 0a
[ 0.064003] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.064003] PEBS disabled due to CPU errata.
[ 0.064003] ... version: 2
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 2
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 000000007fffffff
[ 0.064003] ... fixed-purpose events: 3
[ 0.064003] ... event mask: 0000000700000003
[ 0.064003] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.064003] Booting Node 0, Processors #1 Ok.
[ 0.072079] Brought up 2 CPUs
[ 0.072084] Total of 2 processors activated (9576.66 BogoMIPS).
[ 0.073907] devtmpfs: initialized
[ 0.073907] EVM: security.selinux
[ 0.073907] EVM: security.SMACK64
[ 0.073907] EVM: security.capability
[ 0.076026] PM: Registering ACPI NVS region [mem 0x7fed0000-0x7fedbfff] (49152 bytes)
[ 0.076727] dummy:
[ 0.076762] RTC time: 15:04:24, date: 07/31/13
[ 0.076798] NET: Registered protocol family 16
[ 0.076836] Trying to unpack rootfs image as initramfs...
[ 0.076981] ACPI: bus type pci registered
[ 0.077038] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.077040] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.093124] PCI: Using configuration type 1 for base access
[ 0.094161] bio: create slab <bio-0> at 0
[ 0.094271] ACPI: Added _OSI(Module Device)
[ 0.094274] ACPI: Added _OSI(Processor Device)
[ 0.094275] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.094277] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.095373] ACPI: EC: Look up EC in DSDT
[ 0.097206] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.097900] ACPI: SSDT 000000007fed33ff 0033E (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.098163] ACPI: Dynamic OEM Table Load:
[ 0.098166] ACPI: SSDT (null) 0033E (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.098270] ACPI: SSDT 000000007fed2d6e 0060C (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.098518] ACPI: Dynamic OEM Table Load:
[ 0.098521] ACPI: SSDT (null) 0060C (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.098703] ACPI: SSDT 000000007fed373d 000C8 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 0.098963] ACPI: Dynamic OEM Table Load:
[ 0.098966] ACPI: SSDT (null) 000C8 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 0.099035] ACPI: SSDT 000000007fed337a 00085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 0.099285] ACPI: Dynamic OEM Table Load:
[ 0.099288] ACPI: SSDT (null) 00085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 0.176075] ACPI: Interpreter enabled
[ 0.176084] ACPI: (supports S0 S3 S4 S5)
[ 0.176111] ACPI: Using IOAPIC for interrupt routing
[ 0.220077] ACPI: EC: GPE = 0x11, I/O: command/status = 0x66, data = 0x62
[ 0.220239] ACPI: No dock devices found.
[ 0.220244] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.220505] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.220972] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.220975] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.220978] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.220981] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff] (ignored)
[ 0.220983] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff] (ignored)
[ 0.220986] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff] (ignored)
[ 0.220988] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff] (ignored)
[ 0.220991] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
[ 0.220994] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfebfffff] (ignored)
[ 0.220996] PCI: root bus 00: using default resources
[ 0.221028] PCI host bridge to bus 0000:00
[ 0.221031] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.221033] pci_bus 0000:00: root bus resource [mem 0x00000000-0xfffffffff]
[ 0.221045] pci 0000:00:00.0: [8086:2a00] type 00 class 0x060000
[ 0.221098] pci 0000:00:01.0: [8086:2a01] type 01 class 0x060400
[ 0.221144] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.221201] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.221260] pci 0000:00:1a.0: reg 20: [io 0x1800-0x181f]
[ 0.221305] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.221362] pci 0000:00:1a.1: reg 20: [io 0x1820-0x183f]
[ 0.221422] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.221449] pci 0000:00:1a.7: reg 10: [mem 0xf0704800-0xf0704bff]
[ 0.221563] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.221599] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.221621] pci 0000:00:1b.0: reg 10: [mem 0xf0700000-0xf0703fff 64bit]
[ 0.221730] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.221765] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.221879] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.221916] pci 0000:00:1c.1: [8086:2841] type 01 class 0x060400
[ 0.222032] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.222068] pci 0000:00:1c.2: [8086:2843] type 01 class 0x060400
[ 0.222182] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.222218] pci 0000:00:1c.3: [8086:2845] type 01 class 0x060400
[ 0.222333] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.222370] pci 0000:00:1c.4: [8086:2847] type 01 class 0x060400
[ 0.222486] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.222521] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.222579] pci 0000:00:1d.0: reg 20: [io 0x1840-0x185f]
[ 0.222625] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.222683] pci 0000:00:1d.1: reg 20: [io 0x1860-0x187f]
[ 0.222728] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[ 0.222788] pci 0000:00:1d.2: reg 20: [io 0x1880-0x189f]
[ 0.222848] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.222873] pci 0000:00:1d.7: reg 10: [mem 0xf0704c00-0xf0704fff]
[ 0.222988] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.223017] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.223118] pci 0000:00:1f.0: [8086:2815] type 00 class 0x060100
[ 0.223228] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.223234] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH6 GPIO
[ 0.223238] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0068 (mask 0007)
[ 0.223243] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0260 (mask 0007)
[ 0.223302] pci 0000:00:1f.1: [8086:2850] type 00 class 0x01018a
[ 0.223320] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.223332] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.223344] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.223357] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.223369] pci 0000:00:1f.1: reg 20: [io 0x18a0-0x18af]
[ 0.223425] pci 0000:00:1f.2: [8086:2829] type 00 class 0x010601
[ 0.223454] pci 0000:00:1f.2: reg 10: [io 0x18d8-0x18df]
[ 0.223466] pci 0000:00:1f.2: reg 14: [io 0x18cc-0x18cf]
[ 0.223479] pci 0000:00:1f.2: reg 18: [io 0x18d0-0x18d7]
[ 0.223491] pci 0000:00:1f.2: reg 1c: [io 0x18c8-0x18cb]
[ 0.223503] pci 0000:00:1f.2: reg 20: [io 0x18e0-0x18ff]
[ 0.223515] pci 0000:00:1f.2: reg 24: [mem 0xf0704000-0xf07047ff]
[ 0.223584] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.223609] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[ 0.223626] pci 0000:00:1f.3: reg 10: [mem 0x00000000-0x000000ff]
[ 0.223670] pci 0000:00:1f.3: reg 20: [io 0x1c00-0x1c1f]
[ 0.223764] pci 0000:01:00.0: [10de:0425] type 00 class 0x030000
[ 0.223784] pci 0000:01:00.0: reg 10: [mem 0xce000000-0xceffffff]
[ 0.223806] pci 0000:01:00.0: reg 14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.223828] pci 0000:01:00.0: reg 1c: [mem 0xcc000000-0xcdffffff 64bit]
[ 0.223842] pci 0000:01:00.0: reg 24: [io 0x2000-0x207f]
[ 0.223856] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.223964] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.223968] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.223972] pci 0000:00:01.0: bridge window [mem 0xcc000000-0xceffffff]
[ 0.223977] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.224070] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.224076] pci 0000:00:1c.0: bridge window [io 0xf000-0xffff]
[ 0.224081] pci 0000:00:1c.0: bridge window [mem 0xfb000000-0xfcffffff]
[ 0.224177] pci 0000:04:00.0: [8086:444e] type 00 class 0x058000
[ 0.224201] pci 0000:04:00.0: reg 10: [mem 0xf0300000-0xf03003ff]
[ 0.224234] pci 0000:04:00.0: reg 18: [io 0x3000-0x307f]
[ 0.224297] pci 0000:04:00.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 0.232040] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.232048] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
[ 0.232053] pci 0000:00:1c.1: bridge window [mem 0xf0300000-0xf03fffff]
[ 0.232160] pci 0000:05:00.0: [8086:4229] type 00 class 0x028000
[ 0.232203] pci 0000:05:00.0: reg 10: [mem 0xf0200000-0xf0201fff 64bit]
[ 0.232414] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 0.240044] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.240054] pci 0000:00:1c.2: bridge window [mem 0xf0200000-0xf02fffff]
[ 0.240159] pci 0000:06:00.0: [10ec:8168] type 00 class 0x020000
[ 0.240184] pci 0000:06:00.0: reg 10: [io 0x4000-0x40ff]
[ 0.240226] pci 0000:06:00.0: reg 18: [mem 0xf0500000-0xf0500fff 64bit]
[ 0.240274] pci 0000:06:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.240386] pci 0000:06:00.0: supports D1 D2
[ 0.240388] pci 0000:06:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.240423] pci 0000:06:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.240436] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.240441] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.240446] pci 0000:00:1c.3: bridge window [mem 0xf0500000-0xf05fffff]
[ 0.240543] pci 0000:07:00.0: [1095:3531] type 00 class 0x018000
[ 0.240577] pci 0000:07:00.0: reg 10: [mem 0xf0402000-0xf040207f 64bit]
[ 0.240604] pci 0000:07:00.0: reg 18: [mem 0xf0400000-0xf0401fff 64bit]
[ 0.240622] pci 0000:07:00.0: reg 20: [io 0x5000-0x507f]
[ 0.240737] pci 0000:07:00.0: supports D1 D2
[ 0.248039] pci 0000:00:1c.4: PCI bridge to [bus 07-07]
[ 0.248046] pci 0000:00:1c.4: bridge window [io 0x5000-0x5fff]
[ 0.248051] pci 0000:00:1c.4: bridge window [mem 0xf0400000-0xf04fffff]
[ 0.248113] pci 0000:08:04.0: [1217:00f7] type 00 class 0x0c0010
[ 0.248136] pci 0000:08:04.0: reg 10: [mem 0xf0600000-0xf0600fff]
[ 0.248149] pci 0000:08:04.0: reg 14: [mem 0xf0602000-0xf06027ff]
[ 0.248242] pci 0000:08:04.0: supports D1 D2
[ 0.248245] pci 0000:08:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.248314] pci 0000:00:1e.0: PCI bridge to [bus 08-08] (subtractive decode)
[ 0.248322] pci 0000:00:1e.0: bridge window [mem 0xf0600000-0xf06fffff]
[ 0.248330] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.248333] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xfffffffff] (subtractive decode)
[ 0.248381] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.248530] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEGP._PRT]
[ 0.248573] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.248609] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.248645] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.248680] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.248716] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.248775] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.248818] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.248821] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.248823] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.253646] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.253694] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.253739] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 *7 10 12 14 15)
[ 0.253783] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.253828] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.253871] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.253915] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.253960] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.254079] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.254083] vgaarb: loaded
[ 0.254085] vgaarb: bridge control possible 0000:01:00.0
[ 0.254286] SCSI subsystem initialized
[ 0.254348] libata version 3.00 loaded.
