Debian : Διαγραφή των κλειστών οδηγών της κάρτας γραφικών.  Το θέμα επιλύθηκε
Δημοσίευσηαπό Tassos10 » 19 Ιαν 2018, 14:36
Έχω τον εξής φορητό υπολογιστή :
1 debian 8.10 3.16.0-4-amd64 64bit (en_US.UTF-8, GNOME default)
2 Intel Core2 Duo CPU P8600 2.40GHz ‖ RAM 5983 MiB ‖ Quanta 3603 - HP Pavilion dv5 Notebook PC
3 nVidia G96M [GeForce 9600M GT] [10de:0649] {nvidia}
4 wlan1: Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection [8086:4237] ⋮ eth0: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 02)
$ inxi -Fx
System: Host: UserPc Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4) Console: tty 0
Distro: Debian GNU/Linux 8
Machine: System: Hewlett-Packard product: HP Pavilion dv5 Notebook PC v: F.0C serial: CNF8421Q1Z
Mobo: Quanta model: 3603 v: 02.20 serial: CNF8421Q1Z Bios: Hewlett-Packard v: F.0C date: 09/18/2008
CPU: Dual core Intel Core2 Duo P8600 (-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 9575
Clock Speeds: 1: 800 MHz 2: 2400 MHz
Graphics: Card: NVIDIA G96M [GeForce 9600M GT] bus-ID: 01:00.0
Display Server: X.org 1.16.4 driver: nvidia tty size: 211x54 Advanced Data: N/A for root out of X
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: 6000 bus-ID: 03:00.0
IF: eth0 state: down mac: 00:23:8b:14:f3:54
Card-2: Intel PRO/Wireless 5100 AGN [Shiloh] Network Connection
driver: iwlwifi v: in-tree: bus-ID: 02:00.0
IF: wlan1 state: up mac: 00:21:5d:a3:b9:fe
Drives: HDD Total Size: 120.0GB (79.2% used) ID-1: /dev/sda model: INTEL_SSDSC2BW12 size: 120.0GB temp: 0C
Partition: ID-1: / size: 106G used: 85G (85%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 4.90GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 37.0C mobo: N/A gpu: 0.0:46C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 175 Uptime: 7 min Memory: 909.1/5983.2MB Init: systemd runlevel: 5 Gcc sys: 4.9.2
Client: Shell (bash 4.3.301) inxi: 2.1.28
Όπως βλέπετε με Debian 8 GNU/Linux και η κάρτα γραφικών του είναι nVidia!
Λόγο του ότι κάποια στιγμή δεν γινόταν αλλιώς, έπρεπε να εγκαταστήσω τους κλειστούς οδηγούς της nVidia. Έτσι λοιπόν ακολούθησα τις επίσημες οδηγίες και όλα πήγαν μια χαρά.
Πλέον όμως θέλω να διαγράψω ή να απενεργοποιήσω τους κλειστούς οδηγούς της nVidia και να ενεργοποιήσω ή να εγκαταστήσω τους ελεύθερους.
Ακολουθώντας τις επίσημες οδηγίες, δυστυχώς για πρώτη φορά δε λειτούργησαν σωστά.
Η σειρά με την οποία εκτέλεσα τις εντολές ώστε να διαγράψω τους κλειστούς οδηγούς :
NVIDIA driver is still enabled in xorg.conf
The NVIDIA driver was just removed, but it is still enabled in the Xorg configuration. X cannot be (re-)started successfully until NVIDIA is disabled in the following config file(s): /etc/X11/xorg.conf
apt-get purge nvidia.
Reading package lists... Done
Building dependency tree
Note, selecting 'nvidia-340-updates' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-proxy' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-alternative--kmod-alias' for regex 'nvidia.'
Note, selecting 'nvidia-compute-profiler' for regex 'nvidia.'
Note, selecting 'libnvidia-cfg1-any' for regex 'nvidia.'
Note, selecting 'nvidia-cg-dev' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-doc' for regex 'nvidia.'
Note, selecting 'nvidia-libopencl1' for regex 'nvidia.'
Note, selecting 'nvidia-driver-bin-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-alternative' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-check' for regex 'nvidia.'
Note, selecting 'nvidia-349-updates' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-glcore' for regex 'nvidia.'
Note, selecting 'libnvidia-eglcore-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-alternative' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-smi' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-driver-bin' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-71xx-glx' for regex 'nvidia.'
Note, selecting 'nvidia-visual-profiler' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-driver-libs-i386' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-ia32' for regex 'nvidia.'
Note, selecting 'nvidia-358-updates' for regex 'nvidia.'
Note, selecting 'nvidia-vulkan-common' for regex 'nvidia.'
Note, selecting 'libnvidia-cfg1' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-alternatives-ia32' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glvnd-glx' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-cfg1' for regex 'nvidia.'
Note, selecting 'nvidia-vulkan-icd' for regex 'nvidia.'
Note, selecting 'nvidia-glx-dev' for regex 'nvidia.'
Note, selecting 'nvidia-persistenced' for regex 'nvidia.'
Note, selecting 'nvidia-driver' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-eglcore' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-source' for regex 'nvidia.'
Note, selecting 'nvidia-alternative-legacy-96xx' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-173xx-glx' for regex 'nvidia.'
Note, selecting 'nvidia-settings-legacy-340xx' for regex 'nvidia.'
Note, selecting 'nvidia-installer-cleanup' for regex 'nvidia.'
Note, selecting 'nvidia-cg-doc' for regex 'nvidia.'
Note, selecting 'nvidia-settings' for regex 'nvidia.'
Note, selecting 'libnvidia-egl-wayland-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-gdb' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-486' for regex 'nvidia.'
Note, selecting 'nvidia-opencl-common' for regex 'nvidia.'
Note, selecting 'nvidia-driver-libs-i386' for regex 'nvidia.'
Note, selecting 'libnvidia-encode1' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-support--v1' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-nvcuvid1' for regex 'nvidia.'
Note, selecting 'libxvmcnvidia1' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-dummy' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-mps' for regex 'nvidia.'
Note, selecting 'nvidia-glx' for regex 'nvidia.'
Note, selecting 'nvidia-libopencl1-ia32' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-kernel-support' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-driver' for regex 'nvidia.'
Note, selecting 'nvidia-325-updates' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-compiler' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-96xx-dev' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-686-pae' for regex 'nvidia.'
Note, selecting 'libnvidia-fatbinaryloader' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-i386' for regex 'nvidia.'
Note, selecting 'nvidia-libvdpau1-ia32' for regex 'nvidia.'
Note, selecting 'nvidia-xconfig' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-vdpau-driver' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-173xx-dev' for regex 'nvidia.'
Note, selecting 'nvidia-334-updates' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-cfg1' for regex 'nvidia.'
Note, selecting 'nvidia-egl-icd' for regex 'nvidia.'
Note, selecting 'nvidia-glx-ia32' for regex 'nvidia.'
Note, selecting 'libnvidia-glcore' for regex 'nvidia.'
Note, selecting 'nvidia-343-updates' for regex 'nvidia.'
