wine on Ubuntu  Το θέμα επιλύθηκε
Συντονιστές: adem1, konnn
Για ubuntu
Για kubuntu
wine on Ubuntu
Δημοσίευσηαπό manin » 17 Μαρ 2024, 14:25
Καλησπέρα,
προσπαθώ να εγκαταστήσω το wine, αλλά δεν τα πολυκαταφέρνω.
έγραψε:manin@manos-PC:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.5 LTS"
manin@manos-PC:~$ uname -r
5.15.0-100-generic
manin@manos-PC:~$ sudo apt install --install-recommends winehq-stable
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
winehq-stable : Depends: wine-stable (= 8.0.1~bionic-1)
E: Unable to correct problems, you have held broken packages.
manin@manos-PC:~$ sudo apt update --fix-missing
Hit:1 http://gr.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease
Hit:3 http://ppa.launchpad.net/cdemu/ppa/ubuntu focal InRelease
Hit:4 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
1 package can be upgraded. Run 'apt list --upgradable' to see it.
manin@manos-PC:~$ sudo apt upgrade
Calculating upgrade... Done
# News about significant security updates, features and services will
# appear here to raise awareness and perhaps tease /r/Linux ;)
# Use 'pro config set apt_news=false' to hide this and future APT news.
The following packages have been kept back:
shim-signed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
manin@manos-PC:~$ apt list --upgradable -a
Listing... Done
shim-signed/focal-security 1.40.9+15.7-0ubuntu1 amd64 [upgradable from: 1.40.7+15.4-0ubuntu9]
shim-signed/now 1.40.7+15.4-0ubuntu9 amd64 [installed,upgradable to: 1.40.9+15.7-0ubuntu1]
shim-signed/focal 1.40.3+15+1533136590.3beb971-0ubuntu1 amd64
Πραγματικά μπερδεύτηκα στο τι φταίει...
Καμιά ιδέα;
Ευχαριστώ
1 Γνώσεις Linux: Αρχάριος ┃ Προγραμματισμού: Αρχάριος ┃ Αγγλικών: Πολύ καλό
2 Ubuntu 16.04 xenial 64bit (en_US.UTF-8),
3 Intel Core i5-7600 CPU @ 3.50GHz ‖ RAM 15935 MiB ‖ MSI Z170A PC MATE (MS-7971) - MSI MS-7971
4 Advanced Micro Devices, Inc. [AMD/ATI] Oland XT [Radeon HD 8670 / R7 250/350] [1002:6610]
5 enp7s0: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
manin
Re: wine on Ubuntu
Δημοσίευσηαπό Maras » 17 Μαρ 2024, 18:12
Καλησπέρα,
Τρέχεις την έκδοση Focal 20.04, αλλά το αποθετήριο που ψάχνεις να εγκαταστήσεις το wine είναι για το Bionic (18.04):
λογικό να παραπονιέται για συμβατότητα.
Άλλαξε το και ξανά-δοκίμασε.
Re: wine on Ubuntu
Δημοσίευσηαπό manin » 17 Μαρ 2024, 19:22
Κατάρχάς σε ευχαριστώ για την απάντηση.
Δοκίμασα με τον παρακάτω οδηγό για την έκδοση 20.04...
Πήρα πάλι το ίδιο μήνυμα.
https://tecadmin.net/how-to-install-win ... ntu-20-04/
Επίσης δοκίμασα και από το ubuntu software και πήρα πάλι μήνυμα λάθους...
Δε θα έπρεπε από εκεί να ψάξει μόνο του τη σωστή έκδοση;
Hit:4 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:5 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:6 http://security.ubuntu.com/ubuntu focal-security InRelease
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-el) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:56 and /etc/apt/sources.list.d/winehq-focal.sources:1
Τελευταία επεξεργασία από manin και 18 Μαρ 2024, 10:59, έχει επεξεργασθεί 2 φορά/ες συνολικά
manin
Re: wine on Ubuntu
Δημοσίευσηαπό Maras » 17 Μαρ 2024, 21:43
Τώρα έβαλες και τα 2 αποθετήρια, πρέπει να βγει το παλιό, προφανώς έκανες αναβάθμιση από την μία έκδοση στην άλλη στο Ubuntu και δεν καθάρισες τα παλιά αποθετήρια.
Ποιον οδηγό ακολούθησες, δεν επισύναψες το link.
Δες εδώ πως θα αφαιρέσεις τα παλιό:
https://askubuntu.com/questions/43345/how-to-remove-a-repository
Ξετίκαρε από την γραφική εφαρμογή Software & Updates, στην καρτέλα Other Software, την επιλογή:
Re: wine on Ubuntu
Δημοσίευσηαπό manin » 18 Μαρ 2024, 12:00
Καλημέρα,
δεν το πιάνω...
