Το πρόβλημα παρουσιάζεται στο ακόλουθο Dell Latitude laptop (έχω πρόβλημα και με το software της υπογραφής):
2 Ubuntu 16.04 xenial 64bit (en_US.UTF-8),
3 Intel Core i5-2520M CPU @ 2.50GHz ‖ RAM 7863 MiB ‖ Dell Inc. 0R97MN - Dell Inc. Latitude E6220
4 Intel 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0126] (rev 09)
5 wlp2s0: Intel Centrino Advanced-N 6205 [Taylor Peak] [8086:0082] (rev 34) ⋮ enp0s25: Intel 82579LM Gigabit Network Connection [8086:1502] (rev 04)
Δε ξέρω αν βοηθάει, αλλά να και το dmesg:
$ dmesg
[ 0.000000] microcode: CPU0 microcode updated early to revision 0x29, date = 2013-06-12
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-28-generic (buildd@lcy01-13) (gcc version 5.3.1 20160413 (Ubuntu 5.3.1-14ubuntu2.1) ) #47-Ubuntu SMP Fri Jun 24 10:09:13 UTC 2016 (Ubuntu 4.4.0-28.47-generic 4.4.13)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-28-generic root=UUID=23f7b308-bb51-443d-8552-f40c7ed395f5 ro quiet splash vt.handoff=7
[ 0.000000] AMD AuthenticAMD
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x04: 'AVX registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] x86/fpu: Using 'eager' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009a7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009a800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040200000-0x00000000caa24fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000caa25000-0x00000000caa68fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000caa69000-0x00000000cadb6fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cadb7000-0x00000000cade6fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cade7000-0x00000000cafe6fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cafe7000-0x00000000caffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cafff000-0x00000000caffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cb800000-0x00000000cf9fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffc00000-0x00000000ffc1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022dffffff] usable
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: Dell Inc. Latitude E6220/0R97MN, BIOS A10 08/19/2012
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x22e000 max_arch_pfn = 0x400000000
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FC0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FF8000000 write-back
[ 0.000000] 3 base 0C8000000 mask FFC000000 write-back
[ 0.000000] 4 base 0CB000000 mask FFF000000 uncachable
[ 0.000000] 5 base 100000000 mask F00000000 write-back
[ 0.000000] 6 base 200000000 mask FE0000000 write-back
[ 0.000000] 7 base 220000000 mask FF0000000 write-back
[ 0.000000] 8 base 22E000000 mask FFE000000 uncachable
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 2GB, type WB
[ 0.000000] reg 1, base: 2GB, range: 1GB, type WB
[ 0.000000] reg 2, base: 3GB, range: 128MB, type WB
[ 0.000000] reg 3, base: 3200MB, range: 64MB, type WB
[ 0.000000] reg 4, base: 3248MB, range: 16MB, type UC
[ 0.000000] reg 5, base: 4GB, range: 4GB, type WB
[ 0.000000] reg 6, base: 8GB, range: 512MB, type WB
[ 0.000000] reg 7, base: 8704MB, range: 256MB, type WB
[ 0.000000] reg 8, base: 8928MB, range: 32MB, type UC
[ 0.000000] total RAM covered: 8080M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 64M num_reg: 9 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] e820: update [mem 0xcb000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xcb000 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000f1fb0-0x000f1fbf] mapped at [ffff8800000f1fb0]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000094000] 94000 size 24576
[ 0.000000] reserving inaccessible SNB gfx pages
[ 0.000000] BRK [0x02200000, 0x02200fff] PGTABLE
[ 0.000000] BRK [0x02201000, 0x02201fff] PGTABLE
[ 0.000000] BRK [0x02202000, 0x02202fff] PGTABLE
[ 0.000000] BRK [0x02203000, 0x02203fff] PGTABLE
[ 0.000000] BRK [0x02204000, 0x02204fff] PGTABLE
[ 0.000000] BRK [0x02205000, 0x02205fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x33b5a000-0x35da4fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FE300 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000CAFFDE18 00007C (v01 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: FACP 0x00000000CAF87D98 0000F4 (v04 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: DSDT 0x00000000CAF66018 00849F (v02 INT430 SYSFexxx 00001001 INTL 20090903)
[ 0.000000] ACPI: FACS 0x00000000CAFE4E40 000040
[ 0.000000] ACPI: FACS 0x00000000CAFE4D40 000040
[ 0.000000] ACPI: APIC 0x00000000CAFFCF18 0000CC (v02 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] ACPI: TCPA 0x00000000CAFE5D18 000032 (v02 00000000 00000000)
[ 0.000000] ACPI: SSDT 0x00000000CAF88A98 0002F9 (v01 DELLTP TPM 00003000 INTL 20090903)
[ 0.000000] ACPI: MCFG 0x00000000CAFE5C98 00003C (v01 DELL SNDYBRDG 06222004 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000CAFE5C18 000038 (v01 A M I PCHHPET 06222004 AMI. 00000003)
[ 0.000000] ACPI: BOOT 0x00000000CAFE5B98 000028 (v01 DELL CBX3 06222004 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000CAF7D018 000804 (v01 PmRef Cpu0Ist 00003000 INTL 20090903)
[ 0.000000] ACPI: SSDT 0x00000000CAF7C018 000996 (v01 PmRef CpuPm 00003000 INTL 20090903)
[ 0.000000] ACPI: DMAR 0x00000000CAF87C18 0000E8 (v01 INTEL SNB 00000001 INTL 00000001)
[ 0.000000] ACPI: SLIC 0x00000000CAF86C18 000176 (v03 DELL CBX3 06222004 MSFT 00010013)
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000022dffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x22dff3000-0x22dff7fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000022dffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x0000000000099fff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x000000001fffffff]
[ 0.000000] node 0: [mem 0x0000000020200000-0x000000003fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000caa24fff]
[ 0.000000] node 0: [mem 0x00000000caa69000-0x00000000cadb6fff]
[ 0.000000] node 0: [mem 0x00000000cafff000-0x00000000caffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000022dffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000022dffffff]
[ 0.000000] On node 0 totalpages: 2066701
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 153 pages reserved
[ 0.000000] DMA zone: 3993 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 12902 pages used for memmap
