από dim721 » 02 Νοέμ 2009, 02:34
Το πρόβλημα με τη VGA ήταν ότι το καλώδιο που είχαμε συνδέσει δεν λειτουργούσε, τα αποτελέσματα για την κάρτα ήχου και την κάμερα τα έχω ήδη σε αρχεία txt. τα παραθέτω σε code.
Alsa
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.58
!!Script ran on: Sun Nov 1 22:56:32 UTC 2009
!!Linux Distribution
Ubuntu 9.10 \n \l DISTRIB_ID=Ubuntu DISTRIB_DESCRIPTION="Ubuntu 9.10"
!!DMI Information
Manufacturer: Clevo
Product Name: M660SRU
!!Kernel Information
Kernel release: 2.6.31-14-generic
Operating System: GNU/Linux
Architecture: i686
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: 1.0.20
Library version: 1.0.20
Utilities version: 1.0.20
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
ESound Daemon:
Installed - Yes (/usr/bin/esd)
Running - No
!!Soundcards recognised by ALSA
0 [VT82xx ]: HDA-Intel - HDA VIA VT82xx
HDA VIA VT82xx at 0xdc000000 irq 17
!!PCI Soundcards installed in the system
05:01.0 Audio device: VIA Technologies, Inc. VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller) (rev 10)
!!Advanced information - PCI Vendor/Device/Susbsystem ID's
05:01.0 0403: 1106:3288 (rev 10)
Subsystem: 1106:3288
!!Modprobe options (Sound related)
snd-atiixp-modem: index=-2
snd-intel8x0m: index=-2
snd-via82xx-modem: index=-2
snd-usb-audio: index=-2
snd-usb-us122l: index=-2
snd-usb-usx2y: index=-2
snd-usb-caiaq: index=-2
snd-cmipci: mpu_port=0x330 fm_port=0x388
snd-pcsp: index=-2
snd-hda-intel: power_save=10 power_save_controller=N
!!Loaded sound module options
!!Module: snd_hda_intel
bdl_pos_adj : 32,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : 0
id : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
model : <NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>,<NULL>
position_fix : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
power_save : 10
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
single_cmd : N
!!HDA-Intel Codec information
--startcollapse--
Codec: VIA VT1708
Address: 0
Function Id: 0x1
Vendor Id: 0x11061708
Subsystem Id: 0x15580668
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x10 [Audio Output] wcaps 0x411: Stereo
Converter: stream=0, channel=0
PCM:
rates [0x7e0]: 44100 48000 88200 96000 176400 192000
bits [0xa]: 16 24
formats [0x1]: PCM
Power: setting=D0, actual=D0
Node 0x11 [Audio Output] wcaps 0x411: Stereo
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x12 [Audio Output] wcaps 0x411: Stereo
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x13 [Audio Output] wcaps 0x411: Stereo
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x14 [Audio Output] wcaps 0x211: Stereo Digital
Digital:
Digital category: 0x0
PCM:
bits [0xa]: 16 24
formats [0x5]: PCM AC3
Node 0x15 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x14, stepsize=0x06, mute=1
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
rates [0x440]: 48000 192000
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 1
0x18
Node 0x16 [Audio Input] wcaps 0x100311: Stereo Digital
SDI-Select: 0
Digital: Validity
PCM:
rates [0x1f0]: 32000 44100 48000 88200 96000
bits [0xa]: 16 24
Connection: 1
0x26
Node 0x17 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x06, mute=1
Amp-In vals: [0x00 0x00] [0x19 0x19] [0x80 0x80] [0x00 0x00] [0x00 0x00] [0x80 0x80]
Connection: 6
0x10 0x24 0x1d 0x1e 0x21 0x13
Node 0x18 [Audio Selector] wcaps 0x300101: Stereo
Connection: 5
0x17 0x24 0x1d* 0x1e 0x21
Node 0x19 [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
Amp-Out caps: ofs=0x1b, nsteps=0x1b, stepsize=0x06, mute=1
Amp-Out vals: [0x00 0x00]
Connection: 1
0x11
Node 0x1a [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
Connection: 1
0x12
Node 0x1b [Audio Selector] wcaps 0x30010d: Stereo Amp-Out
Connection: 1
0x13
Node 0x1c [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
Amp-Out caps: N/A
Pincap 0x0000001c: OUT HP Detect
Pin Default 0x410110f2: [N/A] Line Out at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x2
Pin-ctls: 0x00:
Connection: 1
0x19
Node 0x1d [Pin Complex] wcaps 0x400101: Stereo
Pincap 0x00000334: IN OUT Detect
Vref caps: HIZ 50
Pin Default 0x01a19026: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x2, Sequence = 0x6
Pin-ctls: 0x21: IN VREF_50
Connection: 1
0x1a
Node 0x1e [Pin Complex] wcaps 0x400101: Stereo
Vref caps: HIZ 50
Pin Default 0x0181302e: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x2, Sequence = 0xe
Pin-ctls: 0x20: IN VREF_HIZ
Connection: 1
0x19
Node 0x1f [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Connection: 1
0x17
Node 0x20 [Pin Complex] wcaps 0x40010d: Stereo Amp-Out
Amp-Out vals: [0x0e 0x0e]
Pin Default 0x022140f0: [Jack] HP Out at Ext Front
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Connection: 1
0x17
Node 0x21 [Pin Complex] wcaps 0x400101: Stereo
Vref caps: HIZ 50
Pin Default 0x02a190f0: [Jack] Mic at Ext Front
Connection: 1
0x1b
Node 0x22 [Pin Complex] wcaps 0x400101: Stereo
Pincap 0x00000014: OUT Detect
Pin Default 0x410160f1: [N/A] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0xf, Sequence = 0x1
Pin-ctls: 0x00:
Connection: 1
0x1a
Node 0x23 [Pin Complex] wcaps 0x400101: Stereo
Pin Default 0x410120f4: [N/A] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0xf, Sequence = 0x4
Pin-ctls: 0x00:
Connection: 1
0x1b
Node 0x24 [Pin Complex] wcaps 0x400001: Stereo
Pincap 0x00000020: IN
Pin Default 0x99330127: [Fixed] CD at Int ATAPI
Conn = ATAPI, Color = Unknown
DefAssociation = 0x2, Sequence = 0x7
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x25 [Pin Complex] wcaps 0x400301: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x074411f0: [Jack] SPDIF Out at Ext Rear Panel
Conn = RCA, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x14
Node 0x26 [Pin Complex] wcaps 0x400201: Stereo Digital
Pincap 0x00010030: IN OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x47c421f0: [N/A] SPDIF In at Ext Rear Panel
Conn = RCA, Color = Grey
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Node 0x27 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 1
0x21
Codec: Motorola Si3054
Address: 1
Function Id: 0x2
Vendor Id: 0x10573055
Subsystem Id: 0x10573055
Modem Function Group: 0x1
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 11 Nov 1 21:56 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 10 Nov 1 21:56 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 9 Nov 1 21:56 /dev/snd/hwC0D1
crw-rw----+ 1 root audio 116, 8 Nov 1 21:56 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 7 Nov 1 21:56 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 6 Nov 1 21:56 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116, 5 Nov 1 21:56 /dev/snd/pcmC0D6c
crw-rw----+ 1 root audio 116, 4 Nov 1 21:56 /dev/snd/pcmC0D6p
crw-rw----+ 1 root audio 116, 3 Nov 1 21:56 /dev/snd/seq
crw-rw----+ 1 root audio 116, 2 Nov 1 21:56 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Nov 1 21:56 .
drwxr-xr-x 3 root root 260 Nov 1 21:56 ..
