/usr/lib/nux/unity_support_test -pfree -m
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.5, 128 bits)
OpenGL version string: 3.0 Mesa 10.3.2
Not software rendered: no
Not blacklisted: yes
GLX fbconfig: yes
GLX texture from pixmap: yes
GL npot or rect textures: yes
GL vertex program: yes
GL fragment program: yes
GL vertex buffer object: yes
GL framebuffer object: yes
GL version is 1.4+: yes
Unity 3D supported: no
thangian@thangian-desktop:~$
thangian@thangian-desktop:~$ free -m
total used free shared buffers cached
Mem: 2018 1073 944 1 54 491
-/+ buffers/cache: 527 1490
Swap: 2045 0 2045
sudo service lightdm stopsudo ./<όνομα αρχείου> sudo service lightdm startsudo nvidia-xconfig
sudo add-apt-repository ppa:mamarley/nvidiasudo apt-get updatesudo apt-get install nvidia-340