[ 0.000000] DMA32 zone: 825716 pages, LIFO batch:31
[ 0.000000] Normal zone: 19328 pages used for memmap
[ 0.000000] Normal zone: 1236992 pages, LIFO batch:31
[ 0.000000] Reserving Intel graphics stolen memory at 0xcba00000-0xcf9fffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 16 CPUs, 12 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009a000-0x0009afff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009b000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x40000000-0x401fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcaa25000-0xcaa68fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcadb7000-0xcade6fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcade7000-0xcafe6fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcafe7000-0xcaffefff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcb000000-0xcb7fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcb800000-0xcf9fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcfa00000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xffbfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffc00000-0xffc1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffc20000-0xffffffff]
[ 0.000000] e820: [mem 0xcfa00000-0xfed1bfff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:16 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 33 pages/cpu @ffff880225200000 s98008 r8192 d28968 u262144
[ 0.000000] pcpu-alloc: s98008 r8192 d28968 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 2034254
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-28-generic root=UUID=23f7b308-bb51-443d-8552-f40c7ed395f5 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 8013080K/8266804K available (8368K kernel code, 1280K rwdata, 3928K rodata, 1480K init, 1292K bss, 253724K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=16.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=16
[ 0.000000] NR_IRQS:16640 nr_irqs:552 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2494.431 MHz processor
[ 0.000035] Calibrating delay loop (skipped), value calculated using timer frequency.. 4988.86 BogoMIPS (lpj=9977724)
[ 0.000038] pid_max: default: 32768 minimum: 301
[ 0.000044] ACPI: Core revision 20150930
[ 0.006317] ACPI: 4 ACPI AML tables successfully acquired and loaded
[ 0.006341] Security Framework initialized
[ 0.006342] Yama: becoming mindful.
[ 0.006361] AppArmor: AppArmor initialized
[ 0.006858] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.008471] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.009174] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.009184] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.009390] Initializing cgroup subsys io
[ 0.009394] Initializing cgroup subsys memory
[ 0.009400] Initializing cgroup subsys devices
[ 0.009402] Initializing cgroup subsys freezer
[ 0.009404] Initializing cgroup subsys net_cls
[ 0.009406] Initializing cgroup subsys perf_event
[ 0.009408] Initializing cgroup subsys net_prio
[ 0.009410] Initializing cgroup subsys hugetlb
[ 0.009413] Initializing cgroup subsys pids
[ 0.009433] CPU: Physical Processor ID: 0
[ 0.009434] CPU: Processor Core ID: 0
[ 0.009439] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.009440] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.009442] mce: CPU supports 7 MCE banks
[ 0.009453] CPU0: Thermal monitoring enabled (TM1)
[ 0.009460] process: using mwait in idle threads
[ 0.009463] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.009464] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.009870] Freeing SMP alternatives memory: 28K (ffffffff820b4000 - ffffffff820bb000)
[ 0.012756] ftrace: allocating 31920 entries in 125 pages
[ 0.028130] smpboot: Max logical packages: 8
[ 0.028133] smpboot: APIC(0) Converting physical 0 to logical package 0
[ 0.028145] DMAR: Host address width 36
[ 0.028147] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.028153] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[ 0.028154] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.028158] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[ 0.028159] DMAR: RMRR base: 0x000000cadc6000 end: 0x000000cadd5fff
[ 0.028161] DMAR: RMRR base: 0x000000cb800000 end: 0x000000cf9fffff
[ 0.028163] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.028164] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.028165] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.028532] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.028536] x2apic enabled
[ 0.028542] Switched APIC routing to cluster x2apic.
[ 0.028971] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.068660] TSC deadline timer enabled
[ 0.068665] smpboot: CPU0: Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz (family: 0x6, model: 0x2a, stepping: 0x7)
[ 0.068689] Performance Events: PEBS fmt1+, 16-deep LBR, SandyBridge events, full-width counters, Intel PMU driver.
[ 0.068710] ... version: 3
[ 0.068711] ... bit width: 48
[ 0.068712] ... generic registers: 4
[ 0.068713] ... value mask: 0000ffffffffffff
[ 0.068714] ... max period: 0000ffffffffffff
[ 0.068715] ... fixed-purpose events: 3
[ 0.068716] ... event mask: 000000070000000f
[ 0.069541] x86: Booting SMP configuration:
[ 0.069543] .... node #0, CPUs: #1
[ 0.070123] microcode: CPU1 microcode updated early to revision 0x29, date = 2013-06-12
[ 0.072405] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.072494] #2 #3
[ 0.077251] x86: Booted up 1 node, 4 CPUs
[ 0.077254] smpboot: Total of 4 processors activated (19955.44 BogoMIPS)
[ 0.080411] devtmpfs: initialized
[ 0.083003] evm: security.selinux
[ 0.083005] evm: security.SMACK64
[ 0.083006] evm: security.SMACK64EXEC
[ 0.083007] evm: security.SMACK64TRANSMUTE
[ 0.083008] evm: security.SMACK64MMAP
[ 0.083008] evm: security.ima
[ 0.083009] evm: security.capability
[ 0.083073] PM: Registering ACPI NVS region [mem 0xcade7000-0xcafe6fff] (2097152 bytes)
[ 0.083110] reboot: Dell Latitude E6220 series board detected. Selecting PCI-method for reboots.
[ 0.083178] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.083264] pinctrl core: initialized pinctrl subsystem
[ 0.083374] RTC time: 11:20:38, date: 07/11/16
[ 0.083481] NET: Registered protocol family 16
[ 0.093257] cpuidle: using governor ladder
[ 0.105262] cpuidle: using governor menu
[ 0.105274] PCCT header not found.