lrwxrwxrwx 1 root root 12 Nov 1 21:56 pci-0000:05:01.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: VT82xx [HDA VIA VT82xx], device 0: VT1708 Analog [VT1708 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: VT82xx [HDA VIA VT82xx], device 1: VT1708 Digital [VT1708 Digital]
Subdevices: 1/1
card 0: VT82xx [HDA VIA VT82xx], device 6: Si3054 Modem [Si3054 Modem]
Subdevices: 0/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 2/2
Subdevice #1: subdevice #1
Subdevices: 0/1
!!Amixer output
!!-------Mixer controls for card 0 [VT82xx]
Card hw:0 'VT82xx'/'HDA VIA VT82xx at 0xdc000000 irq 17'
Mixer name : 'VIA VT1708'
Components : 'HDA:11061708,15580668,00100700 HDA:10573055,10573055,00100700'
Controls : 28
Simple ctrls : 16
Simple mixer control 'Master Front',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-40.25dB] [on]
Front Right: Playback 0 [0%] [-40.25dB] [on]
Simple mixer control 'Headphone',0
Limits: Playback 0 - 27
Mono:
Front Left: Playback 14 [52%] [-22.75dB] [on]
Front Right: Playback 14 [52%] [-22.75dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Front Left: Playback 0 [0%] [-47.25dB] [off]
Front Right: Playback 0 [0%] [-47.25dB] [off]
Simple mixer control 'Front Mic',0
Mono:
Simple mixer control 'Line',0
Mono:
Simple mixer control 'CD',0
Mono:
Front Left: Playback 25 [81%] [3.50dB] [on]
Front Right: Playback 25 [81%] [3.50dB] [on]
Simple mixer control 'Mic',0
Mono:
Front Left: Playback 0 [0%] [-40.25dB] [off]
Front Right: Playback 0 [0%] [-40.25dB] [off]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Capture channels: Front Left - Front Right
Limits: Capture 0 - 20
Front Left: Capture 0 [0%] [0.00dB] [off]
Front Right: Capture 0 [0%] [0.00dB] [off]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [0.00dB] [on]
Front Right: Capture 0 [0%] [0.00dB] [on]
Simple mixer control 'Caller ID',0
Simple mixer control 'Independent HP',0
Capabilities: enum
Items: 'OFF' 'ON'
Item0: 'ON'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Stereo Mixer' 'Mic' 'Front Mic' 'Line' 'CD'
Item0: 'Mic'
Simple mixer control 'Off-hook',0
!!Alsactl output
--startcollapse--
state.VT82xx {
control.1 {
comment.access 'read write'
comment.type INTEGER
comment.count 2
comment.range '0 - 31'
comment.dbmin -4025
comment.dbmax 1400
iface MIXER
name 'Master Front Playback Volume'
value.0 0
value.1 0
control.2 {
comment.type BOOLEAN
comment.count 2
iface MIXER
name 'Master Front Playback Switch'
value.0 true
value.1 true
control.3 {
comment.count 2
comment.range '0 - 27'
comment.dbmin -4725
comment.dbmax 0
iface MIXER
name 'Front Playback Volume'
value.0 0
value.1 0
control.4 {
comment.count 2
iface MIXER
name 'Front Playback Switch'
value.0 false
value.1 false
control.5 {
comment.count 2
comment.dbmin -4725
comment.dbmax 0
iface MIXER
name 'Headphone Playback Volume'
value.0 14
value.1 14
control.6 {
comment.count 2
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
control.7 {
comment.count 2
comment.dbmin -4025
comment.dbmax 1400
iface MIXER
name 'Mic Playback Volume'
value.0 0
value.1 0
control.8 {
comment.count 2
iface MIXER
name 'Mic Playback Switch'
value.0 false
value.1 false
control.9 {
comment.count 2
comment.dbmin -4025
comment.dbmax 1400
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
control.10 {
comment.count 2
iface MIXER
name 'Front Mic Playback Switch'
value.0 true
value.1 true
control.11 {
comment.count 2
comment.dbmin -4025
comment.dbmax 1400
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
control.12 {
comment.count 2
iface MIXER
name 'Line Playback Switch'
value.0 true
value.1 true
control.13 {
comment.count 2
comment.dbmin -4025
comment.dbmax 1400
iface MIXER
name 'CD Playback Volume'
value.0 25
value.1 25
control.14 {
comment.count 2
iface MIXER
name 'CD Playback Switch'
value.0 true
value.1 true
control.15 {
comment.type ENUMERATED
comment.count 1
comment.item.0 OFF
comment.item.1 ON
iface MIXER
name 'Independent HP'
value ON
control.16 {
comment.count 2
comment.range '0 - 20'
comment.dbmin 0
comment.dbmax 3500
iface MIXER
name 'Capture Volume'
value.0 0
value.1 0
control.17 {
comment.count 2
iface MIXER
name 'Capture Switch'
value.0 false
value.1 false
control.18 {
comment.count 2
comment.dbmin 0
comment.dbmax 3500
iface MIXER
index 1
value.0 0
value.1 0
control.19 {
comment.count 2
iface MIXER
index 1
value.0 true
value.1 true
control.20 {
comment.count 1
comment.item.0 'Stereo Mixer'
comment.item.1 Mic
comment.item.2 'Front Mic'
comment.item.3 Line
comment.item.4 CD
iface MIXER
name 'Input Source'
value Mic
control.21 {
comment.access read
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.22 {
comment.access read
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.23 {
comment.type IEC958
comment.count 1
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
control.24 {
comment.count 1
iface MIXER
name 'IEC958 Playback Switch'
value false
control.25 {
comment.count 1
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
control.26 {
comment.count 1
iface MIXER
name 'Off-hook Switch'
value false
control.27 {
comment.count 1
iface MIXER
name 'Caller ID Switch'
value false
control.28 {
comment.access 'read write user'
comment.count 2
comment.range '0 - 255'
comment.tlv '0000000100000008ffffec1400000014'
comment.dbmin -5100
comment.dbmax 0
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
--endcollapse--
!!All Loaded Modules
Module
binfmt_misc
ppdev
vboxnetflt
vboxnetadp
vboxdrv
snd_hda_codec_si3054
snd_hda_codec_via
snd_hda_intel
snd_hda_codec
snd_hwdep
snd_pcm_oss
snd_mixer_oss
snd_pcm
snd_seq_dummy
snd_seq_oss
snd_seq_midi
snd_rawmidi
snd_seq_midi_event
snd_seq
snd_timer
snd_seq_device
snd
soundcore
snd_page_alloc
joydev
arc4
iptable_filter
ip_tables
x_tables
ecb
rtl8187
i2c_viapro
mac80211
uvcvideo
shpchp
psmouse
sdhci_pci
sdhci
nvidia
led_class
videodev
eeprom_93cx6
v4l1_compat
cfg80211
serio_raw
lp
parport
dm_raid45
xor
usbhid
via_agp
agpgart
sata_via
via_rhine
mii
video
output
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x1c 0x410110f2
0x1d 0x01a19026
0x1e 0x0181302e
0x1f 0x01014010
0x20 0x022140f0
0x21 0x02a190f0
0x22 0x410160f1
0x23 0x410120f4
0x24 0x99330127
0x25 0x074411f0
0x26 0x47c421f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D1/init_pin_configs:
/sys/class/sound/hwC0D1/driver_pin_configs:
/sys/class/sound/hwC0D1/user_pin_configs:
/sys/class/sound/hwC0D1/init_verbs:
!!ALSA/HDA dmesg
[ 11.237118] type=1505 audit(1257105399.163:21): operation="profile_replace" pid=889 name=/usr/sbin/tcpdump
[ 11.763842] HDA Intel 0000:05:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 11.763887] HDA Intel 0000:05:01.0: setting latency timer to 64
[ 11.763893] HDA Intel 0000:05:01.0: PCI: Disallowing DAC for device
[ 13.305583] cfg80211: World regulatory domain updated:
dmesg- Κώδικας: Επιλογή όλων
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.31-14-generic (buildd@rothera) (gcc version 4.4.1 (Ubuntu 4.4.1-4ubuntu8) ) #48-Ubuntu SMP Fri Oct 16 14:04:26 UTC 2009 (Ubuntu 2.6.31-14.48-generic)
