Ubuntu Ubuntu 20.04.6 LTS - WINDOWS 7 DUAL BOOT GRUB
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 12:57
Καλημερα σας και καλη χρονια καταρχην
Στο ιδιο εργο θεατες και παλι ,θελω την βοηθεια σας παλι δεν γινεται dual boot στο συστημα, παραθετω τα κατωθι
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
tuxer@tuxer-P35-DS3L:~$ sudo update-grub
[sudo] password for tuxer:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.4.0-169-generic
Found initrd image: /boot/initrd.img-5.4.0-169-generic
Found linux image: /boot/vmlinuz-5.4.0-167-generic
Found initrd image: /boot/initrd.img-5.4.0-167-generic
Found linux image: /boot/vmlinuz-5.4.0-152-generic
Found initrd image: /boot/initrd.img-5.4.0-152-generic
Found linux image: /boot/vmlinuz-5.4.0-149-generic
Found initrd image: /boot/initrd.img-5.4.0-149-generic
Found linux image: /boot/vmlinuz-5.4.0-148-generic
Found initrd image: /boot/initrd.img-5.4.0-148-generic
Found linux image: /boot/vmlinuz-4.15.0-126-generic
Found initrd image: /boot/initrd.img-4.15.0-126-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
done
tuxer@tuxer-P35-DS3L:~$ /etc/default/grub
bash: /etc/default/grub: Άρνηση πρόσβασης
tuxer@tuxer-P35-DS3L:~$ sudo gedit /etc/default/grub
1 Γνώσεις Linux: Ικανοποιητικό ┃ Προγραμματισμού: Πρώτα βήματα ┃ Αγγλικών: Ικανοποιητικό
2 Ubuntu 20.04.2 LTS
3 Intel® Core™2 Duo CPU E7200 @ 2.53GHz × 2
4 Advanced Micro Devices, Inc. [AMD/ATI] RV635 [Radeon HD 3650/3750/4570/4580] [1002:9598] {radeon}
Tuxer
Re: Ubuntu Ubuntu 20.04.6 LTS - WINDOWS 7 DUAL BOOT GRUB
Δημοσίευσηαπό Maras » 13 Ιαν 2024, 15:33
Διάβασε καλά εδώ:
https://askubuntu.com/questions/1471899/grub-doesnt-detect-windows-10-and-os-prober-shows-no-output-tried-existing-sol
και κάνε πρώτα αυτά που δοκίμασε ο τύπος που ρωτάει στο παραπάνω νήμα.
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 19:35
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop1: 162,32 MiB, 170192896 bytes, 332408 sectors
Disk /dev/loop2: 158,92 MiB, 166621184 bytes, 325432 sectors
Disk /dev/loop3: 162,31 MiB, 170188800 bytes, 332400 sectors
Disk /dev/loop4: 158,92 MiB, 166621184 bytes, 325432 sectors
Disk /dev/loop5: 105,78 MiB, 110895104 bytes, 216592 sectors
Disk /dev/loop6: 55,68 MiB, 58363904 bytes, 113992 sectors
Disk /dev/loop7: 74,12 MiB, 77713408 bytes, 151784 sectors
Disk /dev/sda: 931,53 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000DM010-2EP1
Disklabel type: dos
Disk identifier: 0x69b931d9
/dev/sda1 * 2048 1951522815 1951520768 930,6G 83 Linux
/dev/sda2 1951524862 1953523711 1998850 976M 5 Extended
/dev/sda5 1951524864 1953523711 1998848 976M 82 Linux swap / Solaris
Partition 2 does not start on physical sector boundary.