[ 0.105353] Simple Boot Flag at 0xf3 set to 0x1
[ 0.105382] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.105383] ACPI: bus type PCI registered
[ 0.105385] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.105461] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.105463] PCI: not using MMCONFIG
[ 0.105464] PCI: Using configuration type 1 for base access
[ 0.105471] dmi type 0xB1 record - unknown flag
[ 0.105504] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.121658] ACPI: Added _OSI(Module Device)
[ 0.121660] ACPI: Added _OSI(Processor Device)
[ 0.121661] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.121663] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.125839] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.140632] ACPI: Dynamic OEM Table Load:
[ 0.140640] ACPI: SSDT 0xFFFF8802235EB000 000727 (v01 PmRef Cpu0Cst 00003001 INTL 20090903)
[ 0.141097] ACPI: Dynamic OEM Table Load:
[ 0.141102] ACPI: SSDT 0xFFFF88022361B000 000303 (v01 PmRef ApIst 00003000 INTL 20090903)
[ 0.141490] ACPI: Dynamic OEM Table Load:
[ 0.141494] ACPI: SSDT 0xFFFF880223660200 000119 (v01 PmRef ApCst 00003000 INTL 20090903)
[ 0.142204] ACPI : EC: EC started
[ 0.143063] ACPI: Interpreter enabled
[ 0.143070] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20150930/hwxface-580)
[ 0.143074] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150930/hwxface-580)
[ 0.143087] ACPI: (supports S0 S3 S4 S5)
[ 0.143089] ACPI: Using IOAPIC for interrupt routing
[ 0.143112] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.143453] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources
[ 0.143461] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.154681] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.154687] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.154717] \_SB_.PCI0:_OSC invalid UUID
[ 0.154718] _OSC request data:1 1f 0
[ 0.154722] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.155128] PCI host bridge to bus 0000:00
[ 0.155131] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.155133] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.155134] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.155136] pci_bus 0000:00: root bus resource [mem 0xcfa00000-0xfeafffff window]
[ 0.155138] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[ 0.155140] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.155147] pci 0000:00:00.0: [8086:0104] type 00 class 0x060000
[ 0.155233] pci 0000:00:02.0: [8086:0126] type 00 class 0x030000
[ 0.155246] pci 0000:00:02.0: reg 0x10: [mem 0xe0c00000-0xe0ffffff 64bit]
[ 0.155251] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.155256] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.155354] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[ 0.155387] pci 0000:00:16.0: reg 0x10: [mem 0xe1cb0000-0xe1cb000f 64bit]
[ 0.155452] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.155524] pci 0000:00:16.3: [8086:1c3d] type 00 class 0x070002
[ 0.155552] pci 0000:00:16.3: reg 0x10: [io 0x30e0-0x30e7]
[ 0.155561] pci 0000:00:16.3: reg 0x14: [mem 0xe1c90000-0xe1c90fff]
[ 0.155687] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[ 0.155714] pci 0000:00:19.0: reg 0x10: [mem 0xe1c00000-0xe1c1ffff]
[ 0.155723] pci 0000:00:19.0: reg 0x14: [mem 0xe1c80000-0xe1c80fff]
[ 0.155732] pci 0000:00:19.0: reg 0x18: [io 0x3080-0x309f]
[ 0.155783] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.155995] pci 0000:00:19.0: System wakeup disabled by ACPI
[ 0.156039] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[ 0.156068] pci 0000:00:1a.0: reg 0x10: [mem 0xe1c70000-0xe1c703ff]
[ 0.156143] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.156183] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.156224] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[ 0.156251] pci 0000:00:1b.0: reg 0x10: [mem 0xe1c60000-0xe1c63fff 64bit]
[ 0.156314] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.156357] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.156406] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[ 0.156530] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.156579] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.156622] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[ 0.156749] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.156799] pci 0000:00:1c.1: System wakeup disabled by ACPI
[ 0.156843] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[ 0.156969] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.157016] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.157057] pci 0000:00:1c.5: [8086:1c1a] type 01 class 0x060400
[ 0.157138] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.157180] pci 0000:00:1c.5: System wakeup disabled by ACPI
[ 0.157221] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[ 0.157250] pci 0000:00:1d.0: reg 0x10: [mem 0xe1c50000-0xe1c503ff]
[ 0.157324] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.157362] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.157401] pci 0000:00:1f.0: [8086:1c4f] type 00 class 0x060100
[ 0.157567] pci 0000:00:1f.2: [8086:1c03] type 00 class 0x010601
[ 0.157592] pci 0000:00:1f.2: reg 0x10: [io 0x30d0-0x30d7]
[ 0.157600] pci 0000:00:1f.2: reg 0x14: [io 0x30c0-0x30c3]
[ 0.157608] pci 0000:00:1f.2: reg 0x18: [io 0x30b0-0x30b7]
[ 0.157616] pci 0000:00:1f.2: reg 0x1c: [io 0x30a0-0x30a3]
[ 0.157624] pci 0000:00:1f.2: reg 0x20: [io 0x3060-0x307f]
[ 0.157632] pci 0000:00:1f.2: reg 0x24: [mem 0xe1c40000-0xe1c407ff]
[ 0.157665] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.157733] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[ 0.157751] pci 0000:00:1f.3: reg 0x10: [mem 0xe1c30000-0xe1c300ff 64bit]
[ 0.157772] pci 0000:00:1f.3: reg 0x20: [io 0x3040-0x305f]
[ 0.157919] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.158167] pci 0000:02:00.0: [8086:0082] type 00 class 0x028000
[ 0.158425] pci 0000:02:00.0: reg 0x10: [mem 0xe1b00000-0xe1b01fff 64bit]
[ 0.159045] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.159189] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.164503] pci 0000:00:1c.1: PCI bridge to [bus 02]
[ 0.164513] pci 0000:00:1c.1: bridge window [mem 0xe1b00000-0xe1bfffff]
[ 0.164612] acpiphp: Slot [1] registered
[ 0.164619] pci 0000:00:1c.2: PCI bridge to [bus 03-08]
[ 0.164624] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.164629] pci 0000:00:1c.2: bridge window [mem 0xe1000000-0xe19fffff]
[ 0.164638] pci 0000:00:1c.2: bridge window [mem 0xe0000000-0xe09fffff 64bit pref]