Note, selecting 'nvidia-modprobe' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-ml1' for regex 'nvidia.'
Note, selecting 'nvidia-304' for regex 'nvidia.'
Note, selecting 'nvidia-current-updates' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-304xx-glx' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-amd64' for regex 'nvidia.'
Note, selecting 'nvidia-310' for regex 'nvidia.'
Note, selecting 'nvidia-313' for regex 'nvidia.'
Note, selecting 'nvidia-319' for regex 'nvidia.'
Note, selecting 'nvidia-352-updates' for regex 'nvidia.'
Note, selecting 'nvidia-nsight' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-opencl-icd' for regex 'nvidia.'
Note, selecting 'nvidia-support' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-driver-libs' for regex 'nvidia.'
Note, selecting 'nvidia-325' for regex 'nvidia.'
Note, selecting 'libnvidia-compiler-340.102' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-96xx-glx' for regex 'nvidia.'
Note, selecting 'libegl1-nvidia-legacy-340xx' for regex 'nvidia.'
Note, selecting 'nvidia-331' for regex 'nvidia.'
Note, selecting 'nvidia-334' for regex 'nvidia.'
Note, selecting 'nvidia-337' for regex 'nvidia.'
Note, selecting 'nvidia-361-updates' for regex 'nvidia.'
Note, selecting 'nvidia-cg-toolkit' for regex 'nvidia.'
Note, selecting 'nvidia-340' for regex 'nvidia.'
Note, selecting 'nvidia-343' for regex 'nvidia.'
Note, selecting 'nvidia-346' for regex 'nvidia.'
Note, selecting 'nvidia-349' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-encode1' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-debugger' for regex 'nvidia.'
Note, selecting 'nvidia-driver-binary' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-kernel-support' for regex 'nvidia.'
Note, selecting 'nvidia-352' for regex 'nvidia.'
Note, selecting 'nvidia-355' for regex 'nvidia.'
Note, selecting 'nvidia-358' for regex 'nvidia.'
Note, selecting 'libnvidia-fbc1' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-support' for regex 'nvidia.'
Note, selecting 'nvidia-opencl-icd' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-340.102' for regex 'nvidia.'
Note, selecting 'nvidia-361' for regex 'nvidia.'
Note, selecting 'nvidia-364' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-any' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-toolkit' for regex 'nvidia.'
Note, selecting 'nvidia-opencl-dev' for regex 'nvidia.'
Note, selecting 'libglx-nvidia0' for regex 'nvidia.'
Note, selecting 'nvidia-driver-libs' for regex 'nvidia.'
Note, selecting 'libnvidia-compiler-304.135' for regex 'nvidia.'
Note, selecting 'libnvidia-glcore-340.102' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-kernel-dkms' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-304xx-glx-i386' for regex 'nvidia.'
Note, selecting 'nvidia-opencl-profiler' for regex 'nvidia.'
Note, selecting 'libgles2-nvidia-legacy-340xx' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-kernel-340.102' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-ml1' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-alternative--kmod-alias' for regex 'nvidia.'
Note, selecting 'nvidia-310-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-driver-libs' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-legacy-340xx-glx' for regex 'nvidia.'
Note, selecting 'boinc-client-nvidia-cuda' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-96xx' for regex 'nvidia.'
Note, selecting 'libgles-nvidia1' for regex 'nvidia.'
Note, selecting 'libgles-nvidia2' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-2.6-amd64' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-nvcuvid1' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-304.135' for regex 'nvidia.'
Note, selecting 'libnvidia-egl-wayland' for regex 'nvidia.'
Note, selecting 'libnvidia-compiler' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-compiler' for regex 'nvidia.'
Note, selecting 'nvidia-319-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-kernel-support--v1' for regex 'nvidia.'
Note, selecting 'libnvidia-ifr1' for regex 'nvidia.'
Note, selecting 'nvidia-alternative--kmod-alias' for regex 'nvidia.'
Note, selecting 'nvidia-texture-tools' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-cuda1-i386' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-dkms' for regex 'nvidia.'
Note, selecting 'libnvidia-glcore-304.135' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-driver' for regex 'nvidia.'
Note, selecting 'nvidia-va-driver' for regex 'nvidia.'
Note, selecting 'xserver-xorg-video-nvidia-legacy-304xx' for regex 'nvidia.'
Note, selecting 'nvidia-337-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-kernel-dkms' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-profiler' for regex 'nvidia.'
Note, selecting 'nvidia-current' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-fbc1' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-glcore' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-kernel-source' for regex 'nvidia.'
Note, selecting 'xserver-xorg-video-nvidia-any' for regex 'nvidia.'
Note, selecting 'nvidia-346-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-opencl-icd' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-340.102' for regex 'nvidia.'
Note, selecting 'libnvidia-glcore-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-opencl-icd-ia32' for regex 'nvidia.'
Note, selecting 'libnvidia-compiler-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-173xx' for regex 'nvidia.'
Note, selecting 'nvidia-355-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-driver-bin' for regex 'nvidia.'
Note, selecting 'libgles1-nvidia-legacy-340xx' for regex 'nvidia.'
Note, selecting 'nvidia-libopencl1-dev' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-vdpau-driver' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-ia32-any' for regex 'nvidia.'
Note, selecting 'libnvidia-ml1' for regex 'nvidia.'
Note, selecting 'glvnd-nvidia-abi-375.20' for regex 'nvidia.'
Note, selecting 'nvidia-364-updates' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-kernel-support--v1' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-304' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-driver-libs-i386' for regex 'nvidia.'
Note, selecting 'nvidia-vdpau-driver-ia32' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-71xx' for regex 'nvidia.'
Note, selecting 'libnvidia-ptxjitcompiler' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-310' for regex 'nvidia.'
Note, selecting 'nvidia-alternative-legacy-173xx' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-313' for regex 'nvidia.'
Note, selecting 'nvidia-egl-common' for regex 'nvidia.'
Note, selecting 'nvidia-driver-bin-340.102' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-319' for regex 'nvidia.'
Note, selecting 'boinc-nvidia-cuda' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-325' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-304xx-cuda1' for regex 'nvidia.'
Note, selecting 'nvidia-vdpau-driver' for regex 'nvidia.'
Note, selecting 'nvidia-driver-bin' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-kernel-304.135' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-common' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-support-any' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-331' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-334' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-ifr1' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-337' for regex 'nvidia.'
Note, selecting 'nvidia-cuda-dev' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-3.16.0-4-amd64' for regex 'nvidia.'
Note, selecting 'nvidia-settings-legacy-304xx' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-340' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-343' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-346' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-349' for regex 'nvidia.'
Note, selecting 'nvidia-304-updates' for regex 'nvidia.'
Note, selecting 'nvidia-profiler' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-352' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-355' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-358' for regex 'nvidia.'
Note, selecting 'libegl-nvidia0' for regex 'nvidia.'
Note, selecting 'libgl1-glvnd-nvidia-glx' for regex 'nvidia.'
Note, selecting 'nvidia-settings-legacy-173xx' for regex 'nvidia.'
