Έχω ένα laptop εδώ που έχει winmodem - το HDAUDIO Soft Data Fax Modem with SmartCP.
Μπήκα στο linmodems.org και κατέβασα το πρόγραμμα scanModem το οποίο μου έδωσε τα εξής αποτέλεσματα:
Προσπάθησα όμως μετά να μπω στο linuxant.com και είναι πεσμένο. Τι μπορώ να κάνω για να στήσω αυτό το wimodem;
Only plain text email is forwarded by the Discuss@Linmodems.org List Server,
as HTML can contain viruses. Use as the email Subject Line:
YourName, YourCountry kernel 2.6.22-14-generic
With this Subject Line cogent experts will be alerted, and useful case names left in the Archive.
YourCountry will enable Country specific guidance. Linux experts in YourCountry
can be found through: http://www.linux.org/groups/index.html.
They will know your Country's modem code, which may be essential for dialup service.
Responses from Discuss@Linmodems.org are sometimes blocked by an Internet Provider mail filters.
So in a day, also check the Archived responses at http://www.linmodems.org
-------------------------- System information ----------------------------
CPU=i686,
Linux version 2.6.22-14-generic (buildd@vernadsky) (gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)) #1 SMP Wed Oct 10 06:00:47 GMT 2007
scanModem update of: 2008_08_09
There are no blacklisted modem drivers in /etc/modprobe* files
Attached USB devices are:
ID 045e:0083 Microsoft Corp. Basic Optical Mouse
USB modems not recognized
For candidate card in slot 00:1b.0, firmware information and bootup diagnostics are:
PCI slot PCI ID SubsystemID Name
00:1b.0 8086:27d8 103c:30bb Audio device: Intel Corporation 82801G
Modem interrupt assignment and sharing:
22: 501 0 IO-APIC-fasteoi HDA Intel
--- Bootup diagnostics for card in PCI slot 00:1b.0 ----
[ 149.484000] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
[ 149.484000] PCI: Setting latency timer of device 0000:00:1b.0 to 64
===== Advanced Linux Sound Architecture (ALSA) diagnostics =====
The ALSA packages provide audio support and also drivers for some modems.
ALSA diagnostics are written during bootup to /proc/asound/ folders.
The ALSA verion is 1.0.14
The modem cards detected by "aplay -l" are: None
The /proc/asound/pcm file reports:
00-01: Conexant Digital : Conexant Digital : playback 1
00-00: CONEXANT Analog : CONEXANT Analog : playback 1 : capture 1
about /proc/asound/cards:
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xd8240000 irq 22
PCI slot 00:1b.0 has a High Definition Audio Card
The drivers are in the kernel modules tree at:
/lib/modules/2.6.22-14-generic/ubuntu/media/snd-hda-intel/snd-hda-intel.ko
=== Finished firmware and bootup diagnostics, next deducing cogent software. ===
Predictive diagnostics for card in bus 00:1b.0:
Modem chipset detected on
NAME="Audio device: Intel Corporation 82801G "
CLASS=0403
PCIDEV=8086:27d8
SUBSYS=103c:30bb
IRQ=22
HDA=8086:27d8
SOFT=8086:27d8.HDA
ArchivedChip=0x14f12bfa
CodecClass=14f1
IDENT=hsfmodem
Driver=hsfmodem-drivers
For candidate modem in: 00:1b.0
0403 Audio device: Intel Corporation 82801G
Primary device ID: 8086:27d8
Subsystem PCI_id 103c:30bb
Softmodem codec or chipset from diagnostics:
from Archives: 0x14f12bfa
Support type needed or chipset: hsfmodem
Writing DOCs/Intel.txt
For owners of a Dell PCs with Conexant HSF modems, a driver source package with full speed enabled is available, but requires driver compiling. Read DOCs/Conexant.txt
Start at http://www.linuxant.com/drivers/hsf/dow ... icense.php to find the
hsfmodem package matching your System. For several Linux distros, there are
precompiled drivers matched to specific kernels. These have within the FileName,
your KernelVersion: 2.6.22_14_generic
They can be found through http://www.linuxant.com/drivers/hsf/full/downloads.php
A more precise location may be given a few paragraphs below.
If an EXACT Match with your your KernelVersion is not found, one of the
"Generic packages with source" near the bottom of the page must be used.
Downloaded packages must be moved into the Linux partition (home folder is OK)
and unzipped with:
unzip hsf*.zip
The installation command for a .deb suffic packages is, with root/adm permission:
sudo dpkg -i hsf*.deb
while for .rpm suffix it is, with:
rpm -i hsf*.rpm
From http://www.linuxant.com/drivers/hsf/ful ... tu-x86.php
download hsfmodem-7.68.00.12full_k2.6.22_14_generic_ubuntu_i386.deb.zip
Under Linux unpack with:
$ unzip hsfmodem*.zip
Then install with:
$ sudo dpkg -i hsfmodem*.deb
Subsequently, the modem should be found with
$ sudo wvdialconf /etc/wvdial.conf
Edit in your personal information with:
$ sudo gedit /etc/wvdial.conf
and try dialing out with:
$ sudo wvdial.
See DOCs/Testing.txt for details.
Writing DOCs/Conexant.txt
Completed candidate modem analyses.
The base of the UDEV device file system is: /dev/.udev
Versions adequately match for the compiler installed: 4.1.3
and the compiler used in kernel assembly: 4.1.3
Minimal compiling resources appear complete:
make utility - /usr/bin/make
Compiler version 4.1
linuc_headers base folder /lib/modules/2.6.22-14-generic/build
However some compilations and executable functions may need additional files,
in the FileNames.h (so called kernel "h"eaders) collection installed in /usr/include/ .
For martian_modem, additional required packages are n. The also required headers of package libc6 are commonly installed by default.
Compiling hsfmodem drivers does require linux-libc-dev and libc6-dev packages, for kernels 2.6.24 and later versions.
In not included on your install CD, search for them at http://packages.ubuntu.com
or comparable Repository for other Linux distros.
When compiling ALSA drivers, the utility "patch" will also be needed.
If a driver compilation fails, with message including some lack of some FileName.h (stdio.h for example), then
Some additional kernel-header files need installation to /usr/include. The minimal additional packages are libc6-dev
and any of its dependents, under Ubuntu linux-libc-dev
If an alternate ethernet connection is available,
$ apt-get update
$ apt-get -s install linux-kernel-devel
will install needed packages.
For Debian/Ubuntu related distributions, run the following command to display the needed package list:
Otherwise packages have to be found through http://packages.ubuntu.com
Once downloaded and transferred into a Linux partition,
they can be installed alltogether with:
$ sudo dpkg -i *.deb
Checking pppd properties:
-rwsr-xr-- 1 root dip 269256 2007-10-04 19:57 /usr/sbin/pppd
In case of an "error 17" "serial loopback" problem, see:
http://linmodems.technion.ac.il/linmode ... 02637.html
To enable dialout without Root permission do:
$ su - root (not for Ubuntu)
sudo chmod a+x /usr/sbin/pppd
or under Ubuntu related Linuxes
Checking settings of: /etc/ppp/options
asyncmap 0
noauth
crtscts
lock
hide-password
modem
proxyarp
lcp-echo-interval 30
lcp-echo-failure 4
noipx
In case of a message like:
Warning: Could not modify /etc/ppp/pap-secrets: Permission denied
see http://linmodems.technion.ac.il/bigarch ... 04656.html
Read Modem/DOCs/YourSystem.txt concerning other COMM channels: eth0
Which can interfere with Browser naviagation.
Don't worry about the following, it is for experts should trouble shooting be necessary.
Checking for modem support lines:
/device/modem symbolic link:
slmodemd created symbolic link /dev/ttySL0:
Within /etc/udev/ files:
Within /etc/modprobe.conf files:
/etc/modprobe.d/alsa-base:options snd-atiixp-modem index=-2
/etc/modprobe.d/alsa-base:options snd-via82xx-modem index=-2
/etc/modprobe.d/blacklist-modem:# Uncomment these entries in order to blacklist unwanted modem drivers
/etc/modprobe.d/blacklist-modem:# blacklist snd-atiixp-modem
/etc/modprobe.d/blacklist-modem:# blacklist snd-via82xx-modem
Within any ancient /etc/devfs files:
Within ancient kernel 2.4.n /etc/module.conf files:
--------- end modem support lines --------