[ 0.164736] pci 0000:09:00.0: [1217:8221] type 00 class 0x080501
[ 0.164828] pci 0000:09:00.0: reg 0x10: [mem 0xe1a20000-0xe1a201ff]
[ 0.165107] pci 0000:09:00.0: supports D1 D2
[ 0.165109] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.165178] pci 0000:09:00.0: System wakeup disabled by ACPI
[ 0.165248] pci 0000:09:00.1: [1217:8231] type 00 class 0x018000
[ 0.165339] pci 0000:09:00.1: reg 0x10: [mem 0xe1a10000-0xe1a10fff]
[ 0.165392] pci 0000:09:00.1: reg 0x18: [mem 0xe1a00000-0xe1a007ff]
[ 0.165609] pci 0000:09:00.1: supports D1 D2
[ 0.165610] pci 0000:09:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.172458] pci 0000:00:1c.5: PCI bridge to [bus 09]
[ 0.172464] pci 0000:00:1c.5: bridge window [mem 0xe1a00000-0xe1afffff]
[ 0.173753] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.173800] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.173845] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.173890] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.173934] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.173978] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.174023] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 *3 4 5 6 7 10 12 14 15)
[ 0.174066] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
[ 0.175409] ACPI: Enabled 2 GPEs in block 00 to 3F
[ 0.175458] ACPI : EC: GPE = 0x10, I/O: command/status = 0x934, data = 0x930
[ 0.175563] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.175566] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.175568] vgaarb: loaded
[ 0.175570] vgaarb: bridge control possible 0000:00:02.0
[ 0.175774] SCSI subsystem initialized
[ 0.175823] libata version 3.00 loaded.
[ 0.175844] ACPI: bus type USB registered
[ 0.175859] usbcore: registered new interface driver usbfs
[ 0.175867] usbcore: registered new interface driver hub
[ 0.175887] usbcore: registered new device driver usb
[ 0.176024] PCI: Using ACPI for IRQ routing
[ 0.177698] PCI: pci_cache_line_size set to 64 bytes
[ 0.177812] e820: reserve RAM buffer [mem 0x0009a800-0x0009ffff]
[ 0.177813] e820: reserve RAM buffer [mem 0xcaa25000-0xcbffffff]
[ 0.177815] e820: reserve RAM buffer [mem 0xcadb7000-0xcbffffff]
[ 0.177817] e820: reserve RAM buffer [mem 0xcb000000-0xcbffffff]
[ 0.177818] e820: reserve RAM buffer [mem 0x22e000000-0x22fffffff]
[ 0.177930] NetLabel: Initializing
[ 0.177931] NetLabel: domain hash size = 128
[ 0.177932] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.177943] NetLabel: unlabeled traffic allowed by default
[ 0.178017] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.178022] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.180048] clocksource: Switched to clocksource hpet
[ 0.185958] AppArmor: AppArmor Filesystem Enabled
[ 0.186026] pnp: PnP ACPI init
[ 0.186178] system 00:00: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.186183] system 00:00: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
[ 0.186225] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.186227] system 00:01: [io 0x1000-0x100f] has been reserved
[ 0.186228] system 00:01: [io 0xffff] has been reserved
[ 0.186230] system 00:01: [io 0xffff] has been reserved
[ 0.186232] system 00:01: [io 0x0400-0x047f] could not be reserved
[ 0.186234] system 00:01: [io 0x0500-0x057f] has been reserved
[ 0.186236] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.186238] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.186264] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.186286] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.186893] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (disabled)
[ 0.186916] pnp 00:05: Plug and Play ACPI device, IDs DLL04a9 PNP0f13 (active)
[ 0.187066] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.187068] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.187070] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.187071] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.187073] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.187075] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.187077] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.187079] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.187081] system 00:06: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.187083] system 00:06: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.187085] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.188633] system 00:07: [mem 0x20000000-0x201fffff] has been reserved
[ 0.188636] system 00:07: [mem 0x40000000-0x401fffff] has been reserved
[ 0.188639] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.188645] pnp: PnP ACPI: found 8 devices
[ 0.195104] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.195156] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.195174] pci 0000:00:1c.1: PCI bridge to [bus 02]
[ 0.195181] pci 0000:00:1c.1: bridge window [mem 0xe1b00000-0xe1bfffff]
[ 0.195193] pci 0000:00:1c.2: PCI bridge to [bus 03-08]
[ 0.195196] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.195203] pci 0000:00:1c.2: bridge window [mem 0xe1000000-0xe19fffff]
[ 0.195208] pci 0000:00:1c.2: bridge window [mem 0xe0000000-0xe09fffff 64bit pref]
[ 0.195217] pci 0000:00:1c.5: PCI bridge to [bus 09]
[ 0.195222] pci 0000:00:1c.5: bridge window [mem 0xe1a00000-0xe1afffff]
[ 0.195232] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.195234] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.195235] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.195237] pci_bus 0000:00: resource 7 [mem 0xcfa00000-0xfeafffff window]
[ 0.195239] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff window]
[ 0.195241] pci_bus 0000:02: resource 1 [mem 0xe1b00000-0xe1bfffff]
[ 0.195242] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.195244] pci_bus 0000:03: resource 1 [mem 0xe1000000-0xe19fffff]
[ 0.195246] pci_bus 0000:03: resource 2 [mem 0xe0000000-0xe09fffff 64bit pref]
[ 0.195247] pci_bus 0000:09: resource 1 [mem 0xe1a00000-0xe1afffff]
[ 0.195282] NET: Registered protocol family 2
[ 0.195450] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.195582] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.195708] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.195736] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.195765] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.195845] NET: Registered protocol family 1
[ 0.195861] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.196296] PCI: CLS 64 bytes, default 64
[ 0.196347] Trying to unpack rootfs image as initramfs...