Note, selecting 'libnvidia-eglcore-340.102' for regex 'nvidia.'
Note, selecting 'nvidia-173' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-361' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-smi' for regex 'nvidia.'
Note, selecting 'nvidia-experimental-364' for regex 'nvidia.'
Note, selecting 'nvidia-313-updates' for regex 'nvidia.'
Note, selecting 'nvidia-glx-any' for regex 'nvidia.'
Note, selecting 'nvidia-smi' for regex 'nvidia.'
Note, selecting 'nvidia-driver-bin-304.135' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-304xx-alternative' for regex 'nvidia.'
Note, selecting 'nvidia-kernel-375.82' for regex 'nvidia.'
Note, selecting 'libnvidia-compiler-ia32' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-alternatives' for regex 'nvidia.'
Note, selecting 'nvidia-legacy-340xx-kernel-source' for regex 'nvidia.'
Note, selecting 'libglx-nvidia-alternatives' for regex 'nvidia.'
Note, selecting 'libnvidia-eglcore' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-cuda1-i386' for regex 'nvidia.'
Note, selecting 'libgl1-nvidia-glx-375.82' for regex 'nvidia.'
Note, selecting 'nvidia-glx-legacy-71xx-dev' for regex 'nvidia.'
Note, selecting 'libnvidia-legacy-340xx-cuda1' for regex 'nvidia.'
Note, selecting 'nvidia-331-updates' for regex 'nvidia.'
Note, selecting 'nvidia-detect' for regex 'nvidia.'
Note, selecting 'xserver-xorg-video-nvidia-legacy-340xx' for regex 'nvidia.'
Package 'nvidia-glx-ia32' is not installed, so not removed
Package 'nvidia-libvdpau1-ia32' is not installed, so not removed
Package 'libgl1-nvidia-alternatives' is not installed, so not removed
Package 'nvidia-glx-dev' is not installed, so not removed
Note, selecting 'libnvtt-bin' instead of 'nvidia-texture-tools'
Package 'nvidia-libopencl1-dev' is not installed, so not removed
Package 'nvidia-current' is not installed, so not removed
Package 'nvidia-current-updates' is not installed, so not removed
Note, selecting 'vdpau-va-driver' instead of 'nvidia-va-driver'
Package 'nvidia-173' is not installed, so not removed
Package 'nvidia-304' is not installed, so not removed
Package 'nvidia-304-updates' is not installed, so not removed
Package 'nvidia-310' is not installed, so not removed
Package 'nvidia-310-updates' is not installed, so not removed
Package 'nvidia-313-updates' is not installed, so not removed
Package 'nvidia-319' is not installed, so not removed
Package 'nvidia-319-updates' is not installed, so not removed
Package 'nvidia-331' is not installed, so not removed
Package 'nvidia-331-updates' is not installed, so not removed
Package 'nvidia-kernel-686-pae' is not installed, so not removed
Package 'nvidia-kernel-486' is not installed, so not removed
Package 'nvidia-driver-binary' is not installed, so not removed
Package 'nvidia-experimental-304' is not installed, so not removed
Package 'nvidia-experimental-310' is not installed, so not removed
Package 'nvidia-313' is not installed, so not removed
Package 'nvidia-experimental-313' is not installed, so not removed
Package 'nvidia-experimental-319' is not installed, so not removed
Package 'nvidia-325' is not installed, so not removed
Package 'nvidia-325-updates' is not installed, so not removed
Package 'nvidia-experimental-325' is not installed, so not removed
Package 'nvidia-experimental-331' is not installed, so not removed
Package 'nvidia-334' is not installed, so not removed
Package 'nvidia-334-updates' is not installed, so not removed
Package 'nvidia-experimental-334' is not installed, so not removed
Package 'nvidia-337' is not installed, so not removed
Package 'nvidia-337-updates' is not installed, so not removed
Package 'nvidia-experimental-337' is not installed, so not removed
Package 'nvidia-340' is not installed, so not removed
Package 'nvidia-340-updates' is not installed, so not removed
Package 'nvidia-experimental-340' is not installed, so not removed
Package 'nvidia-343' is not installed, so not removed
Package 'nvidia-343-updates' is not installed, so not removed
Package 'nvidia-experimental-343' is not installed, so not removed
Package 'libgl1-nvidia-legacy-173xx-glx' is not installed, so not removed
Package 'libgl1-nvidia-legacy-71xx-glx' is not installed, so not removed
Package 'libgl1-nvidia-legacy-96xx-glx' is not installed, so not removed
Package 'libglx-nvidia-alternatives' is not installed, so not removed
Package 'nvidia-glx-legacy-173xx' is not installed, so not removed
Package 'nvidia-glx-legacy-71xx' is not installed, so not removed
Package 'nvidia-glx-legacy-96xx' is not installed, so not removed
Package 'nvidia-glx-legacy-173xx-dev' is not installed, so not removed
Package 'nvidia-glx-legacy-71xx-dev' is not installed, so not removed
Package 'nvidia-glx-legacy-96xx-dev' is not installed, so not removed
Package 'nvidia-alternative-legacy-173xx' is not installed, so not removed
Package 'nvidia-alternative-legacy-96xx' is not installed, so not removed
Package 'nvidia-cuda-debugger' is not installed, so not removed
Package 'nvidia-compute-profiler' is not installed, so not removed
Package 'nvidia-cuda-profiler' is not installed, so not removed
Package 'nvidia-opencl-profiler' is not installed, so not removed
Package 'nvidia-cuda-proxy' is not installed, so not removed
Note, selecting 'libgl1-nvidia-glx' instead of 'libgl1-nvidia-glx-340.102'
Package 'libgl1-nvidia-glx-ia32' is not installed, so not removed
Package 'libgl1-nvidia-glx-ia32-any' is not installed, so not removed
Package 'libnvidia-compiler-ia32' is not installed, so not removed
Package 'libgl1-nvidia-alternatives-ia32' is not installed, so not removed
Package 'nvidia-settings-legacy-173xx' is not installed, so not removed
Note, selecting 'nvidia-alternative' instead of 'nvidia-alternative--kmod-alias'
Package 'libgl1-nvidia-glx-i386' is not installed, so not removed
Package 'nvidia-libopencl1-ia32' is not installed, so not removed
Package 'nvidia-opencl-icd-ia32' is not installed, so not removed
Package 'nvidia-vdpau-driver-ia32' is not installed, so not removed
Note, selecting 'nvidia-legacy-304xx-kernel-dkms' instead of 'nvidia-legacy-304xx-kernel-304.135'
Note, selecting 'libgl1-nvidia-legacy-304xx-glx' instead of 'libgl1-nvidia-glx-304.135'
Package 'libxvmcnvidia1' is not installed, so not removed
Note, selecting 'nvidia-legacy-304xx-alternative' instead of 'nvidia-legacy-304xx-alternative--kmod-alias'
Package 'libgl1-nvidia-legacy-304xx-glx-i386' is not installed, so not removed
Package 'nvidia-kernel-2.6-amd64' is not installed, so not removed
Package 'nvidia-346' is not installed, so not removed
Package 'nvidia-346-updates' is not installed, so not removed
Package 'nvidia-experimental-346' is not installed, so not removed
Package 'nvidia-349' is not installed, so not removed
Package 'nvidia-349-updates' is not installed, so not removed
Package 'nvidia-experimental-349' is not installed, so not removed
Package 'nvidia-352' is not installed, so not removed
Package 'nvidia-352-updates' is not installed, so not removed
Package 'nvidia-experimental-352' is not installed, so not removed
Package 'nvidia-355' is not installed, so not removed