Disk /dev/sdb: 465,78 GiB, 500106780160 bytes, 976771055 sectors
Disk model: ST3500320AS
Disklabel type: dos
Disk identifier: 0xe4fc056a
/dev/sdb1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sdb2 206848 184322047 184115200 87,8G 7 HPFS/NTFS/exFAT
/dev/sdb3 184322048 785441035 601118988 286,7G 7 HPFS/NTFS/exFAT
/dev/sdb4 785442814 976769023 191326210 91,2G 5 Extended
/dev/sdb5 785442816 974770175 189327360 90,3G 83 Linux
/dev/sdb6 974772224 976769023 1996800 975M 82 Linux swap / Solaris
Disk /dev/sdc: 465,78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: ST3500418AS
Disklabel type: dos
Disk identifier: 0x82efbbbd
/dev/sdc1 * 2048 976769023 976766976 465,8G 7 HPFS/NTFS/exFAT
Disk /dev/loop8: 66,58 MiB, 69795840 bytes, 136320 sectors
Disk /dev/loop9: 105,84 MiB, 110960640 bytes, 216720 sectors
Disk /dev/loop10: 63,93 MiB, 67014656 bytes, 130888 sectors
Disk /dev/loop11: 66,55 MiB, 69771264 bytes, 136272 sectors
Disk /dev/loop12: 63,48 MiB, 66547712 bytes, 129976 sectors
Disk /dev/loop13: 140,7 MiB, 147517440 bytes, 288120 sectors
Disk /dev/loop14: 55,68 MiB, 58363904 bytes, 113992 sectors
Disk /dev/loop15: 218,4 MiB, 228999168 bytes, 447264 sectors
Disk /dev/loop16: 496,9 MiB, 521015296 bytes, 1017608 sectors
Disk /dev/loop17: 140,68 MiB, 147492864 bytes, 288072 sectors
Disk /dev/loop18: 164,84 MiB, 172830720 bytes, 337560 sectors
Disk /dev/loop19: 218,4 MiB, 228999168 bytes, 447264 sectors
Disk /dev/loop20: 349,71 MiB, 366682112 bytes, 716176 sectors
Disk /dev/loop21: 73,92 MiB, 77492224 bytes, 151352 sectors
Disk /dev/loop22: 91,7 MiB, 96141312 bytes, 187776 sectors
Disk /dev/loop23: 164,84 MiB, 172830720 bytes, 337560 sectors
Disk /dev/loop24: 65,1 MiB, 68259840 bytes, 133320 sectors
Disk /dev/loop25: 349,71 MiB, 366678016 bytes, 716168 sectors
Disk /dev/loop26: 1,56 MiB, 1617920 bytes, 3160 sectors
Disk /dev/loop27: 45,95 MiB, 48160768 bytes, 94064 sectors
Disk /dev/loop28: 12,33 MiB, 12922880 bytes, 25240 sectors
Disk /dev/loop29: 235,98 MiB, 247422976 bytes, 483248 sectors
Disk /dev/loop30: 1,49 MiB, 1552384 bytes, 3032 sectors
Disk /dev/loop31: 13,68 MiB, 14331904 bytes, 27992 sectors
Disk /dev/loop32: 14,81 MiB, 15511552 bytes, 30296 sectors
Disk /dev/loop33: 496,10 MiB, 521121792 bytes, 1017816 sectors
Tuxer
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 19:36
Maras έγραψε:Διάβασε καλά εδώ:
με ειχες ξανα βοηθησει προσπαθησα να κανω αυτα που μου ειχες πει παλαιοτερα αλλα ειδα διαφορες και για αυτο μπηκα στην διαδικασια να ρωτησω
Tuxer
Δημοσίευσηαπό Maras » 13 Ιαν 2024, 20:46
Το πρόβλημα είναι ότι ο Grub δεν βλέπει τα Windows για να στα βγάλει στην λίστα με τα διαθέσιμα λειτουργικά.
Δώσε με την σειρά:
sudo apt install --reinstall os-prober
και
sudo update-grub
και δώσε τα αποτελέσματα.
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 20:56
Κατασκευή Δένδρου Εξαρτήσεων
Τα ακόλουθα πακέτα εγκαταστάθηκαν αυτόματα και δεν χρειάζονται πλέον:
chromium-browser-l10n g++-7 gir1.2-mutter-2 libargon2-0 libavahi-client3:i386 libavahi-common-data:i386 libavahi-common3:i386
libbind9-160 libboost-date-time1.65.1 libboost-filesystem1.65.1 libboost-iostreams1.65.1 libboost-system1.65.1
libboost-thread1.65.1 libcamel-1.2-61 libcapnp-0.6.1 libdbus-1-3:i386 libdns-export1100 libdns1100 libdouble-conversion1
libevent-2.1-6 libffi7:i386 libfwupdplugin1 libgdbm5 libgmime-3.0-0 libgmp10:i386 libgnome-desktop-3-17 libgnutls30:i386
libgssapi-krb5-2:i386 libgweather-3-15 libhogweed5:i386 libhunspell-1.6-0 libicu60 libip6tc0 libiptc0 libirs160 libisc-export169
libisc169 libisccc160 libisccfg160 libisl19 libjson-c3 libk5crypto3:i386 libkeyutils1:i386 libkrb5-3:i386 libkrb5support0:i386
libllvm10 libllvm11 liblouis14 liblouisutdml8 liblwres160 libmagickcore-6.q16-3 libmagickcore-6.q16-3-extra
libmagickwand-6.q16-3 libmozjs-52-0 libmutter-2-0 libnettle7:i386 libnss-myhostname libntfs-3g88 liborcus-0.13-0
libp11-kit0:i386 libperl5.26 libpoppler73 libprocps6 libprotobuf-lite10 libprotobuf10 libpython3.6-minimal libqpdf21 libraw16
libreadline7 libsane1 libssl1.1:i386 libstdc++-7-dev libtasn1-6:i386 libvpx5 libxmlb1 nplan python3-asn1crypto
python3-zope.interface python3.6-minimal
Χρησιμοποιήστε 'sudo apt autoremove' για να τα διαγράψετε.
0 αναβαθμίστηκαν, 0 νέο εγκατεστημένα, 1 επανεγκατεστημένα,0 θα αφαιρεθούν και 8 δεν αναβαθμίζονται.
Χρειάζεται να μεταφορτωθούν 20,1 kB από αρχεία.
Μετά από αυτή τη λειτουργία, θα χρησιμοποιηθούν 0 B χώρου από το δίσκο.
Φέρε:1 http://gr.archive.ubuntu.com/ubuntu focal/main amd64 os-prober amd64 1.74ubuntu2 [20,1 kB]
Μεταφορτώθηκαν 20,1 kB σε 7δ (2735 B/s)
(Ανάγνωση βάσης δεδομένων ... 381238 files and directories currently installed.)
Preparing to unpack .../os-prober_1.74ubuntu2_amd64.deb ...
Unpacking os-prober (1.74ubuntu2) over (1.74ubuntu2) ...
Γίνεται εγκατάσταση os-prober (1.74ubuntu2) ...
Found Windows 7 on /dev/sdb1
Found Windows 7 on /dev/sdb2
Found Ubuntu 18.04.6 LTS (18.04) on /dev/sdb5
done
Tuxer
Δημοσίευσηαπό Maras » 13 Ιαν 2024, 21:43
Ωραία κάνε μια επανεκκίνηση και μπες στα Windows.
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 22:04
το grub εχει διορθωθει , μολις παω να μπω στα windows 7 βγαζει το εξης BOOTMGR is missing Press Ctrl +alt+del to restart
Tuxer
Δημοσίευσηαπό Maras » 13 Ιαν 2024, 22:12
Πείραξες τίποτα στο BIOS, όπως για παράδειγμα το boot order?
Ρίξε μια ματιά εδώ για λύσεις σε αυτό το πρόβλημα.
https://www.partitionwizard.com/partitionmagic/bootmgr-is-missing.html
Δημοσίευσηαπό Tuxer » 13 Ιαν 2024, 22:34
Maras έγραψε:Πείραξες τίποτα στο BIOS, όπως για παράδειγμα το boot order?
ειχα εδω και μηνες να μπω στο λειτουργικο των windows 7 και σημερα ηθελα να μπω το πρωι συνδεθηκα και καπου εκει κρασαρε το συστημα και μετα ανοιξα τον υπολογιστη και εβγαλα τα καλωδια και των 2 δισκων και τα ξανα συνδεσα, επειτα συνεβη οτι αρχιζα να ποσταρω
Tuxer
