Ubuntu Broken Boot
Ubuntu Broken Boot
Δημοσίευσηαπό akounadis » 16 Ιαν 2018, 19:17
Distributor ID: Ubuntu
Description: Ubuntu 16.04.3 LTS
Release: 16.04
Codename: xenial
Linux rory-f***-the-system 4.10.0-28-generic #32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Με τον 4.10 έχω αυτό
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] Linux version 4.10.0-28-generic (buildd@lgw01-12) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017 (Ubuntu 4.10.0-28.32~16.04.2-generic 4.10.17)
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.10.0-28-generic root=UUID=85c57e9b-bbf2-4e14-b3aa-57e7f357a0a8 ro quiet splash vt.handoff=7
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] KERNEL supported cpus:
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] Intel GenuineIntel
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] AMD AuthenticAMD
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] Centaur CentaurHauls
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] e820: BIOS-provided physical RAM map:
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x00000000000907ff] usable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000090800-0x000000000009ffff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000006980afff] usable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x000000006980b000-0x000000006980bfff] ACPI NVS
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x000000006980c000-0x0000000078652fff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000078653000-0x0000000078694fff] ACPI data
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000078695000-0x0000000078ff7fff] ACPI NVS
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000078ff8000-0x00000000795fefff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027f7fffff] usable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] NX (Execute Disable) protection: active
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] SMBIOS 3.0 present.
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] DMI: Dell Inc. Inspiron 15 7000 Gaming/065C71, BIOS 01.00.03 01/10/2017
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] e820: last_pfn = 0x27f800 max_arch_pfn = 0x400000000
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] MTRR default type: write-back
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] MTRR fixed ranges enabled:
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 00000-9FFFF write-back
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] A0000-BFFFF uncachable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] C0000-FFFFF write-protect
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] MTRR variable ranges enabled:
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 0 base 0080000000 mask 7F80000000 uncachable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 1 base 007C000000 mask 7FFC000000 uncachable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 2 base 007B000000 mask 7FFF000000 uncachable
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 3 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 4 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 5 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 6 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 7 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 8 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] 9 disabled
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] e820: last_pfn = 0x6980b max_arch_pfn = 0x400000000
Jan 15 00:05:22 rory-f***-the-system kernel: [ 0.000000] found SMP MP-table at [mem 0x000fce40-0x000fce4f] mapped at [ffff934fc00fce40]
7,1 Top
Ενώ όταν αναβαθμίζεται στον 4.13 έχω αυτό και μένει σε μαύρη οθόνη μετά το login
Εγκατάσταση σε 17.04, 17.10 & 18.04 το ίδιο. Όλα αυτά μετά από clean install με 16.04 και εγκατεστημένο microcode firmware for intel CPUs (open source)
Είναι το μηχάνημα της υπογραφής. Δεν έχω εγκαταστήσει τον οδηγό της nvidia ακόμα.
Ποιά είναι η γνώμη σας.
akounadis
Τοποθεσία: Πειραιάς
Launchpad: akounadis
Re: Ubuntu Broken Boot
Δημοσίευσηαπό Maras » 17 Ιαν 2018, 01:44
Αρχικά να έχεις το νού σου για προβληματικό iso αρχείο. Επίσης η τελευταία έκδοση των 16.04 είναι η 16.04.3. Επιπλέον δοκίμασε καθώς βάζεις ένα cd με τα 17.04(ή όποια θέλεις) να πατήσεις ένα πλήκτρο όταν εμφανίζει το μικρό logo κάτω στην οθόνη, και να πας στα "Advanced options.." και από εκεί να δεις αν θα σου ανοίξει το γραφικό περιβάλλον επιλέγοντας "Try Ubuntu without installing".
Δημοσίευσηαπό akounadis » 17 Ιαν 2018, 18:31
Το πρόβλημα είναι και σε αναβάθμιση πυρήνα στην 16.04.3 απ τον 3.10 στον 3.13. Επίσης σε αναβάθμιση της 16.04 στην 17.04 χωρίς clean install και με clean install 17.04, 17.10 & 18.04 δε φορτώνει ούτε το live. Αυτή τη στιγμή με ukuu επιλέγω τον 3.10 για να εισέλθω.
akounadis
Τοποθεσία: Πειραιάς
Δημοσίευσηαπό Maras » 17 Ιαν 2018, 18:43
Δοκίμασε να μπεις με Live CD χωρίς όμως να περιμένεις να φορτώσει το περιβάλλον. Δες στο παρακάτω λινκ
https://help.ubuntu.com/community/BootOptions
στην παράγραφο Ubuntu CD Advanced Welcome Page Options
Μπορείς να μπεις σε Try mode?
Δημοσίευσηαπό akounadis » 17 Ιαν 2018, 18:52
μόλις έτρεξα το live της 16.04, εκανα εγκατάσταση και όταν έκανα τις αναβαθμίσεις και πέρασε από τον 3.10 σε 3.13 φτάνει μέχρι το login
akounadis
Τοποθεσία: Πειραιάς
Δημοσίευσηαπό the_eye » 17 Ιαν 2018, 20:37
Η 16.04 που έβαλες έχει τον 3.13 ;
Δημοσίευσηαπό akounadis » 17 Ιαν 2018, 20:47
Με την εγκατάσταση αυτόν έχει
Μόλις κάνω αναβάθμιση μετά την εγκατάσταση περνάει τον 4.13.
akounadis
Τοποθεσία: Πειραιάς
Δημοσίευσηαπό the_eye » 18 Ιαν 2018, 00:28
Ναι, γιατί με μπέρδεψες όταν έγραψες 3.13.
Σε εμένα πάντως λειτουργεί μια χαρά
Linux dimitris 4.13.0-29-generic #32~16.04.1-Ubuntu SMP Fri Jan 12 13:08:03 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Δημοσίευσηαπό Maras » 18 Ιαν 2018, 02:13
Όταν λες φτάνει μέχρι το login τι εννοείς? Μετά τα διαπιστευτήρια που δίνεις έχεις black screen?
Δημοσίευσηαπό akounadis » 18 Ιαν 2018, 10:42
Ακριβώς, αφού δίνω κωδικό για είσοδο μετά έχω black screen.
Έκαψα ένα νέο iso της 18.04 φτάνει στο install ubuntu ή try without ubuntu και όταν επιλέγω το live ή την εγκατάσταση μένει στο σημείο με το λογότυπο που φορτώνει.
Με το ukuu όλοι οι πυρήνες από τον 4.11 και μετά παρουσιάζουν hardware error εκτός από τους 4.10 και πριν.
Στα διαγνωστικά της Dell στο PSA pro-boot system assessment αναφέρει πως όλα τα υλικά είναι εντάξει (μνήμες, cpu κτλ)
Από την υποστήριξη της Dell ανέφεραν πως δεν υπάρχει πρόβλημα υλικού.
Αν και οι πυρήνες 4.10 και πριν παρουσίαζαν το ίδιο τότε θα ήμουν σίγουρος για αστοχία υλικού. Θα κάνω εγκατάσταση ξανά slackware, compile ένα νέο πυρήνα και θα κάνω επανεκκίνηση χωρίς τα διαθέσιμα loadable modules και μετά θα κάνω ένα
make modules στο /src/linux να δω τι στο καλό γίνεται. Δε θα τα δω ένα ένα γιατί δεν έχω περισσότερο χρόνο. Στο μεσοδιάστημα αν έχετε κάποια ιδέα θα χαρώ.
akounadis
Τοποθεσία: Πειραιάς