[ 0.733067] Freeing initrd memory: 35116K (ffff880033b5a000 - ffff880035da5000)
[ 0.733128] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.733131] software IO TLB [mem 0xc6a25000-0xcaa25000] (64MB) mapped at [ffff8800c6a25000-ffff8800caa24fff]
[ 0.733208] RAPL PMU detected, API unit is 2^-32 Joules, 3 fixed counters 163840 ms ovfl timer
[ 0.733209] hw unit of domain pp0-core 2^-16 Joules
[ 0.733210] hw unit of domain package 2^-16 Joules
[ 0.733211] hw unit of domain pp1-gpu 2^-16 Joules
[ 0.733304] Scanning for low memory corruption every 60 seconds
[ 0.733769] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.733826] audit: initializing netlink subsys (disabled)
[ 0.733840] audit: type=2000 audit(1468236038.728:1): initialized
[ 0.734213] Initialise system trusted keyring
[ 0.734326] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.735779] zbud: loaded
[ 0.735972] VFS: Disk quotas dquot_6.6.0
[ 0.736009] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.736533] fuse init (API version 7.23)
[ 0.736675] Key type big_key registered
[ 0.736701] Allocating IMA MOK and blacklist keyrings.
[ 0.737095] Key type asymmetric registered
[ 0.737098] Asymmetric key parser 'x509' registered
[ 0.737133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.737171] io scheduler noop registered
[ 0.737175] io scheduler deadline registered (default)
[ 0.737206] io scheduler cfq registered
[ 0.737861] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.737868] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.737897] vesafb: mode is 1366x768x32, linelength=5504, pages=0
[ 0.737898] vesafb: scrolling: redraw
[ 0.737900] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.737911] vesafb: framebuffer at 0xd0000000, mapped to 0xffffc90001000000, using 4160k, total 4160k
[ 0.738007] Console: switching to colour frame buffer device 170x48
[ 0.738023] fb0: VESA VGA frame buffer device
[ 0.738041] intel_idle: MWAIT substates: 0x21120
[ 0.738042] intel_idle: v0.4.1 model 0x2A
[ 0.738043] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.738502] ACPI: AC Adapter [AC] (on-line)
[ 0.738558] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.738802] ACPI: Lid Switch [LID]
[ 0.738839] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.738842] ACPI: Power Button [PBTN]
[ 0.738874] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.738876] ACPI: Sleep Button [SBTN]
[ 0.738909] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.738911] ACPI: Power Button [PWRF]
[ 0.739781] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.739783] ACPI: Thermal Zone [THM] (25 C)
[ 0.739809] GHES: HEST is not enabled!
[ 0.739911] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.762147] 0000:00:16.3: ttyS4 at I/O 0x30e0 (irq = 17, base_baud = 115200) is a 16550A
[ 0.762658] Linux agpgart interface v0.103
[ 0.766311] brd: module loaded
[ 0.767811] loop: module loaded
[ 0.768016] libphy: Fixed MDIO Bus: probed
[ 0.768020] tun: Universal TUN/TAP device driver, 1.6
[ 0.768021] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.768097] PPP generic driver version 2.4.2
[ 0.768156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.768160] ehci-pci: EHCI PCI platform driver
[ 0.768321] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.768327] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.768339] ehci-pci 0000:00:1a.0: debug port 2
[ 0.770664] ACPI: Battery Slot [BAT0] (battery present)
[ 0.772250] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.772268] ehci-pci 0000:00:1a.0: irq 16, io mem 0xe1c70000
[ 0.772834] ACPI: Battery Slot [BAT1] (battery absent)
[ 0.784097] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.784149] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.784151] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.784153] usb usb1: Product: EHCI Host Controller
[ 0.784155] usb usb1: Manufacturer: Linux 4.4.0-28-generic ehci_hcd
[ 0.784156] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.784324] hub 1-0:1.0: USB hub found
[ 0.784332] hub 1-0:1.0: 3 ports detected
[ 0.784537] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.784543] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.784553] ehci-pci 0000:00:1d.0: debug port 2
[ 0.788452] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.788465] ehci-pci 0000:00:1d.0: irq 17, io mem 0xe1c50000
[ 0.800103] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.800142] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.800144] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.800146] usb usb2: Product: EHCI Host Controller
[ 0.800147] usb usb2: Manufacturer: Linux 4.4.0-28-generic ehci_hcd
[ 0.800149] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.800307] hub 2-0:1.0: USB hub found
[ 0.800315] hub 2-0:1.0: 3 ports detected
[ 0.800426] ehci-platform: EHCI generic platform driver
[ 0.800438] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.800443] ohci-pci: OHCI PCI platform driver
[ 0.800453] ohci-platform: OHCI generic platform driver
[ 0.800461] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.800521] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.800895] i8042: Warning: Keylock active
[ 0.802128] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.802133] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.802349] mousedev: PS/2 mouse device common for all mice
[ 0.802699] rtc_cmos 00:02: RTC can wake from S4
[ 0.802851] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.802889] rtc_cmos 00:02: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 0.802897] i2c /dev entries driver
[ 0.802951] device-mapper: uevent: version 1.0.3
[ 0.803021] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 0.803041] Intel P-state driver initializing.
[ 0.803205] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.803651] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.804297] NET: Registered protocol family 10
[ 0.804822] NET: Registered protocol family 17
[ 0.804857] Key type dns_resolver registered
[ 0.805419] microcode: CPU0 sig=0x206a7, pf=0x10, revision=0x29
[ 0.805442] microcode: CPU1 sig=0x206a7, pf=0x10, revision=0x29
[ 0.805466] microcode: CPU2 sig=0x206a7, pf=0x10, revision=0x29
[ 0.805489] microcode: CPU3 sig=0x206a7, pf=0x10, revision=0x29
[ 0.805650] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.806171] registered taskstats version 1
[ 0.806213] Loading compiled-in X.509 certificates
[ 0.808420] Loaded X.509 cert 'Build time autogenerated kernel key: 6ea974e07bd0b30541f4d838a3b7a8a80d5ca9af'
[ 0.808439] zswap: loaded using pool lzo/zbud
[ 0.810145] Key type trusted registered
[ 0.812605] Key type encrypted registered
[ 0.812610] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.812612] ima: No TPM chip found, activating TPM-bypass!
