ilias@ilias-desktop:~$ sudo dpkg --configure -a
Γίνεται εγκατάσταση odbcinst1debian1 (2.2.11-16build1) ...
Γίνεται εγκατάσταση unixodbc (2.2.11-16build1) ...
Processing triggers for libc6 ...
ldconfig deferred processing now taking place
ilias@ilias-desktop:~$ sudo wget
http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
--18:14:37--
http://www.medibuntu.org/sources.list.d/hardy.list => `/etc/apt/sources.list.d/medibuntu.list'
Εύρεση του
www.medibuntu.org... 87.98.242.10
Connecting to
www.medibuntu.org|87.98.242.10|:80... συνδέθηκε.
Η αίτηση για HTTP στάλθηκε, αναμονή απάντησης... 200 OK
Μήκος: 226 [text/plain]
100%[====================================>] 226 --.--K/s
18:14:37 (48.98 MB/s) - `/etc/apt/sources.list.d/medibuntu.list' saved [226/226]
ilias@ilias-desktop:~$ apt-get
apt 0.7.9ubuntu17 for amd64 compiled on Apr 22 2008 15:20:34
Usage: apt-get [options] command
apt-get [options] install|remove pkg1 [pkg2 ...]
apt-get [options] source pkg1 [pkg2 ...]
apt-get is a simple command line interface for downloading and
installing packages. The most frequently used commands are update
and install.
Commands:
update - Retrieve new lists of packages
upgrade - Perform an upgrade
install - Install new packages (pkg is libc6 not libc6.deb)
remove - Remove packages
autoremove - Remove all automatic unused packages
purge - Remove and purge packages
source - Download source archives
build-dep - Configure build-dependencies for source packages
dist-upgrade - Distribution upgrade, see apt-get(8)
dselect-upgrade - Follow dselect selections
clean - Erase downloaded archive files
autoclean - Erase old downloaded archive files
check - Verify that there are no broken dependencies
Options:
-h This help text.
-q Loggable output - no progress indicator
-qq No output except for errors
-d Download only - do NOT install or unpack archives
-s No-act. Perform ordering simulation
-y Assume Yes to all queries and do not prompt
-f Attempt to correct a system with broken dependencies in place
-m Attempt to continue if archives are unlocatable
-u Show a list of upgraded packages as well
-b Build the source package after fetching it
-V Show verbose version numbers
-c=? Read this configuration file
-o=? Set an arbitrary configuration option, eg -o dir::cache=/tmp
See the apt-get(8), sources.list(5) and apt.conf(5) manual
pages for more information and options.
This APT has Super Cow Powers.
ilias@ilias-desktop:~$ sudo apt-get update && sudo apt-get install medibuntu-keyring && sudo apt-get update
Hit
http://gr.archive.ubuntu.com hardy Release.gpg
Αγνόησε
http://gr.archive.ubuntu.com hardy/main Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy/restricted Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy/universe Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy/multiverse Translation-el
Hit
http://gr.archive.ubuntu.com hardy-updates Release.gpg
Αγνόησε
http://gr.archive.ubuntu.com hardy-updates/main Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-updates/restricted Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-updates/universe Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-updates/multiverse Translation-el
Hit
http://gr.archive.ubuntu.com hardy-backports Release.gpg
Αγνόησε
http://gr.archive.ubuntu.com hardy-backports/main Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-backports/restricted Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-backports/universe Translation-el
Αγνόησε
http://gr.archive.ubuntu.com hardy-backports/multiverse Translation-el
Hit
Hit
Hit
Hit
http://archive.canonical.com hardy Release.gpg
Αγνόησε
http://archive.canonical.com hardy/partner Translation-el