[ 0.254372] ACPI: bus type usb registered
[ 0.254392] usbcore: registered new interface driver usbfs
[ 0.254401] usbcore: registered new interface driver hub
[ 0.254430] usbcore: registered new device driver usb
[ 0.254512] PCI: Using ACPI for IRQ routing
[ 0.265735] PCI: pci_cache_line_size set to 64 bytes
[ 0.265870] e820: reserve RAM buffer [mem 0x0009b800-0x0009ffff]
[ 0.265873] e820: reserve RAM buffer [mem 0x7fed0000-0x7fffffff]
[ 0.266010] NetLabel: Initializing
[ 0.266012] NetLabel: domain hash size = 128
[ 0.266013] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.266026] NetLabel: unlabeled traffic allowed by default
[ 0.266094] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.266100] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.266105] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.272077] Switching to clocksource hpet
[ 0.280453] AppArmor: AppArmor Filesystem Enabled
[ 0.280490] pnp: PnP ACPI init
[ 0.280507] ACPI: bus type pnp registered
[ 0.300332] pnp 00:00: [bus 00-ff]
[ 0.300338] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.300340] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.300343] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.300345] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.300347] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.300350] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.300352] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.300354] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.300356] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.300359] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.300361] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.300363] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.300366] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.300368] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.300370] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.300372] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.300375] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.300377] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 0.300379] pnp 00:00: [mem 0xf0000000-0xfebfffff window]
[ 0.300385] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[ 0.300491] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.300559] pnp 00:01: [mem 0xfed1c000-0xfed1ffff]
[ 0.300562] pnp 00:01: [mem 0xfed14000-0xfed17fff]
[ 0.300564] pnp 00:01: [mem 0xfed18000-0xfed18fff]
[ 0.300566] pnp 00:01: [mem 0xfed19000-0xfed19fff]
[ 0.300568] pnp 00:01: [mem 0xe0000000-0xefffffff]
[ 0.300570] pnp 00:01: [mem 0xfed20000-0xfed3ffff]
[ 0.300573] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.300575] pnp 00:01: [mem 0xfed45000-0xfed8ffff]
[ 0.300645] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.300648] system 00:01: [mem 0xfed14000-0xfed17fff] has been reserved
[ 0.300651] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.300653] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.300656] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.300659] system 00:01: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.300661] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.300664] system 00:01: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.300667] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.300866] pnp 00:02: [io 0x0068]
[ 0.300869] pnp 00:02: [io 0x006c]
[ 0.300871] pnp 00:02: [io 0x0260-0x0261]
[ 0.300888] pnp 00:02: [irq 10]
[ 0.300932] pnp 00:02: Plug and Play ACPI device, IDs ITE8709 (active)
[ 0.300943] pnp 00:03: [io 0x0000-0x001f]
[ 0.300945] pnp 00:03: [io 0x0081-0x0091]
[ 0.300947] pnp 00:03: [io 0x0093-0x009f]
[ 0.300949] pnp 00:03: [io 0x00c0-0x00df]
[ 0.300952] pnp 00:03: [dma 4]
[ 0.300991] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.301000] pnp 00:04: [mem 0xff000000-0xffffffff]
[ 0.301043] pnp 00:04: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.301105] pnp 00:05: [mem 0xfed00000-0xfed003ff]
[ 0.301166] system 00:05: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.301170] system 00:05: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.301180] pnp 00:06: [io 0x00f0]
[ 0.301187] pnp 00:06: [irq 13]
[ 0.301230] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.301241] pnp 00:07: [io 0x002e-0x002f]
[ 0.301243] pnp 00:07: [io 0x004e-0x004f]
[ 0.301246] pnp 00:07: [io 0x0061]
[ 0.301248] pnp 00:07: [io 0x0063]
[ 0.301250] pnp 00:07: [io 0x0065]
[ 0.301252] pnp 00:07: [io 0x0067]
[ 0.301254] pnp 00:07: [io 0x0080]
[ 0.301256] pnp 00:07: [io 0x0092]
[ 0.301258] pnp 00:07: [io 0x00b2-0x00b3]
[ 0.301260] pnp 00:07: [io 0x0680-0x069f]
[ 0.301262] pnp 00:07: [io 0x0800-0x080f]
[ 0.301264] pnp 00:07: [io 0x1000-0x107f]
[ 0.301266] pnp 00:07: [io 0x1180-0x11bf]
[ 0.301268] pnp 00:07: [io 0x1640-0x164f]
[ 0.301270] pnp 00:07: [io 0xfe00]
[ 0.301281] pnp 00:07: disabling [io 0xfe00] because it overlaps 0000:00:1c.0 BAR 13 [io 0xf000-0xffff]
[ 0.301351] system 00:07: [io 0x0680-0x069f] has been reserved
[ 0.301354] system 00:07: [io 0x0800-0x080f] has been reserved
[ 0.301357] system 00:07: [io 0x1000-0x107f] has been reserved
[ 0.301359] system 00:07: [io 0x1180-0x11bf] has been reserved
[ 0.301362] system 00:07: [io 0x1640-0x164f] has been reserved
[ 0.301365] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.301376] pnp 00:08: [io 0x0070-0x0077]
[ 0.301382] pnp 00:08: [irq 8]
[ 0.301423] pnp 00:08: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.301468] pnp 00:09: [io 0x0060]
[ 0.301470] pnp 00:09: [io 0x0064]
[ 0.301476] pnp 00:09: [irq 1]
[ 0.301523] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.301538] pnp 00:0a: [irq 12]
[ 0.301583] pnp 00:0a: Plug and Play ACPI device, IDs SYN0804 SYN0800 PNP0f13 (active)
[ 0.301604] pnp: PnP ACPI: found 11 devices
[ 0.301605] ACPI: ACPI bus type pnp unregistered
[ 0.307742] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-03] add_size 200000
[ 0.307756] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x001fffff pref] to [bus 04-04] add_size 200000
[ 0.307769] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000
[ 0.307772] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000
[ 0.307784] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x001fffff pref] to [bus 06-06] add_size 200000
[ 0.307797] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 07-07] add_size 200000
[ 0.307818] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.307821] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x001fffff pref] get_res_add_size add_size 200000
[ 0.307824] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.307826] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x001fffff pref] get_res_add_size add_size 200000
[ 0.307829] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.307832] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.307839] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 0.307842] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80200000-0x804fffff pref]
[ 0.307845] pci 0000:00:1c.2: BAR 15: assigned [mem 0x80500000-0x806fffff 64bit pref]
[ 0.307848] pci 0000:00:1c.3: BAR 15: assigned [mem 0x80700000-0x809fffff pref]
[ 0.307850] pci 0000:00:1c.4: BAR 15: assigned [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.307854] pci 0000:00:1c.2: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.307857] pci 0000:00:1f.3: BAR 0: assigned [mem 0x80c00000-0x80c000ff]
[ 0.307866] pci 0000:01:00.0: BAR 6: can't assign mem pref (size 0x20000)
[ 0.307869] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.307872] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
[ 0.307876] pci 0000:00:01.0: bridge window [mem 0xcc000000-0xceffffff]
[ 0.307879] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.307884] pci 0000:00:1c.0: PCI bridge to [bus 02-03]
[ 0.307888] pci 0000:00:1c.0: bridge window [io 0xf000-0xffff]
[ 0.307894] pci 0000:00:1c.0: bridge window [mem 0xfb000000-0xfcffffff]
[ 0.307899] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 0.307907] pci 0000:04:00.0: BAR 6: assigned [mem 0x80200000-0x8020ffff pref]
[ 0.307910] pci 0000:00:1c.1: PCI bridge to [bus 04-04]
[ 0.307913] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
[ 0.307920] pci 0000:00:1c.1: bridge window [mem 0xf0300000-0xf03fffff]
[ 0.307924] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x804fffff pref]
[ 0.307932] pci 0000:00:1c.2: PCI bridge to [bus 05-05]
[ 0.307936] pci 0000:00:1c.2: bridge window [io 0x6000-0x6fff]
[ 0.307942] pci 0000:00:1c.2: bridge window [mem 0xf0200000-0xf02fffff]
[ 0.307947] pci 0000:00:1c.2: bridge window [mem 0x80500000-0x806fffff 64bit pref]
[ 0.307955] pci 0000:06:00.0: BAR 6: assigned [mem 0x80700000-0x8071ffff pref]
[ 0.307957] pci 0000:00:1c.3: PCI bridge to [bus 06-06]
[ 0.307961] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.307967] pci 0000:00:1c.3: bridge window [mem 0xf0500000-0xf05fffff]
[ 0.307972] pci 0000:00:1c.3: bridge window [mem 0x80700000-0x809fffff pref]
[ 0.307979] pci 0000:00:1c.4: PCI bridge to [bus 07-07]
[ 0.307983] pci 0000:00:1c.4: bridge window [io 0x5000-0x5fff]
[ 0.307989] pci 0000:00:1c.4: bridge window [mem 0xf0400000-0xf04fffff]
[ 0.308012] pci 0000:00:1c.4: bridge window [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.308022] pci 0000:00:1e.0: PCI bridge to [bus 08-08]
[ 0.308028] pci 0000:00:1e.0: bridge window [mem 0xf0600000-0xf06fffff]
[ 0.308099] pci 0000:00:1e.0: setting latency timer to 64
[ 0.308104] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.308106] pci_bus 0000:00: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.308109] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.308111] pci_bus 0000:01: resource 1 [mem 0xcc000000-0xceffffff]
[ 0.308114] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.308116] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.308118] pci_bus 0000:02: resource 1 [mem 0xfb000000-0xfcffffff]
[ 0.308121] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 0.308123] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 0.308126] pci_bus 0000:04: resource 1 [mem 0xf0300000-0xf03fffff]
[ 0.308128] pci_bus 0000:04: resource 2 [mem 0x80200000-0x804fffff pref]
[ 0.308130] pci_bus 0000:05: resource 0 [io 0x6000-0x6fff]
[ 0.308133] pci_bus 0000:05: resource 1 [mem 0xf0200000-0xf02fffff]