Package 'nvidia-355-updates' is not installed, so not removed
Package 'nvidia-experimental-355' is not installed, so not removed
Package 'nvidia-358' is not installed, so not removed
Package 'nvidia-358-updates' is not installed, so not removed
Package 'nvidia-experimental-358' is not installed, so not removed
Package 'nvidia-361' is not installed, so not removed
Package 'nvidia-361-updates' is not installed, so not removed
Package 'nvidia-experimental-361' is not installed, so not removed
Package 'nvidia-364' is not installed, so not removed
Package 'nvidia-364-updates' is not installed, so not removed
Package 'nvidia-experimental-364' is not installed, so not removed
Note, selecting 'libgldispatch0-nvidia' instead of 'glvnd-nvidia-abi-375.20'
Note, selecting 'libnvidia-egl-wayland' instead of 'libnvidia-egl-wayland-375.82'
Package 'libgl1-nvidia-glx-375.82' is not installed, so not removed
Note, selecting 'libnvidia-glcore' instead of 'libnvidia-glcore-375.82'
Package 'nvidia-driver-libs-i386' is not installed, so not removed
Note, selecting 'nvidia-kernel-support' instead of 'nvidia-kernel-support--v1'
Note, selecting 'libnvidia-legacy-304xx-compiler' instead of 'libnvidia-compiler-304.135'
Package 'libnvidia-legacy-304xx-cuda1-i386' is not installed, so not removed
Note, selecting 'libnvidia-legacy-304xx-glcore' instead of 'libnvidia-glcore-304.135'
Note, selecting 'nvidia-legacy-304xx-driver-bin' instead of 'nvidia-driver-bin-304.135'
Package 'nvidia-legacy-304xx-driver-libs-i386' is not installed, so not removed
Note, selecting 'nvidia-legacy-304xx-kernel-support' instead of 'nvidia-legacy-304xx-kernel-support--v1'
Note, selecting 'nvidia-legacy-340xx-kernel-dkms' instead of 'nvidia-legacy-340xx-kernel-340.102'
Package 'libnvidia-legacy-340xx-cuda1-i386' is not installed, so not removed
Note, selecting 'libnvidia-legacy-340xx-glcore' instead of 'libnvidia-glcore-340.102'
Note, selecting 'nvidia-legacy-340xx-alternative' instead of 'nvidia-legacy-340xx-alternative--kmod-alias'
Package 'nvidia-legacy-340xx-driver-libs-i386' is not installed, so not removed
Note, selecting 'nvidia-legacy-340xx-kernel-support' instead of 'nvidia-legacy-340xx-kernel-support--v1'
Package 'boinc-nvidia-cuda' is not installed, so not removed
Package 'nvidia-cg-dev' is not installed, so not removed
Package 'nvidia-cg-doc' is not installed, so not removed
Package 'nvidia-cg-toolkit' is not installed, so not removed
Package 'nvidia-glx' is not installed, so not removed
Package 'nvidia-kernel-3.16.0-4-amd64' is not installed, so not removed
Package 'nvidia-kernel-amd64' is not installed, so not removed
Package 'nvidia-kernel-dummy' is not installed, so not removed
Package 'boinc-client-nvidia-cuda' is not installed, so not removed
Package 'nvidia-persistenced' is not installed, so not removed
Package 'nvidia-settings-legacy-304xx' is not installed, so not removed
Package 'nvidia-settings-legacy-340xx' is not installed, so not removed
Package 'nvidia-cuda-dev' is not installed, so not removed
Package 'nvidia-cuda-doc' is not installed, so not removed
Package 'nvidia-cuda-gdb' is not installed, so not removed
Package 'nvidia-cuda-toolkit' is not installed, so not removed
Package 'nvidia-nsight' is not installed, so not removed
Package 'nvidia-opencl-dev' is not installed, so not removed
Package 'nvidia-profiler' is not installed, so not removed
Package 'nvidia-visual-profiler' is not installed, so not removed
Package 'libegl-nvidia0' is not installed, so not removed
Package 'libgl1-glvnd-nvidia-glx' is not installed, so not removed
Package 'libgl1-nvidia-glvnd-glx' is not installed, so not removed
Package 'libgles-nvidia1' is not installed, so not removed
Package 'libgles-nvidia2' is not installed, so not removed
Package 'libglx-nvidia0' is not installed, so not removed
Package 'libnvidia-cfg1' is not installed, so not removed
Package 'libnvidia-compiler' is not installed, so not removed
Package 'libnvidia-egl-wayland' is not installed, so not removed
Package 'libnvidia-encode1' is not installed, so not removed
Package 'libnvidia-fatbinaryloader' is not installed, so not removed
Package 'libnvidia-fbc1' is not installed, so not removed
Package 'libnvidia-glcore' is not installed, so not removed
Package 'libnvidia-ifr1' is not installed, so not removed
Package 'libnvidia-ptxjitcompiler' is not installed, so not removed
Package 'nvidia-cuda-mps' is not installed, so not removed
Package 'nvidia-detect' is not installed, so not removed
Package 'nvidia-driver-libs' is not installed, so not removed
Package 'nvidia-egl-common' is not installed, so not removed
Package 'nvidia-egl-icd' is not installed, so not removed
Package 'nvidia-kernel-source' is not installed, so not removed
Package 'nvidia-kernel-support' is not installed, so not removed
Package 'nvidia-legacy-check' is not installed, so not removed
Package 'nvidia-libopencl1' is not installed, so not removed
Package 'nvidia-opencl-common' is not installed, so not removed
Package 'nvidia-opencl-icd' is not installed, so not removed
Package 'nvidia-smi' is not installed, so not removed
Package 'nvidia-vulkan-common' is not installed, so not removed
Package 'nvidia-vulkan-icd' is not installed, so not removed
Package 'libgl1-nvidia-legacy-304xx-glx' is not installed, so not removed
Package 'libnvidia-legacy-304xx-cfg1' is not installed, so not removed
Package 'libnvidia-legacy-304xx-compiler' is not installed, so not removed
Package 'libnvidia-legacy-304xx-cuda1' is not installed, so not removed
Package 'libnvidia-legacy-304xx-glcore' is not installed, so not removed
Package 'libnvidia-legacy-304xx-ml1' is not installed, so not removed
Package 'libnvidia-legacy-304xx-nvcuvid1' is not installed, so not removed
Package 'nvidia-legacy-304xx-alternative' is not installed, so not removed
Package 'nvidia-legacy-304xx-driver' is not installed, so not removed
Package 'nvidia-legacy-304xx-driver-bin' is not installed, so not removed
Package 'nvidia-legacy-304xx-driver-libs' is not installed, so not removed
Package 'nvidia-legacy-304xx-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-304xx-kernel-source' is not installed, so not removed
Package 'nvidia-legacy-304xx-kernel-support' is not installed, so not removed
Package 'nvidia-legacy-304xx-opencl-icd' is not installed, so not removed
Package 'nvidia-legacy-304xx-smi' is not installed, so not removed
Package 'nvidia-legacy-304xx-vdpau-driver' is not installed, so not removed
Package 'xserver-xorg-video-nvidia-legacy-304xx' is not installed, so not removed
Package 'libegl1-nvidia-legacy-340xx' is not installed, so not removed
Package 'libgl1-nvidia-legacy-340xx-glx' is not installed, so not removed
Package 'libgles1-nvidia-legacy-340xx' is not installed, so not removed
Package 'libgles2-nvidia-legacy-340xx' is not installed, so not removed
Package 'libnvidia-legacy-340xx-cfg1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-compiler' is not installed, so not removed
Package 'libnvidia-legacy-340xx-cuda1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-eglcore' is not installed, so not removed