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
[ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fe80000 (usable)
[ 0.000000] BIOS-e820: 000000007fe80000 - 000000007fe98000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007fe98000 - 000000007ff00000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007ff00000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x7fe80 max_arch_pfn = 0x100000
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009dc00 (usable)
[ 0.000000] modified: 000000000009dc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000007fe80000 (usable)
[ 0.000000] modified: 000000007fe80000 - 000000007fe98000 (ACPI data)
[ 0.000000] modified: 000000007fe98000 - 000000007ff00000 (ACPI NVS)
[ 0.000000] modified: 000000007ff00000 - 0000000080000000 (reserved)
[ 0.000000] modified: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] modified: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 3786a000 - 37fef9e6
[ 0.000000] Allocated new RAMDISK: 008ad000 - 010329e6
[ 0.000000] Move RAMDISK from 000000003786a000 - 0000000037fef9e5 to 008ad000 - 010329e5
[ 0.000000] ACPI: RSDP 000f8020 00024 (v02 PTLTD )
[ 0.000000] ACPI: XSDT 7fe8f23e 00084 (v01 PTLTD XSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 7fe97e66 000F4 (v03 VN896 PTLTW 06040000 PTL_ 000F4240)
[ 0.000000] ACPI: DSDT 7fe932ae 04B44 (v01 VIA PTL_ACPI 06040000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 7fe98fc0 00040
[ 0.000000] ACPI: APIC 7fe97f5a 0006A (v01 PTLTD APIC 06040000 LTP 00000000)
[ 0.000000] ACPI: MCFG 7fe97fc4 0003C (v01 PTLTD MCFG 06040000 LTP 00000000)
[ 0.000000] ACPI: SSDT 7fe90b35 0025F (v01 PmRef Cpu0Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe90a8f 000A6 (v01 PmRef Cpu7Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe909e9 000A6 (v01 PmRef Cpu6Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe90943 000A6 (v01 PmRef Cpu5Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe9089d 000A6 (v01 PmRef Cpu4Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe907f7 000A6 (v01 PmRef Cpu3Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe90751 000A6 (v01 PmRef Cpu2Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe906ab 000A6 (v01 PmRef Cpu1Tst 00003000 INTL 20050228)
[ 0.000000] ACPI: SSDT 7fe8f2c2 013E9 (v01 PmRef CpuPm 00003000 INTL 20050228)
[ 0.000000] 1158MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008a80a0] TEXT DATA BSS ==> [0000100000 - 00008a80a0]
[ 0.000000] #4 [000009dc00 - 0000100000] BIOS reserved ==> [000009dc00 - 0000100000]
[ 0.000000] #5 [00008a9000 - 00008ac130] BRK ==> [00008a9000 - 00008ac130]
[ 0.000000] #6 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #7 [00008ad000 - 00010329e6] NEW RAMDISK ==> [00008ad000 - 00010329e6]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] found SMP MP-table at [c00f8050] f8050
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007fe80
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x0007fe80
[ 0.000000] On node 0 totalpages: 523789
[ 0.000000] free_area_init_node: node 0, pgdat c0784900, node_mem_map c1033200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2318 pages used for memmap
[ 0.000000] HighMem zone: 294260 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x03] address[0xfecc0000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 3, version 3, address 0xfecc0000, GSI 24-47
[ 0.000000] ACPI: IRQ10 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 2 I/O APICs
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 48
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages at c203d000, static data 35612 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519695
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.31-14-generic root=UUID=4e0b8da9-4f13-4c7e-a72e-667358f794b7 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 10477760 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007fe80)
[ 0.000000] Memory: 2051252k/2095616k available (4565k kernel code, 43148k reserved, 2143k data, 540k init, 1186312k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1d000 - 0xfffff000 ( 904 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc078e000 - 0xc0815000 ( 540 kB)
[ 0.000000] .data : 0xc0575554 - 0xc078d308 (2143 kB)
[ 0.000000] .text : 0xc0100000 - 0xc0575554 (4565 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] NR_IRQS:2304 nr_irqs:512
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1595.877 MHz processor.
[ 0.002122] Console: colour VGA+ 80x25
[ 0.002127] console [tty0] enabled
[ 0.004016] Calibrating delay loop (skipped), value calculated using timer frequency.. 3191.75 BogoMIPS (lpj=6383508)
[ 0.004049] Security Framework initialized
[ 0.004081] AppArmor: AppArmor initialized
[ 0.004091] Mount-cache hash table entries: 512
[ 0.004286] Initializing cgroup subsys ns
[ 0.004294] Initializing cgroup subsys cpuacct
[ 0.004299] Initializing cgroup subsys memory
[ 0.004308] Initializing cgroup subsys freezer
[ 0.004311] Initializing cgroup subsys net_cls
[ 0.004333] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.004336] CPU: L2 cache: 1024K
[ 0.004340] CPU: Physical Processor ID: 0
[ 0.004342] CPU: Processor Core ID: 0
[ 0.004347] mce: CPU supports 6 MCE banks
[ 0.004359] CPU0: Thermal monitoring enabled (TM2)
[ 0.004364] using mwait in idle threads.
[ 0.004373] Performance Counters: Core2 events, Intel PMU driver.
[ 0.004386] ... version: 2
[ 0.004388] ... bit width: 40
[ 0.004390] ... generic counters: 2
[ 0.004392] ... value mask: 000000ffffffffff
[ 0.004395] ... max period: 000000007fffffff
[ 0.004397] ... fixed-purpose counters: 3
[ 0.004399] ... counter mask: 0000000700000003
[ 0.004405] Checking 'hlt' instruction... OK.
[ 0.023368] ACPI: Core revision 20090521
[ 0.036643] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.040001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.040001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.040001] ..... (found apic 0 pin 0) ...
[ 0.083029] ....... works.
[ 0.083031] CPU0: Intel(R) Pentium(R) Dual CPU T2330 @ 1.60GHz stepping 0d
[ 0.084001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.004000] Initializing CPU#1
[ 0.004000] Calibrating delay using timer specific routine.. 3192.15 BogoMIPS (lpj=6384319)
[ 0.004000] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.004000] CPU: L2 cache: 1024K
[ 0.004000] CPU: Physical Processor ID: 0
[ 0.004000] CPU: Processor Core ID: 1
[ 0.004000] mce: CPU supports 6 MCE banks
[ 0.004000] CPU1: Thermal monitoring enabled (TM2)
[ 0.004000] x86 PAT enabled: cpu 1, old 0x7040600070406, new 0x7010600070106
[ 0.170047] CPU1: Intel(R) Pentium(R) Dual CPU T2330 @ 1.60GHz stepping 0d
[ 0.170066] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.172035] Brought up 2 CPUs
[ 0.172038] Total of 2 processors activated (6383.91 BogoMIPS).