[ 0.308135] pci_bus 0000:05: resource 2 [mem 0x80500000-0x806fffff 64bit pref]
[ 0.308137] pci_bus 0000:06: resource 0 [io 0x4000-0x4fff]
[ 0.308140] pci_bus 0000:06: resource 1 [mem 0xf0500000-0xf05fffff]
[ 0.308142] pci_bus 0000:06: resource 2 [mem 0x80700000-0x809fffff pref]
[ 0.308145] pci_bus 0000:07: resource 0 [io 0x5000-0x5fff]
[ 0.308147] pci_bus 0000:07: resource 1 [mem 0xf0400000-0xf04fffff]
[ 0.308149] pci_bus 0000:07: resource 2 [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.308152] pci_bus 0000:08: resource 1 [mem 0xf0600000-0xf06fffff]
[ 0.308154] pci_bus 0000:08: resource 4 [io 0x0000-0xffff]
[ 0.308156] pci_bus 0000:08: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.308196] NET: Registered protocol family 2
[ 0.308305] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.308951] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.311242] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.311847] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.311850] TCP: reno registered
[ 0.311860] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.311889] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.312030] NET: Registered protocol family 1
[ 0.312309] pci 0000:01:00.0: Boot video device
[ 0.312333] PCI: CLS 64 bytes, default 64
[ 0.312374] Simple Boot Flag at 0x36 set to 0x1
[ 0.312747] audit: initializing netlink socket (disabled)
[ 0.312758] type=2000 audit(1375283064.308:1): initialized
[ 0.334231] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.336024] VFS: Disk quotas dquot_6.5.2
[ 0.336069] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.336571] fuse init (API version 7.19)
[ 0.336645] msgmni has been set to 3967
[ 0.336965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.336991] io scheduler noop registered
[ 0.336993] io scheduler deadline registered (default)
[ 0.337021] io scheduler cfq registered
[ 0.337175] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 0.337281] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X
[ 0.337415] pcieport 0000:00:1c.1: irq 42 for MSI/MSI-X
[ 0.337544] pcieport 0000:00:1c.2: irq 43 for MSI/MSI-X
[ 0.337680] pcieport 0000:00:1c.3: irq 44 for MSI/MSI-X
[ 0.337810] pcieport 0000:00:1c.4: irq 45 for MSI/MSI-X
[ 0.337905] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.337922] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.337977] intel_idle: does not run on family 6 model 15
[ 0.338579] ACPI: AC Adapter [AC0] (on-line)
[ 0.338665] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.338681] ACPI: Lid Switch [LID0]
[ 0.338719] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.338723] ACPI: Power Button [PWRB]
[ 0.338763] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.338766] ACPI: Sleep Button [SLPB]
[ 0.338818] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.338820] ACPI: Power Button [PWRF]
[ 0.338894] ACPI: Requesting acpi_cpufreq
[ 0.347350] Freeing initrd memory: 15320k freed
[ 0.356755] Monitor-Mwait will be used to enter C-1 state
[ 0.356767] Monitor-Mwait will be used to enter C-3 state
[ 0.356771] Marking TSC unstable due to TSC halts in idle
[ 0.356784] ACPI: acpi_idle registered with cpuidle
[ 0.397494] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.397496] ACPI: Thermal Zone [THRM] (44 C)
[ 0.397515] ACPI: Battery Slot [BAT0] (battery absent)
[ 0.397550] GHES: HEST is not enabled!
[ 0.397643] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.399098] Linux agpgart interface v0.103
[ 0.400725] brd: module loaded
[ 0.401462] loop: module loaded
[ 0.401563] ata_piix 0000:00:1f.1: version 2.13
[ 0.401611] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.401900] scsi0 : ata_piix
[ 0.401978] scsi1 : ata_piix
[ 0.402291] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x18a0 irq 14
[ 0.402293] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x18a8 irq 15
[ 0.402573] Fixed MDIO Bus: probed
[ 0.402621] tun: Universal TUN/TAP device driver, 1.6
[ 0.402622] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.402775] PPP generic driver version 2.4.2
[ 0.402827] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.402858] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 0.402863] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 0.402870] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 0.402903] ehci_hcd 0000:00:1a.7: debug port 1
[ 0.406792] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 0.406809] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf0704800
[ 0.416022] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 0.416029] ACPI: Battery Slot [BAT0] (battery absent)
[ 0.416043] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.416046] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.416048] usb usb1: Product: EHCI Host Controller
[ 0.416050] usb usb1: Manufacturer: Linux 3.5.0-37-generic ehci_hcd
[ 0.416052] usb usb1: SerialNumber: 0000:00:1a.7
[ 0.416165] hub 1-0:1.0: USB hub found
[ 0.416169] hub 1-0:1.0: 4 ports detected
[ 0.416249] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.416253] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.416259] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 0.416287] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.420162] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 0.420178] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf0704c00
[ 0.432022] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.432057] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.432060] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.432062] usb usb2: Product: EHCI Host Controller
[ 0.432065] usb usb2: Manufacturer: Linux 3.5.0-37-generic ehci_hcd
[ 0.432067] usb usb2: SerialNumber: 0000:00:1d.7
[ 0.432171] hub 2-0:1.0: USB hub found
[ 0.432175] hub 2-0:1.0: 6 ports detected
[ 0.432247] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.432266] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.432287] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.432291] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 0.432296] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 0.432335] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
[ 0.432369] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.432372] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.432374] usb usb3: Product: UHCI Host Controller
[ 0.432376] usb usb3: Manufacturer: Linux 3.5.0-37-generic uhci_hcd
[ 0.432379] usb usb3: SerialNumber: 0000:00:1a.0
[ 0.432480] hub 3-0:1.0: USB hub found
[ 0.432485] hub 3-0:1.0: 2 ports detected
[ 0.432555] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 0.432559] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 0.432564] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 0.432599] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
[ 0.432632] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.432635] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.432637] usb usb4: Product: UHCI Host Controller
[ 0.432639] usb usb4: Manufacturer: Linux 3.5.0-37-generic uhci_hcd
[ 0.432641] usb usb4: SerialNumber: 0000:00:1a.1
[ 0.432737] hub 4-0:1.0: USB hub found
[ 0.432741] hub 4-0:1.0: 2 ports detected
[ 0.432811] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.432814] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.432822] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 0.432849] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001840
[ 0.432884] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.432887] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.432889] usb usb5: Product: UHCI Host Controller
[ 0.432891] usb usb5: Manufacturer: Linux 3.5.0-37-generic uhci_hcd
[ 0.432894] usb usb5: SerialNumber: 0000:00:1d.0
[ 0.432984] hub 5-0:1.0: USB hub found
[ 0.432990] hub 5-0:1.0: 2 ports detected
[ 0.433058] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.433062] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.433067] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 0.433103] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001860
[ 0.433138] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.433141] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.433143] usb usb6: Product: UHCI Host Controller
[ 0.433146] usb usb6: Manufacturer: Linux 3.5.0-37-generic uhci_hcd
[ 0.433148] usb usb6: SerialNumber: 0000:00:1d.1
[ 0.433242] hub 6-0:1.0: USB hub found
[ 0.433247] hub 6-0:1.0: 2 ports detected
[ 0.433318] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.433321] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.433327] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 0.433353] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001880
[ 0.433387] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.433389] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.433391] usb usb7: Product: UHCI Host Controller
[ 0.433394] usb usb7: Manufacturer: Linux 3.5.0-37-generic uhci_hcd
[ 0.433396] usb usb7: SerialNumber: 0000:00:1d.2
[ 0.433491] hub 7-0:1.0: USB hub found
[ 0.433495] hub 7-0:1.0: 2 ports detected
[ 0.433606] usbcore: registered new interface driver libusual
[ 0.433640] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.436440] i8042: Detected active multiplexing controller, rev 1.1
[ 0.437732] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.437737] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.437764] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.437784] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.437805] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.437923] mousedev: PS/2 mouse device common for all mice
[ 0.438270] rtc_cmos 00:08: rtc core: registered rtc_cmos as rtc0
[ 0.438302] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.438370] device-mapper: uevent: version 1.0.3
[ 0.438430] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 0.438475] cpuidle: using governor ladder
[ 0.438525] cpuidle: using governor menu
[ 0.438528] EFI Variables Facility v0.08 2004-May-17
[ 0.438773] ashmem: initialized
[ 0.438901] TCP: cubic registered
[ 0.438999] NET: Registered protocol family 10
[ 0.439186] NET: Registered protocol family 17
[ 0.439197] Key type dns_resolver registered
[ 0.439401] PM: Hibernation image not present or could not be loaded.