[ 0.812630] evm: HMAC attrs: 0x1
[ 0.812983] Magic number: 8:269:327
[ 0.813079] rtc_cmos 00:02: setting system clock to 2016-07-11 11:20:39 UTC (1468236039)
[ 0.813155] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.813157] EDD information not available.
[ 0.813220] PM: Hibernation image not present or could not be loaded.
[ 0.814345] Freeing unused kernel memory: 1480K (ffffffff81f42000 - ffffffff820b4000)
[ 0.814346] Write protecting the kernel read-only data: 14336k
[ 0.814756] Freeing unused kernel memory: 1860K (ffff88000182f000 - ffff880001a00000)
[ 0.815104] Freeing unused kernel memory: 168K (ffff880001dd6000 - ffff880001e00000)
[ 0.823129] random: systemd-udevd urandom read with 3 bits of entropy available
[ 0.847161] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[ 0.853941] wmi: Mapper loaded
[ 0.856883] pps_core: LinuxPPS API ver. 1 registered
[ 0.856886] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.858232] PTP clock support registered
[ 0.860128] sdhci: Secure Digital Host Controller Interface driver
[ 0.860131] sdhci: Copyright(c) Pierre Ossman
[ 0.862298] sdhci-pci 0000:09:00.0: SDHCI controller found [1217:8221] (rev 5)
[ 0.862489] sdhci-pci 0000:09:00.0: No vmmc regulator found
[ 0.862491] sdhci-pci 0000:09:00.0: No vqmmc regulator found
[ 0.863168] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 0.863171] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.863356] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 0.863636] mmc0: SDHCI controller on PCI [0000:09:00.0] using DMA
[ 0.864852] [drm] Initialized drm 1.1.0 20060810
[ 1.064897] e1000e 0000:00:19.0 eth0: registered PHC clock
[ 1.064900] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 84:8f:69:f0:8d:84
[ 1.064902] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 1.064934] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: 9041FF-0FF
[ 1.064965] ahci 0000:00:1f.2: version 3.0
[ 1.065153] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.065490] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[ 1.080182] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3b impl SATA mode
[ 1.080187] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems sxs apst
[ 1.096138] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.112670] scsi host0: ahci
[ 1.112779] scsi host1: ahci
[ 1.112871] scsi host2: ahci
[ 1.112962] scsi host3: ahci
[ 1.113050] scsi host4: ahci
[ 1.113139] scsi host5: ahci
[ 1.113178] ata1: SATA max UDMA/133 abar m2048@0xe1c40000 port 0xe1c40100 irq 27
[ 1.113181] ata2: SATA max UDMA/133 abar m2048@0xe1c40000 port 0xe1c40180 irq 27
[ 1.113182] ata3: DUMMY
[ 1.113184] ata4: SATA max UDMA/133 abar m2048@0xe1c40000 port 0xe1c40280 irq 27
[ 1.113186] ata5: SATA max UDMA/133 abar m2048@0xe1c40000 port 0xe1c40300 irq 27
[ 1.113189] ata6: SATA max UDMA/133 abar m2048@0xe1c40000 port 0xe1c40380 irq 27
[ 1.113835] [drm] Memory usable by graphics device = 2048M
[ 1.113838] checking generic (d0000000 410000) vs hw (d0000000 10000000)
[ 1.113839] fb: switching to inteldrmfb from VESA VGA
[ 1.113862] Console: switching to colour dummy device 80x25
[ 1.113908] [drm] Replacing VGA console driver
[ 1.120055] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.120119] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.120121] [drm] Driver supports precise vblank timestamp query.
[ 1.120664] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.141114] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 1.146050] acpi device:39: registered as cooling_device4
[ 1.146784] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[ 1.146860] [drm] Initialized i915 1.6.0 20151010 for 0000:00:02.0 on minor 0
[ 1.228487] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.228498] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.228729] hub 1-1:1.0: USB hub found
[ 1.228818] hub 1-1:1.0: 6 ports detected
[ 1.252490] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.252500] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.252707] hub 2-1:1.0: USB hub found
[ 1.252875] hub 2-1:1.0: 8 ports detected
[ 1.432124] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.434209] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.434312] ata1.00: supports DRM functions and may not be fully accessible
[ 1.434706] ata1.00: disabling queued TRIM support
[ 1.434713] ata1.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT02B6Q, max UDMA/133
[ 1.434718] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.435681] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1.435737] ata1.00: supports DRM functions and may not be fully accessible
[ 1.436074] ata1.00: disabling queued TRIM support
[ 1.436511] ata1.00: configured for UDMA/133
[ 1.436753] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 2B6Q PQ: 0 ANSI: 5
[ 1.437034] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 1.437070] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.437088] sd 0:0:0:0: [sda] Write Protect is off
[ 1.437091] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.437110] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.437545] sda: sda1 sda2 sda3
[ 1.437809] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.500121] usb 1-1.5: new high-speed USB device number 3 using ehci-pci
[ 1.524126] usb 2-1.3: new full-speed USB device number 3 using ehci-pci
[ 1.532769] fbcon: inteldrmfb (fb0) is primary device
[ 1.532824] Console: switching to colour frame buffer device 170x48
[ 1.532841] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 1.621602] usb 2-1.3: New USB device found, idVendor=248a, idProduct=8367
[ 1.621613] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.621619] usb 2-1.3: Product: Wireless Receiver
[ 1.621624] usb 2-1.3: Manufacturer: Telink
[ 1.625045] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.631720] usbcore: registered new interface driver usbhid
[ 1.631722] usbhid: USB HID core driver
[ 1.633084] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/0003:248A:8367.0001/input/input8
[ 1.688135] hid-generic 0003:248A:8367.0001: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input0
[ 1.688235] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:248A:8367.0002/input/input9
[ 1.691997] usb 2-1.8: new full-speed USB device number 4 using ehci-pci
[ 1.713563] usb 1-1.5: New USB device found, idVendor=1bcf, idProduct=2804
[ 1.713567] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.713568] usb 1-1.5: Product: Laptop_Integrated_Webcam_HD
[ 1.713570] usb 1-1.5: Manufacturer: CN018T967248719N01NDA01
[ 1.732025] tsc: Refined TSC clocksource calibration: 2494.333 MHz
[ 1.732031] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23f45085418, max_idle_ns: 440795285711 ns
[ 1.744319] hid-generic 0003:248A:8367.0002: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input1
[ 1.756122] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.812677] usb 2-1.8: New USB device found, idVendor=0a5c, idProduct=5800
[ 1.812680] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.812681] usb 2-1.8: Product: 5880
[ 1.812683] usb 2-1.8: Manufacturer: Broadcom Corp
[ 1.812684] usb 2-1.8: SerialNumber: 0123456789ABCD
[ 1.812865] usb 2-1.8: config 0 descriptor??