[ 0.172110] CPU0 attaching sched-domain:
[ 0.172114] domain 0: span 0-1 level MC
[ 0.172118] groups: 0 1
[ 0.172125] CPU1 attaching sched-domain:
[ 0.172127] domain 0: span 0-1 level MC
[ 0.172131] groups: 1 0
[ 0.172238] Booting paravirtualized kernel on bare hardware
[ 0.172268] regulator: core version 0.5
[ 0.172268] Time: 21:56:28 Date: 11/01/09
[ 0.172268] NET: Registered protocol family 16
[ 0.172284] EISA bus registered
[ 0.172298] ACPI: bus type pci registered
[ 0.172393] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 5
[ 0.172397] PCI: MCFG area at e0000000 reserved in E820
[ 0.172399] PCI: Using MMCONFIG for extended config space
[ 0.172402] PCI: Using configuration type 1 for base access
[ 0.176510] bio: create slab <bio-0> at 0
[ 0.176817] ACPI: EC: Look up EC in DSDT
[ 0.180013] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.188077] ACPI: Interpreter enabled
[ 0.188083] ACPI: (supports S0 S3 S4 S5)
[ 0.188112] ACPI: Using IOAPIC for interrupt routing
[ 0.196272] ACPI: EC: GPE = 0xb, I/O: command/status = 0x66, data = 0x62
[ 0.196275] ACPI: EC: driver started in interrupt mode
[ 0.196563] ACPI: No dock devices found.
[ 0.196683] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.196714] pci 0000:00:00.0: reg 10 32bit mmio: [0xd0000000-0xd7ffffff]
[ 0.196763] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.196768] pci 0000:00:02.0: PME# disabled
[ 0.196872] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.196878] pci 0000:00:03.0: PME# disabled
[ 0.196975] pci 0000:00:0f.0: reg 10 io port: [0x4cb0-0x4cb7]
[ 0.196984] pci 0000:00:0f.0: reg 14 io port: [0x4ca4-0x4ca7]
[ 0.196994] pci 0000:00:0f.0: reg 18 io port: [0x4ca8-0x4caf]
[ 0.197004] pci 0000:00:0f.0: reg 1c io port: [0x4ca0-0x4ca3]
[ 0.197013] pci 0000:00:0f.0: reg 20 io port: [0x4c80-0x4c8f]
[ 0.197023] pci 0000:00:0f.0: reg 24 io port: [0x4400-0x44ff]
[ 0.197126] pci 0000:00:0f.1: reg 20 io port: [0x4c90-0x4c9f]
[ 0.197246] pci 0000:00:10.0: reg 20 io port: [0x4c00-0x4c1f]
[ 0.197285] pci 0000:00:10.0: supports D1 D2
[ 0.197288] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.197293] pci 0000:00:10.0: PME# disabled
[ 0.197364] pci 0000:00:10.1: reg 20 io port: [0x4c20-0x4c3f]
[ 0.197402] pci 0000:00:10.1: supports D1 D2
[ 0.197405] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.197411] pci 0000:00:10.1: PME# disabled
[ 0.197481] pci 0000:00:10.2: reg 20 io port: [0x4c40-0x4c5f]
[ 0.197519] pci 0000:00:10.2: supports D1 D2
[ 0.197522] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.197528] pci 0000:00:10.2: PME# disabled
[ 0.197600] pci 0000:00:10.3: reg 20 io port: [0x4c60-0x4c7f]
[ 0.197639] pci 0000:00:10.3: supports D1 D2
[ 0.197641] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.197647] pci 0000:00:10.3: PME# disabled
[ 0.197693] pci 0000:00:10.4: reg 10 32bit mmio: [0xdc400000-0xdc4000ff]
[ 0.197756] pci 0000:00:10.4: supports D1 D2
[ 0.197759] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.197764] pci 0000:00:10.4: PME# disabled
[ 0.198018] pci 0000:00:12.0: reg 10 io port: [0x4800-0x48ff]
[ 0.198027] pci 0000:00:12.0: reg 14 32bit mmio: [0xdc400400-0xdc4004ff]
[ 0.198086] pci 0000:00:12.0: supports D1 D2
[ 0.198088] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.198094] pci 0000:00:12.0: PME# disabled
[ 0.198426] pci 0000:02:00.0: reg 10 32bit mmio: [0xd9000000-0xd9ffffff]
[ 0.198442] pci 0000:02:00.0: reg 14 64bit mmio: [0xc0000000-0xcfffffff]
[ 0.198457] pci 0000:02:00.0: reg 1c 64bit mmio: [0xda000000-0xdbffffff]
[ 0.198466] pci 0000:02:00.0: reg 24 io port: [0x5000-0x507f]
[ 0.198475] pci 0000:02:00.0: reg 30 32bit mmio: [0x000000-0x01ffff]
[ 0.198589] pci 0000:00:02.0: bridge io port: [0x5000-0x5fff]
[ 0.198594] pci 0000:00:02.0: bridge 32bit mmio: [0xd9000000-0xdbffffff]
[ 0.198603] pci 0000:00:02.0: bridge 64bit mmio pref: [0xc0000000-0xcfffffff]
[ 0.198675] pci 0000:00:03.0: bridge io port: [0x6000-0x7fff]
[ 0.198681] pci 0000:00:03.0: bridge 32bit mmio: [0xd8800000-0xd8ffffff]
[ 0.198691] pci 0000:00:03.0: bridge 64bit mmio pref: [0xd8000000-0xd87fffff]
[ 0.198748] pci 0000:05:01.0: reg 10 64bit mmio: [0xdc000000-0xdc003fff]
[ 0.198810] pci 0000:05:01.0: PME# supported from D0 D3hot D3cold
[ 0.198816] pci 0000:05:01.0: PME# disabled
[ 0.198891] pci 0000:00:13.0: bridge 32bit mmio: [0xdc000000-0xdc0fffff]
[ 0.198951] pci 0000:06:04.0: reg 10 32bit mmio: [0x000000-0x00007f]
[ 0.199015] pci 0000:06:04.0: supports D1 D2
[ 0.199018] pci 0000:06:04.0: PME# supported from D0 D1 D2 D3hot
[ 0.199024] pci 0000:06:04.0: PME# disabled
[ 0.199069] pci 0000:06:04.1: reg 10 32bit mmio: [0x000000-0x0000ff]
[ 0.199134] pci 0000:06:04.1: supports D1 D2
[ 0.199137] pci 0000:06:04.1: PME# supported from D0 D1 D2 D3hot
[ 0.199142] pci 0000:06:04.1: PME# disabled
[ 0.199190] pci 0000:06:04.3: reg 10 32bit mmio: [0x000000-0x0000ff]
[ 0.199254] pci 0000:06:04.3: supports D1 D2
[ 0.199257] pci 0000:06:04.3: PME# supported from D0 D1 D2 D3hot
[ 0.199263] pci 0000:06:04.3: PME# disabled
[ 0.199326] pci 0000:00:13.1: transparent bridge
[ 0.199335] pci 0000:00:13.1: bridge 32bit mmio: [0xdc100000-0xdc1fffff]
[ 0.199376] pci_bus 0000:00: on NUMA node 0
[ 0.199381] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.199685] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEGC._PRT]
[ 0.199755] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE0C._PRT]
[ 0.199885] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.SP2P._PRT]
[ 0.199980] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2PE._PRT]
[ 0.214840] ACPI: PCI Interrupt Link [ALKA] (IRQs 16 17 18 19 20 21 22 23) *9, disabled.
[ 0.214957] ACPI: PCI Interrupt Link [ALKB] (IRQs 16 17 18 19 20 21 22 23) *10, disabled.
[ 0.215072] ACPI: PCI Interrupt Link [ALKC] (IRQs 22) *11, disabled.
[ 0.215181] ACPI: PCI Interrupt Link [ALKD] (IRQs 21) *3, disabled.
[ 0.215328] ACPI: PCI Interrupt Link [LNKA] (IRQs *9 10 11 12)
[ 0.215472] ACPI: PCI Interrupt Link [LNKB] (IRQs 9 *10 11 12)
[ 0.215615] ACPI: PCI Interrupt Link [LNKC] (IRQs 9 10 *11 12)
[ 0.215758] ACPI: PCI Interrupt Link [LNKD] (IRQs 9 10 11 12) *3
[ 0.216013] SCSI subsystem initialized
[ 0.216034] libata version 3.00 loaded.
[ 0.216067] usbcore: registered new interface driver usbfs
[ 0.216067] usbcore: registered new interface driver hub
[ 0.216068] usbcore: registered new device driver usb
[ 0.216078] ACPI: WMI: Mapper loaded
[ 0.216080] PCI: Using ACPI for IRQ routing
[ 0.228010] Bluetooth: Core ver 2.15
[ 0.228017] NET: Registered protocol family 31
[ 0.228018] Bluetooth: HCI device and connection manager initialized
[ 0.228022] Bluetooth: HCI socket layer initialized
[ 0.228025] NetLabel: Initializing
[ 0.228027] NetLabel: domain hash size = 128
[ 0.228029] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.228047] NetLabel: unlabeled traffic allowed by default
[ 0.242106] pnp: PnP ACPI init
[ 0.242141] ACPI: bus type pnp registered
[ 0.245201] pnp: PnP ACPI: found 10 devices
[ 0.245205] ACPI: ACPI bus type pnp unregistered
[ 0.245211] PnPBIOS: Disabled by ACPI PNP
[ 0.245229] system 00:01: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.245233] system 00:01: iomem range 0xf0012000-0xf0012fff has been reserved
[ 0.245237] system 00:01: iomem range 0xf0013000-0xf0013fff has been reserved
[ 0.245247] system 00:06: iomem range 0x0-0x9ffff could not be reserved
[ 0.245250] system 00:06: iomem range 0xd0000000-0xd7ffffff has been reserved
[ 0.245254] system 00:06: iomem range 0xe0000-0xfffff could not be reserved
[ 0.245258] system 00:06: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.245262] system 00:06: iomem range 0xffee0000-0xffefffff has been reserved
[ 0.245265] system 00:06: iomem range 0xfec00000-0xfec0ffff could not be reserved
[ 0.245269] system 00:06: iomem range 0xfee00000-0xfee0ffff could not be reserved
[ 0.245277] system 00:07: ioport range 0x200-0x20f has been reserved
[ 0.245280] system 00:07: ioport range 0x400-0x40f has been reserved
[ 0.245284] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[ 0.245288] system 00:07: ioport range 0xfe10-0xfe11 has been reserved
[ 0.245291] system 00:07: ioport range 0xfe00-0xfe00 has been reserved
[ 0.245295] system 00:07: ioport range 0x4000-0x407f has been reserved
[ 0.245298] system 00:07: ioport range 0x4100-0x411f has been reserved
[ 0.280016] AppArmor: AppArmor Filesystem Enabled
[ 0.280097] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.280100] pci 0000:00:01.0: IO window: disabled
[ 0.280108] pci 0000:00:01.0: MEM window: disabled
[ 0.280113] pci 0000:00:01.0: PREFETCH window: disabled
[ 0.280125] pci 0000:02:00.0: BAR 6: can't allocate mem resource [0xd0000000-0xcfffffff]
[ 0.280128] pci 0000:00:02.0: PCI bridge, secondary bus 0000:02
[ 0.280132] pci 0000:00:02.0: IO window: 0x5000-0x5fff
[ 0.280140] pci 0000:00:02.0: MEM window: 0xd9000000-0xdbffffff
[ 0.280146] pci 0000:00:02.0: PREFETCH window: 0x000000c0000000-0x000000cfffffff
[ 0.280155] pci 0000:00:03.0: PCI bridge, secondary bus 0000:03
[ 0.280159] pci 0000:00:03.0: IO window: 0x6000-0x7fff
[ 0.280167] pci 0000:00:03.0: MEM window: 0xd8800000-0xd8ffffff
[ 0.280173] pci 0000:00:03.0: PREFETCH window: 0x000000d8000000-0x000000d87fffff
[ 0.280183] pci 0000:00:13.0: PCI bridge, secondary bus 0000:05
[ 0.280186] pci 0000:00:13.0: IO window: disabled
[ 0.280193] pci 0000:00:13.0: MEM window: 0xdc000000-0xdc0fffff
[ 0.280198] pci 0000:00:13.0: PREFETCH window: disabled
[ 0.280216] pci 0000:00:13.1: PCI bridge, secondary bus 0000:06
[ 0.280218] pci 0000:00:13.1: IO window: disabled
[ 0.280225] pci 0000:00:13.1: MEM window: 0xdc100000-0xdc1fffff
[ 0.280231] pci 0000:00:13.1: PREFETCH window: disabled
[ 0.280250] pci 0000:00:01.0: setting latency timer to 64
[ 0.280263] pci 0000:00:02.0: power state changed by ACPI to D0
[ 0.280272] alloc irq_desc for 27 on node -1
[ 0.280275] alloc kstat_irqs on node -1
[ 0.280283] pci 0000:00:02.0: PCI INT A -> GSI 27 (level, low) -> IRQ 27
[ 0.280289] pci 0000:00:02.0: setting latency timer to 64
[ 0.280299] alloc irq_desc for 31 on node -1
[ 0.280301] alloc kstat_irqs on node -1
[ 0.280306] pci 0000:00:03.0: PCI INT A -> GSI 31 (level, low) -> IRQ 31
[ 0.280312] pci 0000:00:03.0: setting latency timer to 64
[ 0.280321] pci 0000:00:13.0: setting latency timer to 64
[ 0.280330] pci 0000:00:13.1: setting latency timer to 64
[ 0.280336] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.280339] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.280343] pci_bus 0000:02: resource 0 io: [0x5000-0x5fff]
[ 0.280346] pci_bus 0000:02: resource 1 mem: [0xd9000000-0xdbffffff]
[ 0.280349] pci_bus 0000:02: resource 2 pref mem [0xc0000000-0xcfffffff]
[ 0.280352] pci_bus 0000:03: resource 0 io: [0x6000-0x7fff]
[ 0.280355] pci_bus 0000:03: resource 1 mem: [0xd8800000-0xd8ffffff]
[ 0.280359] pci_bus 0000:03: resource 2 pref mem [0xd8000000-0xd87fffff]
[ 0.280362] pci_bus 0000:05: resource 1 mem: [0xdc000000-0xdc0fffff]
[ 0.280365] pci_bus 0000:06: resource 1 mem: [0xdc100000-0xdc1fffff]
[ 0.280369] pci_bus 0000:06: resource 3 io: [0x00-0xffff]
[ 0.280372] pci_bus 0000:06: resource 4 mem: [0x000000-0xffffffff]
[ 0.280423] NET: Registered protocol family 2
[ 0.280556] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.280990] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.281685] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.282225] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.282229] TCP reno registered
[ 0.282406] NET: Registered protocol family 1
[ 0.282518] Trying to unpack rootfs image as initramfs...
[ 0.528768] Freeing initrd memory: 7702k freed
[ 0.535613] cpufreq-nforce2: No nForce2 chipset.
[ 0.535665] Scanning for low memory corruption every 60 seconds
[ 0.535820] audit: initializing netlink socket (disabled)
[ 0.535850] type=2000 audit(1257112588.532:1): initialized
[ 0.546611] highmem bounce pool size: 64 pages
[ 0.546619] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.548494] VFS: Disk quotas dquot_6.5.2
[ 0.548571] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.549260] fuse init (API version 7.12)
[ 0.549365] msgmni has been set to 1705
[ 0.549651] alg: No test for stdrng (krng)
[ 0.549665] io scheduler noop registered
[ 0.549668] io scheduler anticipatory registered
[ 0.549670] io scheduler deadline registered
[ 0.549727] io scheduler cfq registered (default)
[ 0.549739] pci 0000:00:00.0: MSI quirk detected; MSI disabled
[ 0.549755] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.778155] Switched to high resolution mode on CPU 1
[ 0.780059] Switched to high resolution mode on CPU 0
[ 2.148010] pci 0000:00:10.4: EHCI: BIOS handoff failed (BIOS bug?) 01010001
[ 2.148047] pci 0000:02:00.0: Boot video device
[ 2.148237] pcieport-driver 0000:00:02.0: setting latency timer to 64
[ 2.148417] pcieport-driver 0000:00:03.0: setting latency timer to 64
[ 2.148585] aer 0000:00:02.0:pcie02: AER service couldn't init device: no _OSC support
[ 2.148595] aer 0000:00:03.0:pcie02: AER service couldn't init device: no _OSC support
[ 2.148607] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.148687] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.151168] ACPI: AC Adapter [AC] (on-line)
[ 2.151259] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 2.151264] ACPI: Power Button [PWRF]
[ 2.151344] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
[ 2.151347] ACPI: Power Button [PWB]
[ 2.151400] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input2
[ 2.151405] ACPI: Sleep Button [SLPB]
[ 2.151461] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input3
[ 2.152387] ACPI: Lid Switch [LID]
[ 2.153508] ACPI: SSDT 7fe9164f 00261 (v01 PmRef Cpu0Ist 00003000 INTL 20050228)
[ 2.154614] ACPI: SSDT 7fe90d94 00518 (v01 PmRef Cpu0Cst 00003001 INTL 20050228)
[ 2.157522] Monitor-Mwait will be used to enter C-1 state
[ 2.157601] processor LNXCPU:00: registered as cooling_device0
[ 2.157608] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 2.158275] ACPI: SSDT 7fe918b0 001F2 (v01 PmRef Cpu1Ist 00003000 INTL 20050228)
[ 2.158749] ACPI: SSDT 7fe912ac 00085 (v01 PmRef Cpu1Cst 00003000 INTL 20050228)
[ 2.159883] processor LNXCPU:01: registered as cooling_device1
[ 2.159890] ACPI: Processor [CPU1] (supports 8 throttling states)
[ 2.170943] thermal LNXTHERM:01: registered as thermal_zone0
[ 2.170954] ACPI: Thermal Zone [THRM] (54 C)
[ 2.186608] thermal LNXTHERM:02: registered as thermal_zone1
[ 2.186619] ACPI: Thermal Zone [TZ0] (-73 C)
[ 2.186694] isapnp: Scanning for PnP cards...
[ 2.222903] ACPI: Battery Slot [BAT0] (battery present)
[ 2.541221] isapnp: No Plug & Play device found
[ 2.542616] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.544249] brd: module loaded
[ 2.544824] loop: module loaded
[ 2.544919] input: Macintosh mouse button emulation as /devices/virtual/input/input4
[ 2.545805] pata_via 0000:00:0f.1: version 0.3.4
[ 2.545869] pata_via 0000:00:0f.1: power state changed by ACPI to D0
[ 2.546076] scsi0 : pata_via
[ 2.546198] scsi1 : pata_via
[ 2.547091] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x4c90 irq 14
[ 2.547095] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x4c98 irq 15
[ 2.547241] alloc irq_desc for 21 on node -1
[ 2.547244] alloc kstat_irqs on node -1
[ 2.547253] pata_acpi 0000:00:0f.0: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 2.547301] pata_acpi 0000:00:0f.0: PCI INT B disabled
[ 2.547685] Fixed MDIO Bus: probed
[ 2.547728] PPP generic driver version 2.4.2
[ 2.547859] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.547885] ehci_hcd 0000:00:10.4: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 2.547908] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 2.547982] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 2.548035] ehci_hcd 0000:00:10.4: irq 21, io mem 0xdc400000
[ 2.560014] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 2.560114] usb usb1: configuration #1 chosen from 1 choice
[ 2.560151] hub 1-0:1.0: USB hub found
[ 2.560161] hub 1-0:1.0: 8 ports detected
[ 2.560244] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.560269] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.560310] alloc irq_desc for 20 on node -1
[ 2.560312] alloc kstat_irqs on node -1
[ 2.560319] uhci_hcd 0000:00:10.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.560327] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 2.560366] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 2.560400] uhci_hcd 0000:00:10.0: irq 20, io base 0x00004c00
[ 2.560495] usb usb2: configuration #1 chosen from 1 choice
[ 2.560530] hub 2-0:1.0: USB hub found
[ 2.560539] hub 2-0:1.0: 2 ports detected
[ 2.560596] alloc irq_desc for 22 on node -1
[ 2.560598] alloc kstat_irqs on node -1
[ 2.560604] uhci_hcd 0000:00:10.1: PCI INT B -> GSI 22 (level, low) -> IRQ 22
[ 2.560612] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 2.560649] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 2.560684] uhci_hcd 0000:00:10.1: irq 22, io base 0x00004c20
[ 2.560777] usb usb3: configuration #1 chosen from 1 choice
[ 2.560808] hub 3-0:1.0: USB hub found
[ 2.560816] hub 3-0:1.0: 2 ports detected
[ 2.560875] uhci_hcd 0000:00:10.2: PCI INT C -> GSI 21 (level, low) -> IRQ 21
[ 2.560883] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 2.560924] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 2.560948] uhci_hcd 0000:00:10.2: irq 21, io base 0x00004c40
[ 2.561054] usb usb4: configuration #1 chosen from 1 choice
[ 2.561087] hub 4-0:1.0: USB hub found
[ 2.561094] hub 4-0:1.0: 2 ports detected
[ 2.561150] alloc irq_desc for 23 on node -1
[ 2.561153] alloc kstat_irqs on node -1
[ 2.561159] uhci_hcd 0000:00:10.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 2.561167] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 2.561210] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 2.561244] uhci_hcd 0000:00:10.3: irq 23, io base 0x00004c60
[ 2.561339] usb usb5: configuration #1 chosen from 1 choice
[ 2.561371] hub 5-0:1.0: USB hub found
[ 2.561379] hub 5-0:1.0: 2 ports detected
[ 2.561497] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.565833] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 2.568286] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.568294] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 2.568297] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 2.568301] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 2.568305] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 2.568380] mice: PS/2 mouse device common for all mice
[ 2.568586] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 2.568618] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 2.568754] device-mapper: uevent: version 1.0.3
[ 2.568880] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 2.568961] device-mapper: multipath: version 1.1.0 loaded
[ 2.568964] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 2.569124] EISA: Probing bus 0 at eisa.0
[ 2.569147] Cannot allocate resource for EISA slot 4
[ 2.569151] Cannot allocate resource for EISA slot 5
[ 2.569154] Cannot allocate resource for EISA slot 6
[ 2.569156] Cannot allocate resource for EISA slot 7
[ 2.569164] EISA: Detected 0 cards.
[ 2.569264] cpuidle: using governor ladder
[ 2.569267] cpuidle: using governor menu
[ 2.569912] TCP cubic registered
[ 2.570109] NET: Registered protocol family 10
[ 2.570682] lo: Disabled Privacy Extensions
[ 2.571114] NET: Registered protocol family 17
[ 2.571138] Bluetooth: L2CAP ver 2.13
[ 2.571140] Bluetooth: L2CAP socket layer initialized
[ 2.571144] Bluetooth: SCO (Voice Link) ver 0.6
[ 2.571146] Bluetooth: SCO socket layer initialized
[ 2.571182] Bluetooth: RFCOMM TTY layer initialized
[ 2.571186] Bluetooth: RFCOMM socket layer initialized
[ 2.571188] Bluetooth: RFCOMM ver 1.11
[ 2.572126] Using IPI No-Shortcut mode
[ 2.572249] PM: Resume from disk failed.
[ 2.572266] registered taskstats version 1
[ 2.572435] Magic number: 1:225:954
[ 2.572543] rtc_cmos 00:04: setting system clock to 2009-11-01 21:56:30 UTC (1257112590)
[ 2.572547] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 2.572550] EDD information not available.
[ 2.604453] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
[ 2.724401] ata1.00: ATAPI: TSSTcorp CDDVDW TS-L632H, TMC0, max UDMA/33
[ 2.756290] ata1.00: configured for UDMA/33
[ 2.760944] scsi 0:0:0:0: CD-ROM TSSTcorp CDDVDW TS-L632H TMC0 PQ: 0 ANSI: 5
[ 2.774153] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.774157] Uniform CD-ROM driver Revision: 3.20
[ 2.774284] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 2.774349] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 2.928085] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 2.928100] Freeing unused kernel memory: 540k freed
[ 2.928500] Write protecting the kernel text: 4568k
[ 2.928556] Write protecting the kernel read-only data: 1836k
[ 3.106512] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[ 3.106593] via-rhine 0000:00:12.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 3.122619] Linux agpgart interface v0.103
[ 3.128843] eth0: VIA Rhine II at 0xdc400400, 00:90:f5:6d:5b:02, IRQ 23.
[ 3.129557] eth0: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
[ 3.129807] sata_via 0000:00:0f.0: version 2.4
[ 3.129825] sata_via 0000:00:0f.0: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 3.129874] sata_via 0000:00:0f.0: routed to hard irq line 10
[ 3.129958] scsi2 : sata_via
[ 3.130061] scsi3 : sata_via
[ 3.130111] ata3: SATA max UDMA/133 cmd 0x4cb0 ctl 0x4ca4 bmdma 0x4c80 irq 21
[ 3.130115] ata4: SATA max UDMA/133 cmd 0x4ca8 ctl 0x4ca0 bmdma 0x4c88 irq 21
[ 3.130176] agpgart: Detected VIA P4M900 chipset
[ 3.157486] acpi device:07: registered as cooling_device2
[ 3.157654] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:04/device:05/input/input6
[ 3.157720] ACPI: Video Device [PERG] (multi-head: yes rom: no post: no)
[ 3.188203] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xd0000000
[ 3.233059] acpi device:1c: registered as cooling_device3
[ 3.233208] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:1a/input/input7
[ 3.233263] ACPI: Video Device [PPB] (multi-head: yes rom: no post: no)
[ 3.344017] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.353488] usb 1-3: configuration #1 chosen from 1 choice
[ 3.472016] usb 1-7: new high speed USB device using ehci_hcd and address 4
[ 3.508344] ata3.00: ATA-7: ST9160821AS, 3.ALC, max UDMA/133
[ 3.508348] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 3.524357] ata3.00: configured for UDMA/133
[ 3.524515] scsi 2:0:0:0: Direct-Access ATA ST9160821AS 3.AL PQ: 0 ANSI: 5
[ 3.524730] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 3.524743] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 3.524807] sd 2:0:0:0: [sda] Write Protect is off
[ 3.524810] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.524841] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.525019] sda: sda1 sda2 < sda5 >
[ 3.561797] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.610660] usb 1-7: configuration #1 chosen from 1 choice
[ 3.728015] ata4: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 3.856033] usb 2-2: new low speed USB device using uhci_hcd and address 2
[ 4.041190] usb 2-2: configuration #1 chosen from 1 choice
[ 4.052418] usbcore: registered new interface driver hiddev
[ 4.066974] input: Microsoft Microsoft Notebook/Mobile Optical Mouse 2.0 as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.0/input/input8
[ 4.067095] generic-usb 0003:045E:007D.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft Notebook/Mobile Optical Mouse 2.0] on usb-0000:00:10.0-2/input0
[ 4.067121] usbcore: registered new interface driver usbhid
[ 4.067125] usbhid: v2.6:USB HID core driver
[ 4.858073] xor: automatically using best checksumming function: pIII_sse
[ 4.877005] pIII_sse : 5862.000 MB/sec
[ 4.877007] xor: using function: pIII_sse (5862.000 MB/sec)
[ 4.880067] device-mapper: dm-raid45: initialized v0.2594b
[ 5.320280] PM: Starting manual resume from disk
[ 5.320285] PM: Resume from partition 8:5
[ 5.320288] PM: Checking hibernation image.
[ 5.320448] PM: Resume from disk failed.
[ 5.358287] EXT4-fs (sda1): barriers enabled
[ 5.378601] kjournald2 starting: pid 427, dev sda1:8, commit interval 5 seconds
[ 5.378614] EXT4-fs (sda1): delayed allocation enabled
[ 5.378619] EXT4-fs: file extents enabled
[ 5.394006] EXT4-fs: mballoc enabled
[ 5.394027] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 6.183827] type=1505 audit(1257112594.110:2): operation="profile_load" pid=450 name=/usr/share/gdm/guest-session/Xsession
[ 6.187033] type=1505 audit(1257112594.111:3): operation="profile_load" pid=451 name=/sbin/dhclient3
[ 6.187959] type=1505 audit(1257112594.111:4): operation="profile_load" pid=451 name=/usr/lib/NetworkManager/nm-dhcp-client.action
[ 6.188461] type=1505 audit(1257112594.115:5): operation="profile_load" pid=451 name=/usr/lib/connman/scripts/dhclient-script
[ 6.244352] type=1505 audit(1257112594.171:6): operation="profile_load" pid=452 name=/usr/bin/evince
[ 6.258805] type=1505 audit(1257112594.183:7): operation="profile_load" pid=452 name=/usr/bin/evince-previewer
[ 6.267417] type=1505 audit(1257112594.191:8): operation="profile_load" pid=452 name=/usr/bin/evince-thumbnailer
[ 6.288499] type=1505 audit(1257112594.215:9): operation="profile_load" pid=454 name=/usr/lib/cups/backend/cups-pdf
[ 6.289584] type=1505 audit(1257112594.215:10): operation="profile_load" pid=454 name=/usr/sbin/cupsd
[ 6.293362] type=1505 audit(1257112594.219:11): operation="profile_load" pid=455 name=/usr/sbin/tcpdump
[ 7.449679] Adding 6032368k swap on /dev/sda5. Priority:-1 extents:1 across:6032368k
[ 7.686634] udev: starting version 147
[ 8.408095] cfg80211: Calling CRDA to update world regulatory domain
[ 8.622046] lp: driver loaded but no devices found
[ 8.773484] Linux video capture interface: v2.00
[ 9.113567] nvidia: module license 'NVIDIA' taints kernel.
[ 9.113573] Disabling lock debugging due to kernel taint
[ 9.316184] EXT4-fs (sda1): internal journal on sda1:8
[ 9.328814] sdhci: Secure Digital Host Controller Interface driver
[ 9.328818] sdhci: Copyright(c) Pierre Ossman
[ 9.331636] sdhci-pci 0000:06:04.1: SDHCI controller found [1524:0750] (rev 0)
[ 9.331660] alloc irq_desc for 17 on node -1
[ 9.331663] alloc kstat_irqs on node -1
[ 9.331673] sdhci-pci 0000:06:04.1: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 9.331755] Registered led device: mmc0::
[ 9.331804] mmc0: SDHCI controller on PCI [0000:06:04.1] using PIO
[ 9.331817] sdhci-pci 0000:06:04.3: SDHCI controller found [1524:0751] (rev 0)
[ 9.331831] sdhci-pci 0000:06:04.3: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 9.331877] Registered led device: mmc1::
[ 9.331910] mmc1: SDHCI controller on PCI [0000:06:04.3] using PIO
[ 9.370015] alloc irq_desc for 24 on node -1
[ 9.370020] alloc kstat_irqs on node -1
[ 9.370030] nvidia 0000:02:00.0: PCI INT A -> GSI 24 (level, low) -> IRQ 24
[ 9.370042] nvidia 0000:02:00.0: setting latency timer to 64
[ 9.370227] NVRM: loading NVIDIA UNIX x86 Kernel Module 185.18.36 Fri Aug 14 17:18:04 PDT 2009
[ 9.447879] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.489743] uvcvideo: Found UVC 1.00 device USB2.0 Camera (0402:5606)
[ 9.550057] input: USB2.0 Camera as /devices/pci0000:00/0000:00:10.4/usb1/1-3/1-3:1.0/input/input9
[ 9.550138] usbcore: registered new interface driver uvcvideo
[ 9.550143] USB Video Class driver (v0.1.0)
[ 10.045071] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.107961] Synaptics Touchpad, model: 1, fw: 6.3, id: 0x81a0b1, caps: 0xa04713/0x204000
[ 10.146333] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input10
[ 10.151193] phy0: Selected rate control algorithm 'minstrel'
[ 10.152177] phy0: hwaddr 00:15:af:9b:6b:a7, RTL8187vB (default) V1 + rtl8225
[ 10.162913] rtl8187: Customer ID is 0x00
[ 10.162962] Registered led device: rtl8187-phy0::tx
[ 10.162987] Registered led device: rtl8187-phy0::rx
[ 10.163025] usbcore: registered new interface driver rtl8187
[ 11.188905] __ratelimit: 3 callbacks suppressed
[ 11.188910] type=1505 audit(1257105399.115:13): operation="profile_replace" pid=885 name=/sbin/dhclient3
[ 11.189854] type=1505 audit(1257105399.115:14): operation="profile_replace" pid=885 name=/usr/lib/NetworkManager/nm-dhcp-client.action
[ 11.190362] type=1505 audit(1257105399.115:15): operation="profile_replace" pid=885 name=/usr/lib/connman/scripts/dhclient-script
[ 11.196341] type=1505 audit(1257105399.123:16): operation="profile_replace" pid=886 name=/usr/bin/evince
[ 11.210999] type=1505 audit(1257105399.135:17): operation="profile_replace" pid=886 name=/usr/bin/evince-previewer
[ 11.220140] type=1505 audit(1257105399.147:18): operation="profile_replace" pid=886 name=/usr/bin/evince-thumbnailer
[ 11.232501] type=1505 audit(1257105399.159:19): operation="profile_replace" pid=888 name=/usr/lib/cups/backend/cups-pdf
[ 11.233598] type=1505 audit(1257105399.159:20): operation="profile_replace" pid=888 name=/usr/sbin/cupsd
[ 13.305588] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 13.305592] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 13.305595] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 13.305598] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 13.305601] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 13.305604] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.541087] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 17.543883] eth0: link down
[ 17.544420] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 23.553032] vboxdrv: Trying to deactivate the NMI watchdog permanently...
[ 23.553037] vboxdrv: Successfully done.
[ 23.553039] vboxdrv: Found 2 processor cores.
[ 23.553147] vboxdrv: fAsync=0 offMin=0x1bc offMax=0xbe8
[ 23.553206] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[ 23.553209] vboxdrv: Successfully loaded version 3.0.8_OSE (interface 0x000e0000).
[ 23.690291] ppdev: user-space parallel port driver
[ 62.168664] wlan0: authenticate with AP 00:13:33:09:82:e4
[ 62.170407] wlan0: authenticated
[ 62.170411] wlan0: associate with AP 00:13:33:09:82:e4
[ 62.172402] wlan0: RX AssocResp from 00:13:33:09:82:e4 (capab=0x411 status=0 aid=2)
[ 62.172406] wlan0: associated
[ 62.174939] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 72.752011] wlan0: no IPv6 routers present
Την δοκίμασα με διάφορες εφαρμογες ekiga,vlc,firefox αλλά και στο Sound Preferences δεν είχε την επιλογή κάποιου Hardware. Είδα μήπως ακόμα μήπως είχε κολλήσε κάποια process και να τα αποτελέσματα :
top - 01:27:49 up 3:31, 2 users, load average: 0.23, 0.17, 0.13
Tasks: 158 total, 3 running, 155 sleeping, 0 stopped, 0 zombie
Cpu(s): 25.4%us, 5.3%sy, 0.0%ni, 68.8%id, 0.0%wa, 0.0%hi, 0.5%si, 0.0%st
Mem: 2060252k total, 1067576k used, 992676k free, 51336k buffers
Swap: 6032368k total, 0k used, 6032368k free, 635228k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2792 dimitris 20 0 461m 99m 33m R 37 4.9 13:44.60 firefox
1313 root 20 0 179m 40m 12m S 15 2.0 13:39.14 Xorg
2057 dimitris 20 0 74796 42m 13m S 9 2.1 6:43.32 compiz.real
3790 dimitris 20 0 38080 12m 9404 R 1 0.6 0:03.30 gnome-terminal
2134 dimitris 20 0 32992 12m 9876 S 1 0.6 1:58.00 multiload-apple
1948 dimitris 20 0 146m 3640 2744 S 1 0.2 0:08.95 pulseaudio
4 root 15 -5 0 0 0 S 0 0.0 0:00.40 ksoftirqd/0
53 root 15 -5 0 0 0 S 0 0.0 0:00.86 kondemand/1
747 root 15 -5 0 0 0 S 0 0.0 0:03.71 phy0
3832 dimitris 20 0 2468 1184 884 R 0 0.1 0:00.08 top
1 root 20 0 2528 1500 1120 S 0 0.1 0:01.07 init
2 root 15 -5 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root RT -5 0 0 0 S 0 0.0 0:00.00 migration/0
5 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/0
6 root RT -5 0 0 0 S 0 0.0 0:00.00 migration/1
7 root 15 -5 0 0 0 S 0 0.0 0:00.09 ksoftirqd/1
8 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/1
Γνώσεις ⇛ Linux: Λίγες ┃ Προγραμματισμός: Ελάχιστα ┃ Αγγλικά: Καλά
Λειτουργικό : Ubuntu 12.04 LTS 64-bit (en_US.UTF-8)
Προδιαγραφές Desktop ⇛ AMD Phenom II 2.8GHz │ 4GiB RAM │GeForce 9600 GT 512MiB |
Audio device: NVIDIA Corporation MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio (rev a1)
Προδιαγραφές Laptop ⇛
CPU: 2x Intel Pentium Dual CPU T2330 1.60GHz ‖ RAM 4 GB ‖ Clevo M660SRU
Κάρτες γραφικών: nVidia G86 [GeForce 8400M G]
Δίκτυα: eth0: VIA Technologies, Inc. VT6102 [Rhine-II] | wlan0:Realtek Semiconductor Corp. RTL8187 Wireless Adapter