Package 'libnvidia-legacy-340xx-encode1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-fbc1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-glcore' is not installed, so not removed
Package 'libnvidia-legacy-340xx-ifr1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-ml1' is not installed, so not removed
Package 'libnvidia-legacy-340xx-nvcuvid1' is not installed, so not removed
Package 'nvidia-legacy-340xx-alternative' is not installed, so not removed
Package 'nvidia-legacy-340xx-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-driver-bin' is not installed, so not removed
Package 'nvidia-legacy-340xx-driver-libs' is not installed, so not removed
Package 'nvidia-legacy-340xx-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-340xx-kernel-source' is not installed, so not removed
Package 'nvidia-legacy-340xx-kernel-support' is not installed, so not removed
Package 'nvidia-legacy-340xx-opencl-icd' is not installed, so not removed
Package 'nvidia-legacy-340xx-smi' is not installed, so not removed
Package 'nvidia-legacy-340xx-vdpau-driver' is not installed, so not removed
Package 'xserver-xorg-video-nvidia-legacy-340xx' is not installed, so not removed
The following packages will be REMOVED:
glx-alternative-mesa* glx-alternative-nvidia* glx-diversions* libegl1-nvidia* libgl1-nvidia-glx* libgles1-nvidia* libgles2-nvidia* libnvidia-eglcore* libnvidia-ml1* nvidia-alternative* nvidia-driver*
nvidia-driver-bin* nvidia-installer-cleanup* nvidia-kernel-common* nvidia-kernel-dkms* nvidia-modprobe* nvidia-settings* nvidia-support* nvidia-vdpau-driver* nvidia-xconfig* xserver-xorg-video-nvidia*
0 upgraded, 0 newly installed, 21 to remove and 25 not upgraded.
After this operation, 137 MB disk space will be freed.
Do you want to continue? [Y/n] yes
(Reading database ... 337753 files and directories currently installed.)
Removing nvidia-driver (340.102-1) ...
Removing xserver-xorg-video-nvidia (340.102-1) ...
Purging configuration files for xserver-xorg-video-nvidia (340.102-1) ...
Removing nvidia-kernel-dkms (340.102-1) ...
Deleting module version: 340.102
completely from the DKMS tree.
Done.
Removing nvidia-vdpau-driver:amd64 (340.102-1) ...
Purging configuration files for nvidia-vdpau-driver:amd64 (340.102-1) ...
Removing nvidia-kernel-common (20141201+1) ...
Purging configuration files for nvidia-kernel-common (20141201+1) ...
update-initramfs: deferring update (trigger activated)
Removing libegl1-nvidia:amd64 (340.102-1) ...
Purging configuration files for libegl1-nvidia:amd64 (340.102-1) ...
Removing libgl1-nvidia-glx:amd64 (340.102-1) ...
Purging configuration files for libgl1-nvidia-glx:amd64 (340.102-1) ...
Removing libgles1-nvidia:amd64 (340.102-1) ...
Purging configuration files for libgles1-nvidia:amd64 (340.102-1) ...
Removing libgles2-nvidia:amd64 (340.102-1) ...
Purging configuration files for libgles2-nvidia:amd64 (340.102-1) ...
Removing libnvidia-eglcore:amd64 (340.102-1) ...
Purging configuration files for libnvidia-eglcore:amd64 (340.102-1) ...
Removing nvidia-driver-bin (340.102-1) ...
Removing libnvidia-ml1:amd64 (340.102-1) ...
Purging configuration files for libnvidia-ml1:amd64 (340.102-1) ...
Removing nvidia-settings (340.46-2) ...
Purging configuration files for nvidia-settings (340.46-2) ...
Removing nvidia-support (20141201+1) ...
Purging configuration files for nvidia-support (20141201+1) ...
Removing nvidia-xconfig (340.46-1) ...
Removing nvidia-alternative (340.102-1) ...
Purging configuration files for nvidia-alternative (340.102-1) ...
Removing glx-alternative-nvidia (0.5.1) ...
update-alternatives: using /usr/lib/mesa-diverted to provide /usr/lib/glx (glx) in auto mode
Purging configuration files for glx-alternative-nvidia (0.5.1) ...
Removing glx-alternative-mesa (0.5.1) ...
Removing glx-diversions (0.5.1) ...
Removing 'diversion of /usr/lib/libGL.so.1.2.0 to /usr/lib/mesa-diverted/libGL.so.1.2.0 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1.2.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1.2.0 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1.2.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1.2.0 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1.2.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1.2.0 by glx-diversions'
Removing 'diversion of /usr/lib/libGL.so.1.2 to /usr/lib/mesa-diverted/libGL.so.1.2 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1.2 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1.2 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1.2 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1.2 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1.2 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1.2 by glx-diversions'
Removing 'diversion of /usr/lib/libGL.so.1 to /usr/lib/mesa-diverted/libGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/libGL.so to /usr/lib/mesa-diverted/libGL.so by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so by glx-diversions'
Removing 'diversion of /usr/lib/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/libEGL.so.1.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so.1.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so.1.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so.1.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/libEGL.so.1 to /usr/lib/mesa-diverted/libEGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libEGL.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/libEGL.so to /usr/lib/mesa-diverted/libEGL.so by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libEGL.so to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/libGLESv1_CM.so.1.1.0 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so.1.1.0 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so.1.1.0 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so.1.1.0 by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/libGLESv1_CM.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so.1 by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv1_CM.so to /usr/lib/mesa-diverted/libGLESv1_CM.so by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/libGLESv2.so.2.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so.2.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so.2.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so.2.0.0 by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv2.so.2 to /usr/lib/mesa-diverted/libGLESv2.so.2 by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so.2 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so.2 by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so.2 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so.2 by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so.2 by glx-diversions'
Removing 'diversion of /usr/lib/libGLESv2.so to /usr/lib/mesa-diverted/libGLESv2.so by glx-diversions'
Removing 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so by glx-diversions'
Removing 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so by glx-diversions'
Removing 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so by glx-diversions'
Purging configuration files for glx-diversions (0.5.1) ...