[ 2.061566] input: AlpsPS/2 ALPS DualPoint Stick as /devices/platform/i8042/serio1/input/input10
[ 2.074877] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input6
[ 2.084105] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.404087] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.724072] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.732017] clocksource: Switched to clocksource tsc
[ 2.770106] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.837463] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 2.837570] systemd[1]: Detected architecture x86-64.
[ 2.837704] systemd[1]: Set hostname to <bob-Latitude-E6220>.
[ 2.902375] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.902425] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.902433] systemd[1]: Reached target User and Group Name Lookups.
[ 2.902458] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.902527] systemd[1]: Created slice User and Session Slice.
[ 2.902573] systemd[1]: Created slice System Slice.
[ 2.902628] systemd[1]: Created slice system-getty.slice.
[ 2.902652] systemd[1]: Listening on Syslog Socket.
[ 2.902678] systemd[1]: Listening on Journal Socket.
[ 2.916154] systemd[1]: Starting Uncomplicated firewall...
[ 2.916526] systemd[1]: Mounting Debug File System...
[ 2.916978] systemd[1]: Started Braille Device Support.
[ 2.917606] systemd[1]: Started Read required files in advance.
[ 2.917797] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.917923] systemd[1]: Listening on Journal Audit Socket.
[ 2.919765] systemd[1]: Starting Load Kernel Modules...
[ 2.920280] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.921113] systemd[1]: Reached target Remote File Systems.
[ 2.921165] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.921522] systemd[1]: Mounting Huge Pages File System...
[ 2.921542] systemd[1]: Reached target Encrypted Volumes.
[ 2.921600] systemd[1]: Listening on udev Kernel Socket.
[ 2.921650] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.922127] systemd[1]: Starting Journal Service...
[ 2.922201] systemd[1]: Listening on udev Control Socket.
[ 2.923494] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.923516] systemd[1]: Reached target Slices.
[ 2.924494] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.925950] systemd[1]: Mounted Huge Pages File System.
[ 2.925976] systemd[1]: Mounted Debug File System.
[ 2.925988] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.926179] systemd[1]: Started Uncomplicated firewall.
[ 2.930418] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 2.935956] lp: driver loaded but no devices found
[ 2.939103] ppdev: user-space parallel port driver
[ 2.941875] parport_pc 00:04: [io 0x0378-0x037b]
[ 2.941965] parport_pc 00:04: [irq 5]
[ 2.943723] parport_pc 00:04: activated
[ 2.943728] parport_pc 00:04: reported by Plug and Play ACPI
[ 2.943883] parport_pc 00:04: disabled
[ 2.945899] systemd[1]: Started Load Kernel Modules.
[ 2.968077] systemd[1]: Mounting FUSE Control File System...
[ 2.968637] systemd[1]: Starting Apply Kernel Variables...
[ 2.969297] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.971531] systemd[1]: Mounted FUSE Control File System.
[ 2.971645] systemd[1]: Started Journal Service.
[ 3.001925] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.035368] systemd-journald[248]: Received request to flush runtime journal from PID 1
[ 3.107998] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.159027] Intel(R) Wireless WiFi driver for Linux
[ 3.159029] Copyright(c) 2003- 2015 Intel Corporation
[ 3.159280] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.162347] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150930/utaddress-254)
[ 3.162353] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.162357] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[ 3.162360] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.162361] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[ 3.162363] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.162364] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[ 3.162366] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.162367] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 3.169049] iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[ 3.201844] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 3.201848] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 3.201851] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 3.201853] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N 6205 AGN, REV=0xB0
[ 3.202394] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[ 3.214261] media: Linux media interface: v0.10
[ 3.218410] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 3.224682] AVX version of gcm_enc/dec engaged.