[ 0.439417] registered taskstats version 1
[ 0.441865] Key type trusted registered
[ 0.443838] Key type encrypted registered
[ 0.446320] Magic number: 5:440:84
[ 0.446463] rtc_cmos 00:08: setting system clock to 2013-07-31 15:04:25 UTC (1375283065)
[ 0.474940] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.492137] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.492139] EDD information not available.
[ 0.567413] ata1.00: ATAPI: HL-DT-ST DVDRAM GSA-T20N, WW01, max UDMA/33
[ 0.580310] ata1.00: configured for UDMA/33
[ 0.585701] scsi 0:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T20N WW01 PQ: 0 ANSI: 5
[ 0.590595] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 0.590597] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 0.590730] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 0.590843] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 0.592511] Freeing unused kernel memory: 948k freed
[ 0.592828] Write protecting the kernel read-only data: 12288k
[ 0.597006] Freeing unused kernel memory: 1356k freed
[ 0.600691] Freeing unused kernel memory: 1064k freed
[ 0.616341] udevd[94]: starting version 175
[ 0.660602] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.660994] r8169 0000:06:00.0: irq 46 for MSI/MSI-X
[ 0.661356] r8169 0000:06:00.0: eth0: RTL8168b/8111b at 0xffffc90000328000, 00:03:0d:75:2d:63, XID 18000000 IRQ 46
[ 0.661359] r8169 0000:06:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 0.665603] sata_sil24 0000:07:00.0: version 1.1
[ 0.668214] scsi2 : sata_sil24
[ 0.668277] ata3: SATA max UDMA/100 host m128@0xf0402000 port 0xf0400000 irq 16
[ 0.928082] usb 7-1: new low-speed USB device number 2 using uhci_hcd
[ 1.110413] usb 7-1: New USB device found, idVendor=045e, idProduct=0039
[ 1.110417] usb 7-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 1.110419] usb 7-1: Product: Microsoft 5-Button Mouse with IntelliEye(TM)
[ 1.110422] usb 7-1: Manufacturer: Microsoft
[ 2.748084] ata3: SATA link down (SStatus 0 SControl 0)
[ 2.748587] ahci 0000:00:1f.2: version 3.0
[ 2.748676] ahci 0000:00:1f.2: irq 47 for MSI/MSI-X
[ 2.748751] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x7 impl SATA mode
[ 2.748754] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ccc
[ 2.748760] ahci 0000:00:1f.2: setting latency timer to 64
[ 2.749248] firewire_ohci 0000:08:04.0: enabling device (0195 -> 0197)
[ 2.749798] scsi3 : ahci
[ 2.749887] scsi4 : ahci
[ 2.749955] scsi5 : ahci
[ 2.750066] ata4: SATA max UDMA/133 abar m2048@0xf0704000 port 0xf0704100 irq 47
[ 2.750070] ata5: SATA max UDMA/133 abar m2048@0xf0704000 port 0xf0704180 irq 47
[ 2.750073] ata6: SATA max UDMA/133 abar m2048@0xf0704000 port 0xf0704200 irq 47
[ 2.764468] usbcore: registered new interface driver usbhid
[ 2.764470] usbhid: USB HID core driver
[ 2.804152] firewire_ohci 0000:08:04.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x10
[ 3.068088] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.068107] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.068136] ata5: SATA link down (SStatus 0 SControl 300)
[ 3.068599] ata4.00: unexpected _GTF length (8)
[ 3.126487] ata4.00: ATA-8: WDC WD2500BEVS-22UST0, 01.01A01, max UDMA/133
[ 3.126489] ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 3.127244] ata4.00: unexpected _GTF length (8)
[ 3.127496] ata4.00: configured for UDMA/133
[ 3.127638] scsi 3:0:0:0: Direct-Access ATA WDC WD2500BEVS-2 01.0 PQ: 0 ANSI: 5
[ 3.127786] sd 3:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.127817] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 3.127829] sd 3:0:0:0: [sda] Write Protect is off
[ 3.127832] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.127851] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.163477] sda: sda1 sda2 sda3
[ 3.163836] sd 3:0:0:0: [sda] Attached SCSI disk
[ 3.167233] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/input/input5
[ 3.167402] hid-generic 0003:045E:0039.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:00:1d.2-1/input0
[ 3.304183] firewire_core 0000:08:04.0: created device fw0: GUID 00030d005500b3dc, S400
[ 3.509332] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 15.119808] Adding 2054140k swap on /dev/sda3. Priority:-1 extents:1 across:2054140k
[ 15.125199] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.231412] udevd[455]: starting version 175
[ 15.585146] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.620594] cfg80211: Calling CRDA to update world regulatory domain
[ 15.625317] cfg80211: World regulatory domain updated:
[ 15.625321] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 15.625323] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.625325] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 15.625327] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 15.625329] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.625330] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.636914] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 15.651887] type=1400 audit(1375283080.701:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=519 comm="apparmor_parser"
[ 15.651897] type=1400 audit(1375283080.701:3): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=610 comm="apparmor_parser"
[ 15.652266] type=1400 audit(1375283080.701:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=519 comm="apparmor_parser"
[ 15.652275] type=1400 audit(1375283080.701:5): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=610 comm="apparmor_parser"
[ 15.652471] type=1400 audit(1375283080.701:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=519 comm="apparmor_parser"
[ 15.652481] type=1400 audit(1375283080.701:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=610 comm="apparmor_parser"
[ 15.657115] ACPI Warning: 0x0000000000001060-0x000000000000107f SystemIO conflicts with Region \PMIO 1 (20120320/utaddress-251)
[ 15.657124] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 15.657126] lpc_ich: Resource conflict(s) found affecting iTCO_wdt
[ 15.657129] ACPI Warning: 0x0000000000001028-0x000000000000102f SystemIO conflicts with Region \PMIO 1 (20120320/utaddress-251)
[ 15.657133] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 15.657137] ACPI Warning: 0x0000000000001180-0x00000000000011bf SystemIO conflicts with Region \GPIO 1 (20120320/utaddress-251)
[ 15.657141] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 15.657143] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 15.702044] microcode: CPU0 sig=0x6fa, pf=0x80, revision=0x92
[ 15.764881] lp: driver loaded but no devices found
[ 15.796994] psmouse: `raw' invalid for parameter `proto'
[ 15.797250] psmouse: `raw' invalid for parameter `proto'
[ 15.800341] psmouse: `raw' invalid for parameter `proto'
[ 15.804368] psmouse: `raw' invalid for parameter `proto'
[ 15.808266] psmouse: `raw' invalid for parameter `proto'
[ 15.812514] psmouse: `raw' invalid for parameter `proto'
[ 15.825800] psmouse: `raw' invalid for parameter `proto'
[ 15.828372] psmouse: `raw' invalid for parameter `proto'
[ 15.874875] microcode: CPU1 sig=0x6fa, pf=0x80, revision=0x92
[ 15.876691] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 15.883237] ite_cir: Auto-detected model: ITE8709 CIR transceiver
[ 15.883241] ite_cir: Using model: ITE8709 CIR transceiver
[ 15.883243] ite_cir: TX-capable: 1
[ 15.883245] ite_cir: Sample period (ns): 8680
[ 15.883246] ite_cir: TX carrier frequency (Hz): 38000
[ 15.883248] ite_cir: TX duty cycle (%): 33
[ 15.883249] ite_cir: RX low carrier frequency (Hz): 0
[ 15.883250] ite_cir: RX high carrier frequency (Hz): 0
[ 15.901593] acpi device:03: registered as cooling_device2
[ 15.901609] ACPI: Can't attach device
[ 15.901614] video: probe of LNXVIDEO:00 failed with error -2
[ 16.080065] Registered IR keymap rc-rc6-mce
[ 16.080169] input: ITE8709 CIR transceiver as /devices/virtual/rc/rc0/input6
[ 16.117457] rc0: ITE8709 CIR transceiver as /devices/virtual/rc/rc0
[ 16.117520] ite_cir: driver has been successfully loaded
[ 16.156367] IR NEC protocol handler initialized
[ 16.181524] IR RC5(x) protocol handler initialized
[ 16.189943] IR RC6 protocol handler initialized
[ 16.201197] IR JVC protocol handler initialized
[ 16.202673] IR Sony protocol handler initialized
[ 16.204292] IR SANYO protocol handler initialized
[ 16.223705] input: MCE IR Keyboard/Mouse (ite-cir) as /devices/virtual/input/input7
[ 16.223776] IR MCE Keyboard/mouse protocol handler initialized
[ 16.228204] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.235362] lirc_dev: IR Remote Control driver registered, major 249
[ 16.236512] rc rc0: lirc_dev: driver ir-lirc-codec (ite-cir) registered at minor = 0
[ 16.236514] IR LIRC bridge handler initialized
[ 16.263756] iwl4965: Intel(R) Wireless WiFi 4965 driver for Linux, in-tree:
[ 16.263759] iwl4965: Copyright(c) 2003-2011 Intel Corporation
[ 16.263861] iwl4965 0000:05:00.0: Detected Intel(R) Wireless WiFi Link 4965AGN, REV=0x4
[ 16.302189] iwl4965 0000:05:00.0: device EEPROM VER=0x36, CALIB=0x5
[ 16.302207] iwl4965 0000:05:00.0: Tunable channels: 13 802.11bg, 19 802.11a channels
[ 16.302292] iwl4965 0000:05:00.0: irq 48 for MSI/MSI-X
[ 16.304865] iwl4965 0000:05:00.0: loaded firmware version 228.61.2.24
[ 16.305070] Registered led device: phy0-led
[ 16.305097] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
[ 16.375569] ieee80211 phy0: Selected rate control algorithm 'iwl-4965-rs'
[ 16.398958] snd_hda_intel 0000:00:1b.0: irq 49 for MSI/MSI-X
[ 16.422208] wmi: Mapper loaded
[ 16.553918] nvidia: module license 'NVIDIA' taints kernel.