Removing nvidia-installer-cleanup (20141201+1) ...
Purging configuration files for nvidia-installer-cleanup (20141201+1) ...
Removing nvidia-modprobe (340.46-1) ...
Processing triggers for libc-bin (2.19-18+deb8u10) ...
Processing triggers for initramfs-tools (0.120+deb8u3) ...
update-initramfs: Generating /boot/initrd.img-3.16.0-5-amd64
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r8169
Processing triggers for menu (2.1.47) ...
Processing triggers for man-db (2.7.0.2-5) ...
/etc/init.d/gdm3 stop
[ ok ] Stopping gdm3 (via systemctl): gdm3.service.
apt-get autoremove -y && apt-get autoclean -y && apt-get clean -y
libxnvctrl0
0 upgraded, 0 newly installed, 1 to remove and 25 not upgraded.
After this operation, 42.0 kB disk space will be freed.
(Reading database ... 337270 files and directories currently installed.)
Removing libxnvctrl0 (340.46-2) ...
apt-get install --reinstall xserver-xorg
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 25 not upgraded.
Need to get 110 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://ftp.gr.debian.org/debian/ jessie/main xserver-xorg amd64 1:7.7+7 [110 kB]
Fetched 110 kB in 0s (518 kB/s)
(Reading database ... 337265 files and directories currently installed.)
Preparing to unpack .../xserver-xorg_1%3a7.7+7_amd64.deb ...
Unpacking xserver-xorg (1:7.7+7) over (1:7.7+7) ...
Setting up xserver-xorg (1:7.7+7) ...
apt-get install --reinstall xserver-xorg-video-nouveau
Need to get 311 kB of archives.
Get:1 http://ftp.gr.debian.org/debian/ jessie/main xserver-xorg-video-nouveau amd64 1:1.0.11-1 [311 kB]
Fetched 311 kB in 0s (604 kB/s)
Preparing to unpack .../xserver-xorg-video-nouveau_1%3a1.0.11-1_amd64.deb ...
Unpacking xserver-xorg-video-nouveau (1:1.0.11-1) over (1:1.0.11-1) ...
Setting up xserver-xorg-video-nouveau (1:1.0.11-1) ...
Εδώ γιατί λέει : «Xorg: no process found» ;
killall Xorg
reboot
Το πρόβλημα είναι πως, δεν έχω πλέον γραφικό περιβάλλον. Όταν ανοίγει, μπαίνει σε terminal/console mode - δεν ξέρω, πως ακριβώς λέγετε αυτό ;
Πάντως καταλαβαίνεται, δε φορτώνει καθόλου γραφικό περιβάλλον παρά μόνο η μαύρη οθόνη που σε παραπέμπει να συνδεθείς και τέλος πάντων να έχει πλήρη πρόσβαση μέσω termail.
Το γραφικό περιβάλλον όμως; Με «ctrl + alt + F4» έμπαινα και πριν σε αυτό το περιβάλλον, αλλά έπειτα με «ctrl + alt + F7» με έβαζε ξανά στο γραφικό περιβάλλον του Gnome. Τώρα τίποτα. Μονάχα αυτό.
Έτρεξα ακόμη όπως λέει και την εντολή «X -configure» αλλά δεν γίνεται τίποτα και μου επιστέφει κιόλας σφάλμα :
X -configure
X.Org X Server 1.16.4
Release Date: 2014-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-4-amd64 x86_64 Debian
Current Operating System: Linux UserPc 3.16.0-4-amd64 #1 SMP Debian 3.16.51-3 (2017-12-13) x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=6db966e5-4375-4da4-ad2a-3b586ff5f0de ro quiet
Build Date: 14 October 2017 10:41:31AM
xorg-server 2:1.16.4-1+deb8u2 (http://www.debian.org/support)
Current version of pixman: 0.32.6
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 13:02:33 2018
List of video drivers:
sisusb
radeon
cirrus
siliconmotion
nouveau
trident
fbdev
r128
openchrome
tdfx
neomagic
savage
ati
qxl
intel
mga
vmware
mach64
vesa
modesetting
(++) Using config file: "/root/xorg.conf.new"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Xorg detected your mouse at device /dev/input/mice.
Please check your config if the mouse is still not
operational, as by default Xorg tries to autodetect
the protocol.
Your xorg.conf file is /root/xorg.conf.new
To test the server, run 'X -config /root/xorg.conf.new'
(EE) Server terminated with error (2). Closing log file.
Το αρχείο «/root/xorg.conf.new» εμπεριέχει τα παρακάτω :
cat /root/xorg.conf.new
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "built-ins"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "VideoKey" # <i>
#Option "WrappedFB" # [<bool>]
#Option "GLXVBlank" # [<bool>]
#Option "ZaphodHeads" # <str>
#Option "PageFlip" # [<bool>]
#Option "SwapLimit" # <i>
#Option "AsyncUTSDFS" # [<bool>]
#Option "AccelMethod" # <str>
Identifier "Card0"
Driver "nouveau"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Τρέχοντας ακόμη και αυτό που με παραπέμπει «X -config /root/xorg.conf.new», το άφησα αρκετή ώρα και δεν μου έδειχνε τίποτα. Πατώντας πάλι του συνδυασμούς «ctrl + alt + F4», «ctrl + alt + F6», «ctrl + alt + F7» μου εμφάνιζε την προ-τελευταία γραμμή, αλλά και πάλι δεν μου φάνηκε κάτι το σπουδαίο και έτσι με «ctrl + C» το έκλεισα :
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 13:11:08 2018
resize called 1280 800
(II) AIGLX: Suspending AIGLX clients for VT switch
^C(EE) Server terminated successfully (0). Closing log file.
Επίσης αν τρέξω «startx» έχω προβλήματα :
startx
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 13:31:40 2018
(==) Using config file: "/etc/X11/xorg.conf"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
^Cxinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
Με το log file να περιέχει τα παρακάτω :
cat /var/log/Xorg.0.log
[ 344.472]
[ 344.472] X Protocol Version 11, Revision 0
[ 344.472] Build Operating System: Linux 4.9.0-4-amd64 x86_64 Debian
[ 344.472] Current Operating System: Linux UserPc 3.16.0-4-amd64 #1 SMP Debian 3.16.51-3 (2017-12-13) x86_64
[ 344.472] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=6db966e5-4375-4da4-ad2a-3b586ff5f0de ro quiet
[ 344.473] Build Date: 14 October 2017 10:41:31AM
[ 344.473] xorg-server 2:1.16.4-1+deb8u2 (http://www.debian.org/support)
[ 344.473] Current version of pixman: 0.32.6
[ 344.473] Before reporting problems, check http://wiki.x.org
[ 344.473] Markers: (--) probed, (**) from config file, (==) default setting,
[ 344.473] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 19 13:31:40 2018
[ 344.473] (==) Using config file: "/etc/X11/xorg.conf"
[ 344.473] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 344.473] (==) ServerLayout "Layout0"
[ 344.473] (**) |-->Screen "Screen0" (0)
[ 344.473] (**) | |-->Monitor "Monitor0"
[ 344.474] (**) | |-->Device "Device0"
[ 344.474] (**) |-->Input Device "Keyboard0"
[ 344.474] (**) |-->Input Device "Mouse0"
[ 344.474] (==) Automatically adding devices
[ 344.474] (==) Automatically enabling devices
[ 344.474] (==) Automatically adding GPU devices
[ 344.474] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 344.474] Entry deleted from font path.