[ 3.224686] AES CTR mode by8 optimization enabled
[ 3.228177] Adding 8514556k swap on /dev/sda3. Priority:-1 extents:1 across:8514556k SSFS
[ 3.230192] Linux video capture interface: v2.00
[ 3.264063] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (1bcf:2804)
[ 3.281703] input: Laptop_Integrated_Webcam_HD as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input11
[ 3.281805] usbcore: registered new interface driver uvcvideo
[ 3.281808] USB Video Class driver (1.1.1)
[ 3.295677] random: nonblocking pool is initialized
[ 3.299162] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.306025] input: Dell WMI hotkeys as /devices/virtual/input/input12
[ 3.324672] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 3.347588] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD90BXX: line_outs=1 (0xe/0x0/0x0/0x0/0x0) type:line
[ 3.347590] snd_hda_codec_idt hdaudioC0D0: speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
[ 3.347591] snd_hda_codec_idt hdaudioC0D0: hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[ 3.347593] snd_hda_codec_idt hdaudioC0D0: mono: mono_out=0x0
[ 3.347594] snd_hda_codec_idt hdaudioC0D0: inputs:
[ 3.347596] snd_hda_codec_idt hdaudioC0D0: Dock Mic=0xf
[ 3.347597] snd_hda_codec_idt hdaudioC0D0: Internal Mic=0x11
[ 3.347599] snd_hda_codec_idt hdaudioC0D0: Mic=0xa
[ 3.363187] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 3.395632] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 3.397342] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 3.397418] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 3.397491] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 3.397556] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 3.397607] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 3.397674] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 3.399258] dell_laptop: Using i8042 filter function for receiving events
[ 3.401403] intel_rapl: Found RAPL domain package
[ 3.401408] intel_rapl: Found RAPL domain core
[ 3.401410] intel_rapl: Found RAPL domain uncore
[ 3.401416] intel_rapl: RAPL package 0 domain package locked by BIOS
[ 3.455299] audit: type=1400 audit(1468236042.135:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/ubuntu-core-launcher" pid=662 comm="apparmor_parser"
[ 3.456819] cfg80211: World regulatory domain updated:
[ 3.456822] cfg80211: DFS Master region: unset
[ 3.456824] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 3.456826] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.456827] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.456828] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.456830] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 3.456831] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 3.456833] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 3.456834] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 3.456835] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 3.463285] audit: type=1400 audit(1468236042.143:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=658 comm="apparmor_parser"
[ 3.463298] audit: type=1400 audit(1468236042.143:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=658 comm="apparmor_parser"
[ 3.463305] audit: type=1400 audit(1468236042.143:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=658 comm="apparmor_parser"
[ 3.463312] audit: type=1400 audit(1468236042.143:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=658 comm="apparmor_parser"
[ 3.463712] audit: type=1400 audit(1468236042.143:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=657 comm="apparmor_parser"
[ 3.463721] audit: type=1400 audit(1468236042.143:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=657 comm="apparmor_parser"
[ 3.465367] audit: type=1400 audit(1468236042.147:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=670 comm="apparmor_parser"
[ 3.466818] audit: type=1400 audit(1468236042.147:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=672 comm="apparmor_parser"
[ 3.702974] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 3.705983] vboxdrv: Found 4 processor cores
[ 3.724069] vboxdrv: TSC mode is Invariant, tentative frequency 2494329850 Hz
[ 3.724073] vboxdrv: Successfully loaded version 5.0.24 (interface 0x00240000)
[ 3.780560] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 3.780695] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[ 3.780936] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[ 3.781032] iwlwifi 0000:02:00.0: Radio type=0x1-0x2-0x0
[ 3.927708] VBoxNetFlt: Successfully started.
[ 3.928925] VBoxNetAdp: Successfully started.
[ 3.930254] VBoxPciLinuxInit
[ 3.932483] vboxpci: IOMMU not found (not registered)
[ 4.052238] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[ 4.052473] iwlwifi 0000:02:00.0: L1 Enabled - LTR Disabled
[ 4.052569] iwlwifi 0000:02:00.0: Radio type=0x1-0x2-0x0
[ 4.136129] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 4.139839] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 4.376482] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[ 4.486158] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 12.387848] wlp2s0: authenticate with 54:22:f8:c2:65:58
[ 12.392061] wlp2s0: send auth to 54:22:f8:c2:65:58 (try 1/3)
[ 12.394521] wlp2s0: authenticated
[ 12.395701] wlp2s0: associate with 54:22:f8:c2:65:58 (try 1/3)
[ 12.401962] wlp2s0: RX AssocResp from 54:22:f8:c2:65:58 (capab=0x411 status=0 aid=2)
[ 12.407299] wlp2s0: associated
[ 12.407334] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 21.781765] usb 2-1.3: USB disconnect, device number 3
[ 23.515270] usb 2-1.3: new full-speed USB device number 5 using ehci-pci
[ 23.613000] usb 2-1.3: New USB device found, idVendor=248a, idProduct=8367
[ 23.613012] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 23.613019] usb 2-1.3: Product: Wireless Receiver
[ 23.613032] usb 2-1.3: Manufacturer: Telink
[ 23.616925] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/0003:248A:8367.0003/input/input20
[ 23.671485] hid-generic 0003:248A:8367.0003: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input0
[ 23.673738] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:248A:8367.0004/input/input21
[ 23.727634] hid-generic 0003:248A:8367.0004: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input1
[ 32.789110] usb 2-1.3: USB disconnect, device number 5
[ 37.338352] usb 2-1.3: new full-speed USB device number 6 using ehci-pci
[ 37.434866] usb 2-1.3: New USB device found, idVendor=248a, idProduct=8367
[ 37.434877] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 37.434888] usb 2-1.3: Product: Wireless Receiver
[ 37.434890] usb 2-1.3: Manufacturer: Telink
[ 37.438920] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/0003:248A:8367.0005/input/input22
[ 37.493244] hid-generic 0003:248A:8367.0005: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input0
[ 37.495416] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:248A:8367.0006/input/input23
[ 37.548716] hid-generic 0003:248A:8367.0006: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:1d.0-1.3/input1
[ 50.452443] usb 2-1.3: USB disconnect, device number 6
[ 52.187738] usb 2-1.4: new full-speed USB device number 7 using ehci-pci
[ 52.285194] usb 2-1.4: New USB device found, idVendor=248a, idProduct=8367
[ 52.285207] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 52.285212] usb 2-1.4: Product: Wireless Receiver
[ 52.285225] usb 2-1.4: Manufacturer: Telink
[ 52.289319] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/0003:248A:8367.0007/input/input24
[ 52.343596] hid-generic 0003:248A:8367.0007: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-0000:00:1d.0-1.4/input0
[ 52.345630] input: Telink Wireless Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/0003:248A:8367.0008/input/input25
[ 52.399509] hid-generic 0003:248A:8367.0008: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-0000:00:1d.0-1.4/input1
bob@bob-Latitude-E6220:
