provlima me aspire 5720
Δημοσίευσηαπό vasilis50 » 17 Μάιος 2009, 19:54
Kat arxhn na zhthso signomi poy grafo me latinikoys xaraktires
To laptop den xekinaei me ta vista kai exo xekinisei me cd toy ubuntu 7.01
Etsi exo mpei sto internet alla den mporo na alaxo glossa gia ta ellhnika
Otan pao na do ton disko ACER moy leiei oti NTFS: IS MARKED TO BE IN USE
leei pio kato na doso thn entolh mount -t ntfs-3g/dev/sda2/media/acer 0 force
tin opoia kai dino alla to laptop exakoluthei na min xekinaei me ta vista
mipos dino lathos thn entolh ayth?
h voitheia sas politimi
kai signomi kai pali giati den mporo na grapso sta ellinika - peite moy mia lysy kai gia ayto
eyxaristo
vasilis50
Re: provlima me aspire 5720
Δημοσίευσηαπό linuxman » 17 Μάιος 2009, 20:23
Δώσε το
sudo mount -t ntfs-3g/dev/sda2/media/acer 0 force
Δημοσίευσηαπό vasilis50 » 17 Μάιος 2009, 21:10
edosa ayto poy moy eipes kai moy apanthse oti
mount point force does not exist
vasilis50
Δημοσίευσηαπό linuxman » 18 Μάιος 2009, 00:08
Λάθος μου σόρρυ
sudo mkdir /media/acer
και μετά
sudo mount -t ntfs-3g /dev/sda2 /media/acer 0 force
Δημοσίευσηαπό vasilis50 » 18 Μάιος 2009, 08:04
Prota na se eyxaristiso gia tin boithia soy
distixos kai pali den egine tipote.
Synexizei na dinei cannot mount volume kai dinonontas tin deyterh bgazei mono tis odigies
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
ubuntu@ubuntu:~$ sudo mkdir /media/acer
ubuntu@ubuntu:~$ sudo mount -t ntfs-3g /dev/sda2 /media/acer 0 force
Usage: mount -V : print version
mount -h : print this help
mount : list mounted filesystems
mount -l : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere'.
Details found in /etc/fstab may be omitted.
mount -a [-t|-O] ... : mount all stuff from /etc/fstab
mount device : mount device at the known place
mount directory : mount known device here
mount -t type dev dir : ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
mount --bind olddir newdir
or move a subtree:
mount --move olddir newdir
One can change the type of mount containing the directory dir:
mount --make-shared dir
mount --make-slave dir
mount --make-private dir
mount --make-unbindable dir
One can change the type of all the mounts in a mount subtree
mount --make-rshared dir
mount --make-rslave dir
mount --make-rprivate dir
mount --make-runbindable dir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using -L label or by uuid, using -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say man 8 mount .
vasilis50
Σε aspire 5720g βγάζει το σφάλμα 0xc00000e9
Δημοσίευσηαπό vasilis50 » 19 Μάιος 2009, 12:14
Βρήκα ένα άλλον υπολογιστή για να μην συνεχίσω να γράφω με λατινικούς χαρακτήρες που δεν μου αρέσει καθόλου και εμένα, αλλά με τον άλλον δεν μπορούσα να κάνω καμία αλαγή ούτε βεβαίως να βάλω και ελληνικά!!!
Στις εντολές που μου έδωσες, στην δεύτερη έπρεπε να γραφτεί -ο force αντνι 0 force.
Έτσι μπόρεσα να δω τα partition του υπολογιστή μου και σε ευχαριστώ πολύ γιαυτό, αλλά τώρα βγήκε άλλο πρόβλημα δηλαδή δεν ξεκινάει γιατί έβγαλε ότι:
"Windows has encountered a problem communicating with a device connected to your computer.
This error can be caused by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or CD-ROM drive that is failing. Make sure any removable storage is properly connected and then restart your computer.
If you continue to receive this error message, contact the hardware manufacturer.
Status: Oxc00000e9
Info: An unexpected I/O error has occurred. "
καποια ιδέα για το τι πρέπει να γίνει και σε αυτό το πρόβλημα, εκτός του να ξαναστηθεί όλος απο την αρχή?
ευχαριστώ
vasilis50
Δημοσίευσηαπό g00fy » 19 Μάιος 2009, 12:28
Όταν κάνεις mount ένα drive, πριν κλείσεις τον υπολογιστή θα κάνεις unmount
umount /media/data
Αν έχεις sVista βάλε το DVD και εκκίνησε απο αυτό. Επέλεξε επιδιόρθωση.
Αν έχεις XP εκκίνηση απο το CD και επιλογή της επισκευής απο την κονσόλα (με πλήκτρο r) εκτελώντας
chkdsk c: /p /r
Η/Υ: Intel Pentium DualCore / 2GB RAM / nVidia Geforce 8400GS / Ubuntu 10.04 64bit
Η/Υ: Toshiba Tecra R10-10S / Ubuntu 9.10 64bit
motd: May the source be with you!
g00fy@ubuntu-gr.org:~$ cat /etc/γνώσεις.conf
Linux:kuru (όχι guru) / Προγραμματισμός:Ναί / Αγγλικά:Καλά
g00fy
Τοποθεσία: Σε όλη τη Μακεδονία!
Δημοσίευσηαπό linuxman » 26 Μάιος 2009, 23:25
Εδώ είναι πρόβλημα με τα παράθυρα , έχω καιρό να το κάνω και δεν θυμάμαι να σου δώσου την καλύτερη λύση .
Όσο για το λίνουξ δες εδώ viewtopic.php?f=9&t=999