[ 344.474] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 344.474] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 344.474] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 344.474] (WW) Disabling Keyboard0
[ 344.474] (WW) Disabling Mouse0
[ 344.474] (II) Loader magic: 0x556de80c1d80
[ 344.474] (II) Module ABI versions:
[ 344.474] X.Org ANSI C Emulation: 0.4
[ 344.474] X.Org Video Driver: 18.0
[ 344.474] X.Org XInput driver : 21.0
[ 344.474] X.Org Server Extension : 8.0
[ 344.474] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 344.477] (--) PCI:*(0:1:0:0) 10de:0649:103c:3603 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00009000/128
[ 344.477] (II) LoadModule: "glx"
[ 344.477] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 344.478] (II) Module glx: vendor="X.Org Foundation"
[ 344.478] compiled for 1.16.4, module version = 1.0.0
[ 344.478] ABI class: X.Org Server Extension, version 8.0
[ 344.478] (==) AIGLX enabled
[ 344.478] (II) LoadModule: "nvidia"
[ 344.479] (WW) Warning, couldn't open module nvidia
[ 344.479] (II) UnloadModule: "nvidia"
[ 344.479] (II) Unloading nvidia
[ 344.479] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 344.479] (EE) No drivers available.
[ 344.479] (EE)
Fatal server error:
[ 344.479] (EE) no screens found(EE)
[ 344.479] (EE)
for help.
[ 344.479] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 344.479] (EE)
Καμία ιδέα ;
Ευχαριστώ πολύ! :)
Τελευταία επεξεργασία από Tassos10 και 10 Μάιος 2018, 13:14, έχει επεξεργασθεί 2 φορά/ες συνολικά
Tassos10
Re: Debian : Διαγραφή των κλεισών οδηγών της κάρτας γραφικών
Δημοσίευσηαπό Maras » 19 Ιαν 2018, 16:11
Δώσε το αποτέλεσμα των
cat /etc/X11/xorg.conf
και
cat /etc/modules
Δημοσίευσηαπό Tassos10 » 19 Ιαν 2018, 16:24
Ευχαριστώ για την άμεση απάντηση. Ορίστε :
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 340.46 (buildd@brahms) Tue Oct 7 08:00:32 UTC 2014
Identifier "Layout0"
EndSection
Section "Files"
EndSection
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Generated by sensors-detect on Sun Sep 3 22:47:19 2017
# Chip drivers
coretemp
Η δεύτερη είναι για να δεις αν φορτώνει κατά την εκκίνηση ;
Ευχαριστώ.
Tassos10
Δημοσίευσηαπό Maras » 19 Ιαν 2018, 16:39
Ναι, επίσης δώσε μου
lsmod | grep nouveau
και
lspci -nnk | grep -iA2 vga
Δημοσίευσηαπό Tassos10 » 19 Ιαν 2018, 17:32
Ορίστε :
nouveau 1122508 1
mxm_wmi 12515 1 nouveau
ttm 77940 1 nouveau
drm_kms_helper 49210 1 nouveau
drm 249998 4 ttm,drm_kms_helper,nouveau
i2c_algo_bit 12751 1 nouveau
wmi 17339 3 hp_wmi,mxm_wmi,nouveau
video 22169 1 nouveau
button 12909 1 nouveau
i2c_core 46012 7 drm,i2c_i801,drm_kms_helper,i2c_algo_bit,v4l2_common,nouveau,videodev
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation G96M [GeForce 9600M GT] [10de:0649] (rev a1)
Subsystem: Hewlett-Packard Company Device [103c:3603]
Kernel driver in use: nouveau
Tassos10
Δημοσίευσηαπό Maras » 19 Ιαν 2018, 17:58
Όπως βλέπεις το σύστημα σου φορτώνει τους κατάλληλους drivers-modules και ή κάρτα γραφικών σου κάνει χρήση του nouveau. Κατά την επανεκκίνηση δεν σου ανοίγει ούτε ο login manager, o gdm ? Δηλαδή κατ 'ευθειαν σε πάει σε τερματικό?
Δημοσίευσηαπό Tassos10 » 19 Ιαν 2018, 18:04
Ναι φίλε τίποτα απολύτως. Κατευθείαν στο τερματικό. Δεν φορτώνει τίποτα απολύτως από το γραφικό περιβάλλον.
Καταρχήν, που μπορείς να δεις που είναι όλοι οι οδηγοί για την κάρτα σου; Ώστε να δω ποιο είναι εγκατεστημένοι και αν είναι να τους διαγράψω όλους και να αφήσω μόνο έναν ή να επέλεγα να απενεργοποιήσω/ενεργοποιήσω κάποιον.
Αν διέγραφα τα πάντα που έχουν να κάνουν με το γραφικό περιβάλλον και τα ξανά έστηνα ;
Tassos10
Δημοσίευσηαπό Maras » 19 Ιαν 2018, 18:13
Ρίξε μια ματιά εδώ σε όλες τις λύσεις μήπως βγάλεις άκρη με κάποια ρύθμιση
https://askubuntu.com/questions/360761/cannot-get-rid-of-nvidia-drivers-restore-nouveau-driver-and-get-desktop-working
οι drivers για το xorg είναι εδώ αλλά πρόσεξε τι θα πειράξεις :
/usr/lib/xorg/modules/drivers
Re: Debian : Διαγραφή των κλεισών οδηγών της κάρτας γραφικών  Το θέμα επιλύθηκε
Δημοσίευσηαπό Tassos10 » 21 Ιαν 2018, 18:26
Χαιρετώ! Επιτέλους έλυσα το πρόβλημα μου και όλα πλέον λειτουργούν ομαλά! :)
Στην προσπάθεια επίλυσης του προβλήματος μου, έτρεξα για ακόμη μια φορά τις παρακάτω εντολές ώστε να βεβαιωθώ πως οι οδηγοί της nVidia καθώς και όλα τα αρχεία αυτών έχουν διαγραφεί.