Έκανα αυτά τα που έγραψες και ακολουθώ από την αρχή τον οδηγό για 20.04
https://tecadmin.net/how-to-install-wine-on-ubuntu-20-04/
Κάνοντας apt-update, μου βγάζει τα παρακάτω...
Hit:1 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:2 http://ppa.launchpad.net/cdemu/ppa/ubuntu focal InRelease
Hit:3 http://gr.archive.ubuntu.com/ubuntu focal InRelease
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target Translations (main/i18n/Translation-el) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/winehq-focal.sources:1
manin@manos-PC:~$ cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 20.04.5 LTS _Focal Fossa_ - Release amd64 (20220831)]/ focal main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://gr.archive.ubuntu.com/ubuntu/ focal main restricted
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal main restricted
## Major bug fix updates produced after the final release of the
## distribution.
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://gr.archive.ubuntu.com/ubuntu/ focal universe
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal universe
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://gr.archive.ubuntu.com/ubuntu/ focal multiverse
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal multiverse
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb-src http://gr.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu focal partner
# deb-src http://archive.canonical.com/ubuntu focal partner
deb http://security.ubuntu.com/ubuntu focal-security restricted main
# deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu focal-security universe
# deb-src http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu focal-security multiverse
# deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
# deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ bionic main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ focal main
deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
manin@manos-PC:/etc/apt/sources.list.d$ cat winehq-focal.sources
Types: deb
URIs: https://dl.winehq.org/wine-builds/ubuntu
Suites: focal
Components: main
Architectures: amd64 i386
Signed-By: /etc/apt/keyrings/winehq-archive.key
Εντωμεταξύ πριν ξεκινήσω πάλι τον οδηγό, δοκίμασα από το Ubuntu SOftware και μου έβγαλε Unmet dependencies
manin
Re: wine on Ubuntu
Δημοσίευσηαπό Maras » 18 Μαρ 2024, 12:35
Βάλε μια διεση στο παρακάτω αρχείο:
στην τελευταία γραμμή, να γίνει έτσι:
#deb https://dl.winehq.org/wine-builds/ubuntu/ focal main
Re: wine on Ubuntu
Δημοσίευσηαπό manin » 18 Μαρ 2024, 17:10
Πραγματικά δεν καταλαβαίνω...Γιατί να βγάλω την τελευταία γραμμή;
Όπως και να χει την έβγαλα...
Ξαναέτρεξα τον οδηγό από την αρχή...Και στο update μου έβγαλε πάλι τα warnings!!!
manin
Re: wine on Ubuntu
Δημοσίευσηαπό Maras » 18 Μαρ 2024, 17:29
Δεν βλέπω κάποιο warning στο τελευταίο update που δίνεις.
Ρίξε μια ματιά εδώ σε όλες τι απαντήσεις για να καταλάβεις το πρόβλημά σου:
https://askubuntu.com/questions/760896/ ... iple-times
και εδώ για να καταλάβεις την διαφορά του αρχείου /etc/apt/sources.list και του φακέλου /etc/apt/sources.list.d:
https://unix.stackexchange.com/questions/407328/what-is-the-benefit-of-etc-apt-sources-list-d-over-etc-apt-sources-list
Εάν θυμάμαι καλά ο 2ος τρόπος (φάκελος) εισήχθηκε κάπου στην έκδοση 20.04.
Re: wine on Ubuntu  Το θέμα επιλύθηκε
Δημοσίευσηαπό Maras » 19 Μαρ 2024, 21:13
Ψάξε επίσης και για διπλότυπα αρχεία μέσα στον φάκελο: /etc/apt/sources.list.d
Και εδώ ένας οδηγός για το wine που εφαρμόζει σε Ubuntu: https://wiki.winehq.org/Ubuntu
Re: wine on Ubuntu
Δημοσίευσηαπό manin » 20 Απρ 2024, 12:00
Καλησπέρα, τελικά το εγκατέστησα, αλλά όχι με το σωστό τρόπο...
Κράσαρε το γραφικό περιβάλλον...Λίγες μέρες νωρίτερα μου έβγαζε για ένα πρόβλημα στο δίσκο, αλλά το παρέβλεπα γιατί είχα προσθέσει κι ένα 2ο και νόμιζα ότι ήταν από αυτόν...
Άλλαξα δίσκο, κοινούργια εγκατάσταση και όλα κομπλέ!
Ευχαριστώ
manin