[ 16.553923] Disabling lock debugging due to kernel taint
[ 16.573703] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 16.573915] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 304.88 Wed Mar 27 14:26:46 PDT 2013
[ 16.615088] hda_codec: ALC883: SKU not ready 0x598301f0
[ 16.628392] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 16.628538] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 16.797879] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 17.297883] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 17.370910] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 17.370914] vesafb: scrolling: redraw
[ 17.370916] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 17.372789] vesafb: framebuffer at 0xcd000000, mapped to 0xffffc90011000000, using 1216k, total 1216k
[ 17.372922] Console: switching to colour frame buffer device 80x30
[ 17.372934] fb0: VESA VGA frame buffer device
[ 18.398164] init: failsafe main process (901) killed by TERM signal
[ 18.477188] ppdev: user-space parallel port driver
[ 18.504546] type=1400 audit(1375283083.553:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=980 comm="apparmor_parser"
[ 18.504996] type=1400 audit(1375283083.553:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=980 comm="apparmor_parser"
[ 18.532564] type=1400 audit(1375283083.581:10): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=1006 comm="apparmor_parser"
[ 18.532932] type=1400 audit(1375283083.581:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1006 comm="apparmor_parser"
[ 18.615143] Bluetooth: Core ver 2.16
[ 18.615164] NET: Registered protocol family 31
[ 18.615166] Bluetooth: HCI device and connection manager initialized
[ 18.615168] Bluetooth: HCI socket layer initialized
[ 18.615170] Bluetooth: L2CAP socket layer initialized
[ 18.615175] Bluetooth: SCO socket layer initialized
[ 18.712042] Bluetooth: RFCOMM TTY layer initialized
[ 18.712049] Bluetooth: RFCOMM socket layer initialized
[ 18.712051] Bluetooth: RFCOMM ver 1.11
[ 18.762830] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 18.771898] r8169 0000:06:00.0: eth0: link down
[ 18.771913] r8169 0000:06:00.0: eth0: link down
[ 18.774770] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.775086] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.842848] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.842851] Bluetooth: BNEP filters: protocol multicast
[ 20.049920] NVRM: Your system is not currently configured to drive a VGA console
[ 20.049925] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 20.049927] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 20.049929] NVRM: drivers including, but not limited to, vesafb, may result in
[ 20.049930] NVRM: corruption and stability problems, and is not supported.
[ 21.371478] r8169 0000:06:00.0: eth0: link up
[ 21.371674] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
~$ cat /var/log/Xorg.0.log
[ 18.847]
X.Org X Server 1.11.3
Release Date: 2011-12-16
[ 18.847] X Protocol Version 11, Revision 0
[ 18.847] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[ 18.847] Current Operating System: Linux master 3.5.0-37-generic #58~precise1-Ubuntu SMP Wed Jul 10 17:48:11 UTC 2013 x86_64
[ 18.847] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-37-generic root=UUID=9eea859f-c227-40ef-a480-748bfa7890a2 ro quiet splash vt.handoff=7
[ 18.847] Build Date: 11 April 2013 01:05:39PM
[ 18.847] xorg-server 2:1.11.4-0ubuntu10.13 (For technical support please see http://www.ubuntu.com/support)
[ 18.847] Current version of pixman: 0.24.4
[ 18.847] Before reporting problems, check http://wiki.x.org
[ 18.847] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 18.847] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 31 18:04:43 2013
[ 18.980] (==) Using config file: "/etc/X11/xorg.conf"
[ 18.980] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 19.087] (==) ServerLayout "Layout0"
[ 19.087] (**) |-->Screen "Screen0" (0)
[ 19.087] (**) | |-->Monitor "Monitor0"
[ 19.087] (**) | |-->Device "Device0"
[ 19.087] (**) |-->Input Device "Keyboard0"
[ 19.087] (**) |-->Input Device "Mouse0"
[ 19.087] (**) Option "Xinerama" "0"
[ 19.087] (==) Automatically adding devices
[ 19.087] (==) Automatically enabling devices
[ 19.087] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 19.087] Entry deleted from font path.
[ 19.087] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 19.087] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 19.088] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 19.088] Entry deleted from font path.
[ 19.088] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 19.088] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 19.088] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 19.088] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 19.088] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 19.088] (WW) Disabling Keyboard0
[ 19.088] (WW) Disabling Mouse0
[ 19.088] (II) Loader magic: 0x7f5cc58a9b00
[ 19.088] (II) Module ABI versions:
[ 19.088] X.Org ANSI C Emulation: 0.4
[ 19.088] X.Org Video Driver: 11.0
[ 19.088] X.Org XInput driver : 16.0
[ 19.088] X.Org Server Extension : 6.0
[ 19.089] (--) PCI:*(0:1:0:0) 10de:0425:1734:1107 rev 161, Mem @ 0xce000000/16777216, 0xd0000000/268435456, 0xcc000000/33554432, I/O @ 0x00002000/128
[ 19.089] (II) Open ACPI successful (/var/run/acpid.socket)
[ 19.089] (II) LoadModule: "extmod"
[ 19.099] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 19.099] (II) Module extmod: vendor="X.Org Foundation"
[ 19.099] compiled for 1.11.3, module version = 1.0.0
[ 19.100] Module class: X.Org Server Extension
[ 19.100] ABI class: X.Org Server Extension, version 6.0
[ 19.100] (II) Loading extension MIT-SCREEN-SAVER
[ 19.100] (II) Loading extension XFree86-VidModeExtension
[ 19.100] (II) Loading extension XFree86-DGA
[ 19.100] (II) Loading extension DPMS
[ 19.100] (II) Loading extension XVideo
[ 19.100] (II) Loading extension XVideo-MotionCompensation
[ 19.100] (II) Loading extension X-Resource
[ 19.100] (II) LoadModule: "dbe"
[ 19.100] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 19.100] (II) Module dbe: vendor="X.Org Foundation"
[ 19.100] compiled for 1.11.3, module version = 1.0.0
[ 19.100] (II) Loading extension DOUBLE-BUFFER
[ 19.100] (II) LoadModule: "glx"
[ 19.100] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 19.117] (II) Module glx: vendor="NVIDIA Corporation"
[ 19.118] compiled for 4.0.2, module version = 1.0.0
[ 19.118] Module class: X.Org Server Extension
[ 19.118] (II) NVIDIA GLX Module 304.88 Wed Mar 27 14:46:57 PDT 2013
[ 19.118] (II) Loading extension GLX
[ 19.118] (II) LoadModule: "record"
[ 19.118] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 19.118] (II) Module record: vendor="X.Org Foundation"
[ 19.118] compiled for 1.11.3, module version = 1.13.0
[ 19.118] ABI class: X.Org Server Extension, version 6.0
[ 19.118] (II) Loading extension RECORD
[ 19.118] (II) LoadModule: "dri"
[ 19.118] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 19.118] (II) Module dri: vendor="X.Org Foundation"
[ 19.118] compiled for 1.11.3, module version = 1.0.0
[ 19.118] (II) Loading extension XFree86-DRI
[ 19.118] (II) LoadModule: "dri2"
[ 19.118] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 19.119] (II) Module dri2: vendor="X.Org Foundation"
[ 19.119] compiled for 1.11.3, module version = 1.2.0
[ 19.119] ABI class: X.Org Server Extension, version 6.0
[ 19.119] (II) Loading extension DRI2
[ 19.119] (II) LoadModule: "nvidia"
[ 19.119] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 19.119] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 19.119] compiled for 4.0.2, module version = 1.0.0
[ 19.119] Module class: X.Org Video Driver
[ 19.119] (II) NVIDIA dlloader X Driver 304.88 Wed Mar 27 14:28:14 PDT 2013
[ 19.119] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 19.119] (++) using VT number 7
[ 19.119] (II) Loading sub module "fb"
[ 19.119] (II) LoadModule: "fb"
[ 19.120] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 19.120] (II) Module fb: vendor="X.Org Foundation"
[ 19.120] compiled for 1.11.3, module version = 1.0.0
[ 19.120] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.120] (II) Loading sub module "wfb"
[ 19.120] (II) LoadModule: "wfb"
[ 19.120] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 19.120] (II) Module wfb: vendor="X.Org Foundation"
[ 19.120] (II) Loading sub module "ramdac"
[ 19.120] (II) LoadModule: "ramdac"
[ 19.120] (II) Module "ramdac" already built-in
[ 19.120] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 19.120] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 19.120] (==) NVIDIA(0): RGB weight 888
[ 19.120] (==) NVIDIA(0): Default visual is TrueColor
[ 19.120] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 19.120] (**) NVIDIA(0): Option "Stereo" "0"
[ 19.120] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
[ 19.120] (**) NVIDIA(0): Stereo disabled by request
[ 19.121] (**) NVIDIA(0): Option "MetaModes" "1280x800_60 +0+0"
[ 19.121] (**) NVIDIA(0): Enabling 2D acceleration
[ 20.092] (II) NVIDIA(GPU-0): Display (LPL (DFP-0)) does not support NVIDIA 3D Vision
[ 20.092] (II) NVIDIA(GPU-0): stereo.
[ 20.096] (II) NVIDIA(0): NVIDIA GPU GeForce 8600M GS (G86) at PCI:1:0:0 (GPU-0)
[ 20.096] (--) NVIDIA(0): Memory: 524288 kBytes
[ 20.096] (--) NVIDIA(0): VideoBIOS: 60.86.4b.00.14
[ 20.096] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 20.096] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 20.102] (--) NVIDIA(0): Valid display device(s) on GeForce 8600M GS at PCI:1:0:0
[ 20.102] (--) NVIDIA(0): CRT-0
[ 20.102] (--) NVIDIA(0): TV-0
[ 20.102] (--) NVIDIA(0): LPL (DFP-0) (connected)
[ 20.102] (--) NVIDIA(0): DFP-1
[ 20.102] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 20.102] (--) NVIDIA(0): TV-0: 400.0 MHz maximum pixel clock
[ 20.102] (--) NVIDIA(0): TV encoder: Unknown
[ 20.102] (--) NVIDIA(0): LPL (DFP-0): 330.0 MHz maximum pixel clock
[ 20.102] (--) NVIDIA(0): LPL (DFP-0): Internal Dual Link LVDS
[ 20.102] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 20.102] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 20.102] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 20.102] (**) NVIDIA(0): device LPL (DFP-0) (Using EDID frequencies has been
[ 20.102] (**) NVIDIA(0): enabled on all display devices.)
[ 20.102] (II) NVIDIA(0): Validated MetaModes:
[ 20.102] (II) NVIDIA(0): "1280x800_60+0+0"
[ 20.102] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 800
[ 21.128] (--) NVIDIA(0): DPI set to (98, 96); computed from "UseEdidDpi" X config
[ 21.128] (--) NVIDIA(0): option
[ 21.128] (--) Depth 24 pixmap format is 32 bpp
[ 21.128] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[ 21.140] (II) NVIDIA(0): Setting mode "1280x800_60+0+0"
[ 21.430] (II) Loading extension NV-GLX
[ 21.460] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 21.460] (==) NVIDIA(0): Backing store disabled
[ 21.460] (==) NVIDIA(0): Silken mouse enabled
[ 21.460] (**) NVIDIA(0): DPMS enabled
[ 21.460] (II) Loading extension NV-CONTROL
[ 21.460] (II) Loading extension XINERAMA
[ 21.461] (II) Loading sub module "dri2"
[ 21.461] (II) LoadModule: "dri2"
[ 21.461] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 21.461] (II) Module dri2: vendor="X.Org Foundation"
[ 21.461] compiled for 1.11.3, module version = 1.2.0
[ 21.461] ABI class: X.Org Server Extension, version 6.0
[ 21.461] (II) NVIDIA(0): [DRI2] Setup complete
[ 21.461] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 21.461] (--) RandR disabled
[ 21.461] (II) Initializing built-in extension Generic Event Extension
[ 21.461] (II) Initializing built-in extension SHAPE
[ 21.461] (II) Initializing built-in extension MIT-SHM
[ 21.461] (II) Initializing built-in extension XInputExtension
[ 21.461] (II) Initializing built-in extension XTEST
[ 21.461] (II) Initializing built-in extension BIG-REQUESTS
[ 21.461] (II) Initializing built-in extension SYNC
[ 21.461] (II) Initializing built-in extension XKEYBOARD
[ 21.461] (II) Initializing built-in extension XC-MISC
[ 21.461] (II) Initializing built-in extension SECURITY
[ 21.461] (II) Initializing built-in extension XINERAMA
[ 21.461] (II) Initializing built-in extension XFIXES
[ 21.461] (II) Initializing built-in extension RENDER
[ 21.461] (II) Initializing built-in extension RANDR
[ 21.461] (II) Initializing built-in extension COMPOSITE
[ 21.461] (II) Initializing built-in extension DAMAGE
[ 21.463] (II) Initializing extension GLX
[ 21.480] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 21.483] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 21.483] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21.483] (II) LoadModule: "evdev"
[ 21.483] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.483] (II) Module evdev: vendor="X.Org Foundation"
[ 21.483] compiled for 1.11.3, module version = 2.7.0
[ 21.483] Module class: X.Org XInput Driver
[ 21.483] ABI class: X.Org XInput driver, version 16.0
[ 21.483] (II) Using input driver 'evdev' for 'Power Button'
[ 21.483] (**) Power Button: always reports core events
[ 21.483] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 21.483] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 21.483] (--) evdev: Power Button: Found keys
[ 21.483] (II) evdev: Power Button: Configuring as keyboard
[ 21.483] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 21.483] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 21.484] (**) Option "xkb_rules" "evdev"
[ 21.484] (**) Option "xkb_model" "pc105"
[ 21.484] (**) Option "xkb_layout" "us,gr"
[ 21.484] (**) Option "xkb_variant" ",extended"
[ 21.484] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 21.485] (II) XKB: reuse xkmfile /var/lib/xkb/server-5638493DFF39088E7B2F033D998088CF5A50243F.xkm
[ 21.486] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 21.486] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21.486] (II) Using input driver 'evdev' for 'Power Button'
[ 21.486] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.486] (**) Power Button: always reports core events
[ 21.486] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 21.486] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 21.486] (--) evdev: Power Button: Found keys
[ 21.486] (II) evdev: Power Button: Configuring as keyboard
[ 21.486] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 21.486] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 21.486] (**) Option "xkb_rules" "evdev"
[ 21.486] (**) Option "xkb_model" "pc105"
[ 21.486] (**) Option "xkb_layout" "us,gr"
[ 21.486] (**) Option "xkb_variant" ",extended"
[ 21.486] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 21.486] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 21.486] (II) No input driver specified, ignoring this device.
[ 21.486] (II) This device may have been added with another device file.
[ 21.487] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 21.487] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 21.487] (II) Using input driver 'evdev' for 'Sleep Button'
[ 21.487] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.487] (**) Sleep Button: always reports core events
[ 21.487] (**) evdev: Sleep Button: Device: "/dev/input/event2"
[ 21.487] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 21.487] (--) evdev: Sleep Button: Found keys
[ 21.487] (II) evdev: Sleep Button: Configuring as keyboard
[ 21.487] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 21.487] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 21.487] (**) Option "xkb_rules" "evdev"
[ 21.487] (**) Option "xkb_model" "pc105"
[ 21.487] (**) Option "xkb_layout" "us,gr"
[ 21.487] (**) Option "xkb_variant" ",extended"
[ 21.487] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 21.487] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event8)
[ 21.487] (II) No input driver specified, ignoring this device.
[ 21.487] (II) This device may have been added with another device file.
[ 21.487] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event9)
[ 21.488] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/event5)
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Applying InputClass "evdev pointer catchall"
[ 21.488] (II) Using input driver 'evdev' for 'Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)'
[ 21.488] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): always reports core events
[ 21.488] (**) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Device: "/dev/input/event5"
[ 21.488] (--) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Vendor 0x45e Product 0x39
[ 21.488] (--) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found 9 mouse buttons
[ 21.488] (--) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found scroll wheel(s)
[ 21.488] (--) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found relative axes
[ 21.488] (--) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Found x and y relative axes
[ 21.488] (II) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Configuring as mouse
[ 21.488] (II) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): Adding scrollwheel support
[ 21.488] (**) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): YAxisMapping: buttons 4 and 5
[ 21.488] (**) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21.488] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/input/input5/event5"
[ 21.488] (II) XINPUT: Adding extended input device "Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)" (type: MOUSE, id 9)
[ 21.488] (II) evdev: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): initialized for relative axes.
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) keeping acceleration scheme 1
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration profile 0
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration factor: 2.000
[ 21.488] (**) Microsoft Microsoft 5-Button Mouse with IntelliEye(TM): (accel) acceleration threshold: 4
[ 21.488] (II) config/udev: Adding input device Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) (/dev/input/mouse0)
[ 21.488] (II) No input driver specified, ignoring this device.
[ 21.488] (II) This device may have been added with another device file.