Hit
http://gr.archive.ubuntu.com hardy/main Packages
Hit
http://gr.archive.ubuntu.com hardy/restricted Packages
Hit
http://gr.archive.ubuntu.com hardy/main Sources
Hit
http://gr.archive.ubuntu.com hardy/restricted Sources
Hit
http://gr.archive.ubuntu.com hardy/universe Packages
Hit
http://gr.archive.ubuntu.com hardy/universe Sources
Hit
http://gr.archive.ubuntu.com hardy/multiverse Packages
Hit
http://gr.archive.ubuntu.com hardy/multiverse Sources
Hit
http://gr.archive.ubuntu.com hardy-updates/main Packages
Hit
http://gr.archive.ubuntu.com hardy-updates/restricted Packages
Hit
http://gr.archive.ubuntu.com hardy-updates/main Sources
Hit
http://gr.archive.ubuntu.com hardy-updates/restricted Sources
Hit
Hit
http://gr.archive.ubuntu.com hardy-updates/universe Packages
Φέρε:1
http://packages.medibuntu.org hardy Release.gpg [189B]
Hit
http://gr.archive.ubuntu.com hardy-updates/universe Sources
Hit
http://gr.archive.ubuntu.com hardy-updates/multiverse Packages
Hit
http://gr.archive.ubuntu.com hardy-updates/multiverse Sources
Hit
http://gr.archive.ubuntu.com hardy-backports/main Packages
Hit
http://gr.archive.ubuntu.com hardy-backports/restricted Packages
Hit
http://gr.archive.ubuntu.com hardy-backports/universe Packages
Hit
http://gr.archive.ubuntu.com hardy-backports/multiverse Packages
Hit
http://gr.archive.ubuntu.com hardy-backports/main Sources
Hit
http://gr.archive.ubuntu.com hardy-backports/restricted Sources
Hit
http://gr.archive.ubuntu.com hardy-backports/universe Sources
Hit
http://gr.archive.ubuntu.com hardy-backports/multiverse Sources
Hit
http://archive.canonical.com hardy/partner Packages
Αγνόησε
http://packages.medibuntu.org hardy/free Translation-el
Αγνόησε
http://packages.medibuntu.org hardy/non-free Translation-el
Hit
http://archive.canonical.com hardy/partner Sources
Φέρε:2
http://packages.medibuntu.org hardy Release [9335B]
Αγνόησε
Φέρε:3
http://packages.medibuntu.org hardy/free Packages [5721B]
Φέρε:4
http://packages.medibuntu.org hardy/non-free Packages [7631B]
Μεταφορτώθηκαν 22,9kB σε 0s (25,3kB/s)
W: GPG error:
http://packages.medibuntu.org hardy Release: Οι παρακάτω υπογραφές δεν ήταν δυνατόν να επαληθευτούν επειδή δεν ήταν διαθέσιμο το δημόσιο κλειδί: NO_PUBKEY 2EBC26B60C5A2783
W: Ίσως να πρέπει να τρέξετε apt-get update για να διορθώσετε αυτά τα προβλήματα
Κατασκευή Δένδρου Εξαρτήσεων
Reading state information... Ολοκληρώθηκε
Aν τρέξετε 'apt-get f install' ίσως να διορθώσετε αυτά τα προβλήματα:
Τα ακόλουθα πακέτα έχουν ανεπίλυτες εξαρτήσεις:
sun-java6-bin: Εξαρτάται από: sun-java6-jre (= 6-06-0ubuntu1) αλλά δεν πρόκειται να εγκατασταθεί
E: Ανεπίλυτες εξαρτήσεις. Δοκιμάστε 'apt-get -f install' χωρίς να ορίσετε πακέτο (ή καθορίστε μια λύση).
Hit
Αγνόησε
Αγνόησε
Αγνόησε
Αγνόησε
Hit
Αγνόησε
Αγνόησε
Αγνόησε
Αγνόησε
Hit
Αγνόησε
Αγνόησε
Αγνόησε
Αγνόησε
Hit
Hit
Hit
Hit
Αγνόησε
Hit
Hit
Hit
Φέρε:1
Αγνόησε
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Hit
Αγνόησε
Φέρε:2
Αγνόησε
Hit
Hit
Hit
Hit
Μεταφορτώθηκαν 190B σε 0s (468B/s)
W: GPG error:
ilias@ilias-desktop:~$ sudo apt-get upgrade
Ίσως να πρέπει να τρέξετε apt-get -f install για να διορθώσετε αυτά τα προβλήματα.
E: Ανεπίλυτες εξαρτήσεις. Δοκιμάστε με το -f.
ilias@ilias-desktop:~$ sudo apt-get install libdvdcss2
ilias@ilias-desktop:~$ sudo apt-get install w64codecs
το w64codecs είναι ήδη η τελευταία έκδοση.
ilias@ilias-desktop:~$ apt-get f install'
> sudo apt-get install mplayer mozilla-mplayer vlc
> sudo apt-get install smplayer
μαγκα αυτα εκανα
σωστα η λαθος δεν εχω ιδεα...
λεω να παω για καφε
αν μπορεις παντως βοηθησε με!!!!!
ευαριστω παντως για το χρονο και την υπομονη σου