Οπότε και έτρεξα τις παρακάτω εντολές ( μερικές ήταν άσκοπες, αλλά διάβασα σε μερικά παρόμοια προβλήματα που πρότειναν να τις τρέξεις - κυρίως όμως αρκούν πιστεύω αυτές που λέει ο επίσημος οδηγός του Debian ) :
Package 'nvidia-xconfig' is not installed, so not removed
Package 'nvidia-modprobe' is not installed, so not removed
Package 'nvidia-settings' is not installed, so not removed
Package 'nvidia-installer-cleanup' is not installed, so not removed
Package 'nvidia-kernel-common' is not installed, so not removed
Package 'nvidia-support' is not installed, so not removed
Package 'libgl1-nvidia-glx' is not installed, so not removed
Package 'libnvidia-eglcore' is not installed, so not removed
Package 'libnvidia-ml1' is not installed, so not removed
Package 'nvidia-alternative' is not installed, so not removed
Package 'nvidia-driver' is not installed, so not removed
Package 'nvidia-driver-bin' is not installed, so not removed
Package 'nvidia-kernel-dkms' is not installed, so not removed
Package 'nvidia-vdpau-driver' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
stop lightdm
bash: stop: command not found
apt-get install xserver-xorg-video-nouveau
xserver-xorg-video-nouveau is already the newest version.
xserver-xorg-video-nouveau set to manually installed.
apt-get purge bumblebee
Package 'bumblebee' is not installed, so not removed
Fetched 110 kB in 3s (34.2 kB/s)
Fetched 311 kB in 2s (138 kB/s)
killall Xorg
X -configure
Current Operating System: Linux TassosPc 3.16.0-4-amd64 #1 SMP Debian 3.16.51-3 (2017-12-13) x86_64
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 21 15:21:39 2018
sisusb
radeon
cirrus
siliconmotion
nouveau
trident
fbdev
r128
openchrome
tdfx
neomagic
savage
ati
qxl
intel
mga
vmware
mach64
vesa
modesetting
the protocol.
dpkg-reconfigure xserver-xorg
Και αφού έκανα τα παραπάνω και διάβαζα παράλληλα αυτά εδώ ( ευχαριστώ @Maras ):
Σκέφτηκα να πάω να ελέγξω αν έχουν ξεμείνει στο σύστημα μου "αποκαΐδια" των οδηγών της nVidia. Και νομίζω αυτό είναι το βήμα που πραγματικά έλυσε το πρόβλημα μου ( όλα τα παραπάνω αν δείτε τα είχα κάνει ήδη ), οπότε και έκανα τα παρακάτω :
cd /etc/modules-load.d/
ls -alh
total 20K
drwxr-xr-x 2 root root 4.0K Jun 24 2017 .
drwxr-xr-x 155 root root 12K Jan 19 12:55 ..
-rw-r--r-- 1 root root 119 Dec 15 2015 cups-filters.conf
lrwxrwxrwx 1 root root 10 Apr 9 2017 modules.conf -> ../modules
aptitude purge nvidia-kernel-dkms nvidia-glx
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
cd /etc/X11/
ls -l
total 84
drwxr-xr-x 2 root root 4096 Apr 20 2016 app-defaults
-rw-r--r-- 1 root root 15 Apr 20 2016 default-display-manager
drwxr-xr-x 6 root root 4096 Apr 20 2016 fonts
-rw-r--r-- 1 root root 17394 Sep 26 2013 rgb.txt
lrwxrwxrwx 1 root root 13 Apr 20 2016 X -> /usr/bin/Xorg
drwxr-xr-x 2 root root 4096 Apr 20 2016 xinit
drwxr-xr-x 2 root root 4096 Jun 6 2014 xkb
-rw-r--r-- 1 root root 1306 Jan 19 12:32 xorg.conf
-rw-r--r-- 1 root root 1299 Jan 19 12:32 xorg.conf.backup
-rw-r--r-- 1 root root 0 Jun 24 2017 xorg.conf.nvidia-xconfig-original
-rwxr-xr-x 1 root root 709 Sep 26 2013 Xreset
drwxr-xr-x 2 root root 4096 Apr 20 2016 Xreset.d
drwxr-xr-x 2 root root 4096 Apr 20 2016 Xresources
-rwxr-xr-x 1 root root 3517 Sep 26 2013 Xsession
drwxr-xr-x 2 root root 4096 Jan 22 2017 Xsession.d
-rw-r--r-- 1 root root 265 Sep 26 2013 Xsession.options
drwxr-xr-x 2 root root 4096 Apr 20 2016 xsm
-rw-r--r-- 1 root root 13 Nov 8 2014 XvMCConfig
-rw-r--r-- 1 root root 601 Apr 20 2016 Xwrapper.config
και εδώ ο βιαστικός - χαζός δεν είχα προσέξει πως υπήρχε ήδη ένα αρχείο «xorg.conf.backup» και έτσι πήγα και έκανα
mv xorg.conf xorg.conf.backup
Αν το είχα προσέξει θα το έκανα «mv xorg.conf xorg.conf.backup1», πάντως ήθελα να μην υπάρχει αρχείο «xorg.conf».
Αμέσως μόλις το πρόσεξα, είπα «οκ, συγχαρητήρια, τώρα μπορεί να τα έκανα ακόμη χειρότερα τα πράγματα». Τέλος πάντων προχώρησα όμως ( τι άλλο να έκανα )
ls -alh
total 96K
drwxr-xr-x 10 root root 4.0K Jan 21 15:24 .
drwxr-xr-x 2 root root 4.0K Apr 20 2016 app-defaults
drwxr-xr-x 6 root root 4.0K Apr 20 2016 fonts
-rw-r--r-- 1 root root 17K Sep 26 2013 rgb.txt
drwxr-xr-x 2 root root 4.0K Apr 20 2016 xinit
drwxr-xr-x 2 root root 4.0K Jun 6 2014 xkb
-rw-r--r-- 1 root root 1.3K Jan 19 12:32 xorg.conf.backup
drwxr-xr-x 2 root root 4.0K Apr 20 2016 Xreset.d
drwxr-xr-x 2 root root 4.0K Apr 20 2016 Xresources
-rwxr-xr-x 1 root root 3.5K Sep 26 2013 Xsession
drwxr-xr-x 2 root root 4.0K Jan 22 2017 Xsession.d
drwxr-xr-x 2 root root 4.0K Apr 20 2016 xsm
Οπότε και προσέχω τώρα πως υπάρχει ένα αποκαΐδι της nVidia, ονόματι «xorg.conf.nvidia-xconfig-original», οπότε και αμέσως το διέγραψα :
rm xorg.conf.nvidia-xconfig-original
ls -l
total 80
-rw-r--r-- 1 root root 1306 Jan 19 12:32 xorg.conf.backup
και τέλος έκανα την τρομερή και ελπιδοφόρα επανεκκίνηση :
reboot
Έπεται για καλή μου τύχη, επιτέλους το Debian GNU/Linux εκκίνησε κανονικά και αμέσως φόρτωσε το γραφικό του περιβάλλον!!
:) :clap: :D :shock: :thumbup: :mrgreen: :bow:
Έτρεξα και ( έτσι για να δω ) και τις παρακάτω εντολές :
nouveau 1122508 3
ttm 77940 1 nouveau
drm 249998 6 ttm,drm_kms_helper,nouveau
Πλέον εκκινεί λοιπόν άψογα και το γραφικό περιβάλλον με τους ανοιχτούς οδηγούς! :D
Σας ευχαριστώ πάρα πολύ όλους για το ενδιαφέρον και την βοήθεια! :)
Tassos10