[ 21.489] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 21.489] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 21.489] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 21.489] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.489] (**) AT Translated Set 2 keyboard: always reports core events
[ 21.489] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event4"
[ 21.489] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 21.489] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 21.489] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 21.489] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 21.489] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 21.489] (**) Option "xkb_rules" "evdev"
[ 21.489] (**) Option "xkb_model" "pc105"
[ 21.489] (**) Option "xkb_layout" "us,gr"
[ 21.489] (**) Option "xkb_variant" ",extended"
[ 21.489] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 21.491] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (ite-cir) (/dev/input/event7)
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): Applying InputClass "evdev pointer catchall"
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): Applying InputClass "evdev keyboard catchall"
[ 21.491] (II) Using input driver 'evdev' for 'MCE IR Keyboard/Mouse (ite-cir)'
[ 21.491] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): always reports core events
[ 21.491] (**) evdev: MCE IR Keyboard/Mouse (ite-cir): Device: "/dev/input/event7"
[ 21.491] (--) evdev: MCE IR Keyboard/Mouse (ite-cir): Vendor 0 Product 0
[ 21.491] (--) evdev: MCE IR Keyboard/Mouse (ite-cir): Found 3 mouse buttons
[ 21.491] (--) evdev: MCE IR Keyboard/Mouse (ite-cir): Found relative axes
[ 21.491] (--) evdev: MCE IR Keyboard/Mouse (ite-cir): Found x and y relative axes
[ 21.491] (--) evdev: MCE IR Keyboard/Mouse (ite-cir): Found keys
[ 21.491] (II) evdev: MCE IR Keyboard/Mouse (ite-cir): Configuring as mouse
[ 21.491] (II) evdev: MCE IR Keyboard/Mouse (ite-cir): Configuring as keyboard
[ 21.491] (**) evdev: MCE IR Keyboard/Mouse (ite-cir): YAxisMapping: buttons 4 and 5
[ 21.491] (**) evdev: MCE IR Keyboard/Mouse (ite-cir): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 21.491] (**) Option "config_info" "udev:/sys/devices/virtual/input/input7/event7"
[ 21.491] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (ite-cir)" (type: KEYBOARD, id 11)
[ 21.491] (**) Option "xkb_rules" "evdev"
[ 21.491] (**) Option "xkb_model" "pc105"
[ 21.491] (**) Option "xkb_layout" "us,gr"
[ 21.491] (**) Option "xkb_variant" ",extended"
[ 21.491] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 21.491] (II) evdev: MCE IR Keyboard/Mouse (ite-cir): initialized for relative axes.
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): (accel) keeping acceleration scheme 1
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): (accel) acceleration profile 0
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): (accel) acceleration factor: 2.000
[ 21.491] (**) MCE IR Keyboard/Mouse (ite-cir): (accel) acceleration threshold: 4
[ 21.492] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (ite-cir) (/dev/input/mouse1)
[ 21.492] (II) No input driver specified, ignoring this device.
[ 21.492] (II) This device may have been added with another device file.
[ 21.492] (II) config/udev: Adding input device ITE8709 CIR transceiver (/dev/input/event6)
[ 21.492] (**) ITE8709 CIR transceiver: Applying InputClass "evdev keyboard catchall"
[ 21.492] (II) Using input driver 'evdev' for 'ITE8709 CIR transceiver'
[ 21.492] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 21.492] (**) ITE8709 CIR transceiver: always reports core events
[ 21.492] (**) evdev: ITE8709 CIR transceiver: Device: "/dev/input/event6"
[ 21.492] (--) evdev: ITE8709 CIR transceiver: Vendor 0x1283 Product 0
[ 21.492] (--) evdev: ITE8709 CIR transceiver: Found keys
[ 21.492] (II) evdev: ITE8709 CIR transceiver: Configuring as keyboard
[ 21.492] (**) Option "config_info" "udev:/sys/devices/virtual/rc/rc0/input6/event6"
[ 21.492] (II) XINPUT: Adding extended input device "ITE8709 CIR transceiver" (type: KEYBOARD, id 12)
[ 21.492] (**) Option "xkb_rules" "evdev"
[ 21.492] (**) Option "xkb_model" "pc105"
[ 21.492] (**) Option "xkb_layout" "us,gr"
[ 21.492] (**) Option "xkb_variant" ",extended"
[ 21.492] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 23.450] (II) NVIDIA(GPU-0): Display (LPL (DFP-0)) does not support NVIDIA 3D Vision
[ 23.450] (II) NVIDIA(GPU-0): stereo.
[ 23.450] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 23.450] (**) NVIDIA(0): device LPL (DFP-0) (Using EDID frequencies has been
[ 23.450] (**) NVIDIA(0): enabled on all display devices.)
[ 24.443] (II) NVIDIA(GPU-0): Display (LPL (DFP-0)) does not support NVIDIA 3D Vision
[ 24.443] (II) NVIDIA(GPU-0): stereo.
[ 24.443] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 24.443] (**) NVIDIA(0): device LPL (DFP-0) (Using EDID frequencies has been
[ 24.443] (**) NVIDIA(0): enabled on all display devices.)
[ 25.920] (II) XKB: reuse xkmfile /var/lib/xkb/server-31BFF7E3F0A5BFB541AE104C644369929E268F61.xkm
[ 26.491] (II) NVIDIA(GPU-0): Display (LPL (DFP-0)) does not support NVIDIA 3D Vision
[ 26.491] (II) NVIDIA(GPU-0): stereo.
[ 26.491] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 26.491] (**) NVIDIA(0): device LPL (DFP-0) (Using EDID frequencies has been
[ 26.491] (**) NVIDIA(0): enabled on all display devices.)
[ 44.153] (II) NVIDIA(GPU-0): Display (LPL (DFP-0)) does not support NVIDIA 3D Vision
[ 44.153] (II) NVIDIA(GPU-0): stereo.
[ 44.153] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 44.153] (**) NVIDIA(0): device LPL (DFP-0) (Using EDID frequencies has been
[ 44.153] (**) NVIDIA(0): enabled on all display devices.)
[ 13614.446] (II) config/udev: Adding input device ImPS/2 Synaptics TouchPad (/dev/input/event10)
[ 13614.446] (**) ImPS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
[ 13614.447] (II) Using input driver 'evdev' for 'ImPS/2 Synaptics TouchPad'
[ 13614.447] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 13614.447] (**) ImPS/2 Synaptics TouchPad: always reports core events
[ 13614.447] (**) evdev: ImPS/2 Synaptics TouchPad: Device: "/dev/input/event10"
[ 13614.447] (--) evdev: ImPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x5
[ 13614.447] (--) evdev: ImPS/2 Synaptics TouchPad: Found 3 mouse buttons
[ 13614.447] (--) evdev: ImPS/2 Synaptics TouchPad: Found scroll wheel(s)
[ 13614.447] (--) evdev: ImPS/2 Synaptics TouchPad: Found relative axes
[ 13614.447] (--) evdev: ImPS/2 Synaptics TouchPad: Found x and y relative axes
[ 13614.447] (II) evdev: ImPS/2 Synaptics TouchPad: Configuring as mouse
[ 13614.447] (II) evdev: ImPS/2 Synaptics TouchPad: Adding scrollwheel support
[ 13614.447] (**) evdev: ImPS/2 Synaptics TouchPad: YAxisMapping: buttons 4 and 5
[ 13614.447] (**) evdev: ImPS/2 Synaptics TouchPad: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 13614.447] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input10/event10"
[ 13614.447] (II) XINPUT: Adding extended input device "ImPS/2 Synaptics TouchPad" (type: MOUSE, id 13)
[ 13614.448] (II) evdev: ImPS/2 Synaptics TouchPad: initialized for relative axes.
[ 13614.448] (**) ImPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 13614.448] (**) ImPS/2 Synaptics TouchPad: (accel) acceleration profile 0
[ 13614.449] (**) ImPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 13614.449] (**) ImPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 13614.451] (II) config/udev: Adding input device ImPS/2 Synaptics TouchPad (/dev/input/mouse2)
[ 13614.451] (II) No input driver specified, ignoring this device.
[ 13614.451] (II) This device may have been added with another device file.
[ 13701.376] (II) config/udev: removing device ImPS/2 Synaptics TouchPad
[ 13701.378] (II) evdev: ImPS/2 Synaptics TouchPad: Close
[ 13701.378] (II) UnloadModule: "evdev"
[ 13701.378] (II) Unloading evdev
~$ ls /etc/X11
app-defaults X Xreset Xsession.options
cursors xinit Xreset.d Xwrapper.config
default-display-manager xkb Xresources
fonts xorg.conf Xsession
rgb.txt xorg.conf.backup Xsession.d
[ 28.028267] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17579 PROTO=2
[ 152.291770] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17580 PROTO=2
[ 277.003710] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17581 PROTO=2
[ 327.727844] audit_printk_skb: 54 callbacks suppressed
[ 327.727855] type=1400 audit(1375283392.259:30): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=981 comm="cupsd" pid=981 comm="cupsd" capability=36 capname="block_suspend"
[ 400.949419] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17582 PROTO=2
[ 525.302660] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17583 PROTO=2
[ 650.392862] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17584 PROTO=2
[ 774.328678] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17585 PROTO=2
[ 868.134442] type=1400 audit(1375283932.666:31): apparmor="DENIED" operation="capable" parent=1 profile="/usr/sbin/cupsd" pid=981 comm="cupsd" pid=981 comm="cupsd" capability=36 capname="block_suspend"
[ 898.661345] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17586 PROTO=2
[ 1023.423024] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17587 PROTO=2
[ 1147.836310] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17588 PROTO=2
[ 1272.209549] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17589 PROTO=2
[ 1396.852658] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17590 PROTO=2
[ 1521.673216] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17591 PROTO=2
[ 1646.446298] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17592 PROTO=2
[ 1770.340220] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17593 PROTO=2
[ 1895.561650] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17594 PROTO=2
[ 2019.375806] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17595 PROTO=2
[ 2143.789061] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17596 PROTO=2
[ 2268.889865] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17597 PROTO=2
[ 2393.223332] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17598 PROTO=2
[ 2517.725849] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17599 PROTO=2
[ 2641.880049] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17600 PROTO=2
[ 2766.545056] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17601 PROTO=2
[ 2890.865986] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17602 PROTO=2
[ 3016.036112] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17603 PROTO=2
[ 3140.628558] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17604 PROTO=2
[ 3264.395073] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17605 PROTO=2
[ 3388.917017] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17606 PROTO=2
[ 3513.360275] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17607 PROTO=2
[ 3638.410657] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17608 PROTO=2
[ 3762.345781] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17609 PROTO=2
[ 3886.858475] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17610 PROTO=2
[ 4011.510854] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17611 PROTO=2
[ 4135.884456] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17612 PROTO=2
[ 4261.054306] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17613 PROTO=2
[ 4385.646906] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17614 PROTO=2
[ 4510.070624] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17615 PROTO=2
[ 4633.870649] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17616 PROTO=2
[ 4758.398701] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17617 PROTO=2
[ 4883.420168] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17618 PROTO=2
[ 4959.800058] usb 2-3: new high-speed USB device number 3 using ehci_hcd
[ 4959.939858] usb 2-3: New USB device found, idVendor=0402, idProduct=5602
[ 4959.939863] usb 2-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4959.939866] usb 2-3: Product: USB2.0 Camera
[ 4960.005960] Linux video capture interface: v2.00
[ 4960.020576] gspca_main: v2.14.0 registered
[ 4960.048761] gspca_main: ALi m5602-2.14.0 probing 0402:5602
[ 4960.111373] gspca_m5602: Detected a s5k4aa sensor
[ 4960.140409] usbcore: registered new interface driver ALi m5602
[ 5007.405208] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17619 PROTO=2
[ 5015.372781] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=41823 LEN=318
[ 5015.432581] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=59075 LEN=318
[ 5050.233452] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=41088 LEN=318
[ 5050.296951] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=53475 LEN=318
[ 5132.265577] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17620 PROTO=2
[ 5134.895690] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=42799 LEN=318
[ 5134.955231] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=59688 LEN=318
[ 5157.125375] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=176.100.91.11 DST=192.168.1.2 LEN=47 TOS=0x18 PREC=0x20 TTL=117 ID=29647 PROTO=UDP SPT=37734 DPT=45628 LEN=27
[ 5169.786277] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=44901 LEN=318
[ 5169.846016] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=35624 LEN=318
[ 5255.424132] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=47006 LEN=318
[ 5255.485399] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=49868 LEN=318
[ 5256.399842] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17621 PROTO=2
[ 5263.144243] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=27.52.246.154 DST=192.168.1.2 LEN=47 TOS=0x18 PREC=0x20 TTL=38 ID=0 DF PROTO=UDP SPT=42722 DPT=45628 LEN=27
[ 5380.922783] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17622 PROTO=2
[ 5506.113063] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17623 PROTO=2
[ 5515.376599] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=35786 LEN=318
[ 5515.436037] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=53750 LEN=318
[ 5550.237381] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=39074 LEN=318
[ 5550.297092] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=48694 LEN=318
[ 5629.928543] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17624 PROTO=2
[ 5661.265978] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=81.193.115.10 DST=192.168.1.2 LEN=47 TOS=0x18 PREC=0x20 TTL=116 ID=58867 PROTO=UDP SPT=9148 DPT=45628 LEN=27
[ 5705.616862] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=41640 LEN=318
[ 5705.676718] [UFW BLOCK] IN=eth0 OUT= MAC=00:03:0d:75:2d:63:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=192.168.1.2 LEN=338 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1900 DPT=36653 LEN=318
[ 5754.700269] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17625 PROTO=2
[ 5879.272984] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17626 PROTO=2
[ 6003.656463] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17627 PROTO=2
[ 6128.668061] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17628 PROTO=2
[ 6180.878692] usb 2-3: USB disconnect, device number 3
[ 6252.462654] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17629 PROTO=2
[ 6377.115989] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17630 PROTO=2
[ 6406.360730] psmouse: `raw' invalid for parameter `proto'
[ 6471.921754] psmouse: `raw' invalid for parameter `proto'
[ 6501.279434] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17631 PROTO=2
[ 6626.319739] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17632 PROTO=2
[ 6750.695509] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17633 PROTO=2
[ 6874.936805] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17634 PROTO=2
[ 6999.977874] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17635 PROTO=2
[ 7123.952670] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17636 PROTO=2
[ 7248.883852] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17637 PROTO=2
[ 7373.037952] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17638 PROTO=2
[ 7497.491380] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17639 PROTO=2
[ 7622.521930] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17640 PROTO=2
[ 7746.487047] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17641 PROTO=2
[ 7871.221028] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17642 PROTO=2
[ 7996.229546] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17643 PROTO=2
[ 8119.965498] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17644 PROTO=2
[ 8245.066116] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17645 PROTO=2
[ 8368.961668] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17646 PROTO=2
[ 8493.603963] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17647 PROTO=2
[ 8618.037073] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17648 PROTO=2
[ 8742.699381] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17649 PROTO=2
[ 8866.943278] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17650 PROTO=2
[ 8991.496001] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17651 PROTO=2
[ 9116.128060] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17652 PROTO=2
[ 9240.541608] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17653 PROTO=2
[ 9365.123862] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17654 PROTO=2
[ 9490.115203] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17655 PROTO=2
[ 9613.990049] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17656 PROTO=2
[ 9739.001338] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17657 PROTO=2
[ 9863.036043] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17658 PROTO=2
[ 9988.266259] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17659 PROTO=2
[10112.579744] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17660 PROTO=2
[10237.044019] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17661 PROTO=2
[10361.117312] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17662 PROTO=2
[10485.570319] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17663 PROTO=2
[10610.780084] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17664 PROTO=2
[10695.589006] CE: hpet increased min_delta_ns to 20113 nsec
[10734.565948] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17665 PROTO=2
[10859.845543] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17666 PROTO=2
[10983.671264] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17667 PROTO=2
[11108.054451] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17668 PROTO=2
[11232.686941] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17669 PROTO=2
[11357.060349] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17670 PROTO=2
[11482.359677] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17671 PROTO=2
[11606.594702] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17672 PROTO=2
[11730.538972] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17673 PROTO=2
[11855.798642] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17674 PROTO=2
[11979.584411] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17675 PROTO=2
[12104.335876] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17676 PROTO=2
[12228.878882] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17677 PROTO=2
[12353.102472] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17678 PROTO=2
[12477.845743] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17679 PROTO=2
[12602.068852] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17680 PROTO=2
[12726.880224] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17681 PROTO=2
[12851.771364] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17682 PROTO=2
[12976.264431] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17683 PROTO=2
[13100.398988] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17684 PROTO=2
[13224.612585] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17685 PROTO=2
[13349.265929] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17686 PROTO=2
[13473.628406] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17687 PROTO=2
[13598.300649] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17688 PROTO=2
[13614.437584] input: ImPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input10
[13723.261599] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17689 PROTO=2
[13847.097137] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17690 PROTO=2
[13971.879641] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17691 PROTO=2
[14096.122621] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17692 PROTO=2
[14221.253882] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17693 PROTO=2
[14345.596681] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17694 PROTO=2
[14469.641112] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17695 PROTO=2
[14594.204023] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:00:00:01:2c:26:c5:1b:b6:dc:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=28 TOS=0x00 PREC=0xC0 TTL=1 ID=17696 PROTO=2
synclient
~$ xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) id=9 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=11 [slave pointer (2)]
⎜ ↳ MCE IR Keyboard/Mouse (ite-cir) id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ ITE8709 CIR transceiver id=13 [slave keyboard (3)]
~$ synclient
Parameter settings:
LeftEdge = 1752
RightEdge = 5192
TopEdge = 1620
BottomEdge = 4236
FingerLow = 25
FingerHigh = 30
FingerPress = 256
MaxTapTime = 180
MaxTapMove = 221
MaxDoubleTapTime = 180
SingleTapTimeout = 180
ClickTime = 100
FastTaps = 0
EmulateMidButtonTime = 75
EmulateTwoFingerMinZ = 282
EmulateTwoFingerMinW = 7
VertScrollDelta = 100
HorizScrollDelta = 100
VertEdgeScroll = 1
HorizEdgeScroll = 0
CornerCoasting = 0
VertTwoFingerScroll = 0
HorizTwoFingerScroll = 0
MinSpeed = 1
MaxSpeed = 1.75
AccelFactor = 0.0398089
TrackstickSpeed = 40
EdgeMotionMinZ = 30
EdgeMotionMaxZ = 160
EdgeMotionMinSpeed = 1
EdgeMotionMaxSpeed = 401
EdgeMotionUseAlways = 0
TouchpadOff = 2
LockedDrags = 0
LockedDragTimeout = 5000
RTCornerButton = 2
RBCornerButton = 3
LTCornerButton = 0
LBCornerButton = 0
TapButton1 = 1
TapButton2 = 3
TapButton3 = 0
ClickFinger1 = 1
ClickFinger2 = 1
ClickFinger3 = 0
CircularScrolling = 0
CircScrollDelta = 0.1
CircScrollTrigger = 0
CircularPad = 0
PalmDetect = 0
PalmMinWidth = 10
PalmMinZ = 200
CoastingSpeed = 20
CoastingFriction = 50
PressureMotionMinZ = 30
PressureMotionMaxZ = 160
PressureMotionMinFactor = 1
PressureMotionMaxFactor = 1
ResolutionDetect = 1
GrabEventDevice = 1
TapAndDragGesture = 1
AreaLeftEdge = 0
AreaRightEdge = 0
AreaTopEdge = 0
AreaBottomEdge = 0
HorizHysteresis = 25
VertHysteresis = 25
ClickPad = 0
